Tim Stevens | 25/11/2015 11:19:49 |
![]() 1779 forum posts 1 photos | Please, what is a Weighshaft? I need to know to make sense of the recent ME article on making a Garrett 4CD Tractor (p797) Thanks Tim Edited By Tim Stevens on 25/11/2015 11:20:15 |
JasonB | 25/11/2015 11:31:30 |
![]() 25215 forum posts 3105 photos 1 articles | It's the bit that goes in the weightshaft bracket
Part of the stevensons valve gear. The rod from the reversing lever attatches to an arm which is fitted to one end of the weightshaft, the one pointing down on the bottom left of this pic. The shaft then runs through the bracket and has the lifting link lever (forked arm) on it which inturn has the lifting links pivoting on its end and these lift the expansion link to engage the forward or reverse eccentric Edited By JasonB on 25/11/2015 11:32:53 |
Tim Stevens | 25/11/2015 12:06:10 |
![]() 1779 forum posts 1 photos | Thanks for that (but it should have been the editor's job, I suspect) So is the origin of the name anything to do with the 'Shaft which alters the way it goes along' and then mis-spelt by someone who thought it ought to be cleverer than that? PS the article does say weigh- and not weight- in several places ... Tim |
julian atkins | 25/11/2015 12:23:04 |
![]() 1285 forum posts 353 photos | hi tim, the term weighshaft is derived from an old meaning of 'weigh' as in to 'raise up' as in 'weigh the anchor'. the weighshaft is the means by which the radius rod in walschaerts gear is moved, or the expansion link moved in stephensons gear. in fullsive raising up these parts can be quite heavy and require a lot of effort, and a counterbalance is often added to the weighshaft with stephensons gear to assist the 'raising up'. cheers, julian |
Martin Kyte | 25/11/2015 12:34:39 |
![]() 3445 forum posts 62 photos | Is it not a variant on way and meaning motion. Weigh shafts in marine engines are part of the starting gear. We talk of motion work and valve gear. Giving weigh or way to someone meaning to allow them to continue in motion. So the weigh shaft is that which gives motion to whatever it is attached to. regards Martin |
JasonB | 25/11/2015 13:05:38 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Tim Stevens on 25/11/2015 12:06:10:
He would probably have said its something to do with the Milkyweigh |
John Stevenson | 25/11/2015 13:07:52 |
![]() 5068 forum posts 3 photos | Naw, He's a genuine hazelnut guy |
Bazyle | 25/11/2015 13:10:14 |
![]() 6956 forum posts 229 photos | So it doesn't have anything to do with counterbalancing the weight of the links? Not a problem in models but how do they do that full size or is it just brute strength? |
JasonB | 25/11/2015 13:18:15 |
![]() 25215 forum posts 3105 photos 1 articles | May be why the reversing levers are so long to give about a 3:1 advantage |
Neil Wyatt | 25/11/2015 14:40:44 |
![]() 19226 forum posts 749 photos 86 articles | A weighshaft is any shaft that moves back and forth, rather than rotating. It's a very common item in control gear, such as valve gear. While it's not feasible for Diane (or me) to include a glossary for every article, you can find a definition in the 'Workshop A-Z' HERE - a little something I put together for just these situations! Neil |
JasonB | 25/11/2015 16:00:43 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Neil Wyatt on 25/11/2015 14:40:44:
A weighshaft is any shaft that moves back and forth, rather than rotating. But the weighshaft does rotate and not move back & forth The lever hanging off the end moves back & forth and the lifting link lever moves up and down but it's the shaft that rotates |
KWIL | 25/11/2015 16:32:15 |
3681 forum posts 70 photos | Stick to stars and electronics Neil |
Neil Wyatt | 25/11/2015 16:46:03 |
![]() 19226 forum posts 749 photos 86 articles | Posted by JasonB on 25/11/2015 16:00:43:
A weighshaft is any shaft that moves back and forth, rather than rotating. But the weighshaft does rotate and not move back & forth The lever hanging off the end moves back & forth and the lifting link lever moves up and down but it's the shaft that rotates Rotation is to move in a circle, a weighshaft only moves in an arc of a circle, or it would be a crankshaft. Craknkshafts rotate, weighshafts sway gracefully back and forth. To be absolutely exact a weighshaft translates linear motion in one plane into linear motion in another, parallel plane.
Edited By Neil Wyatt on 25/11/2015 16:46:31 Edited By Neil Wyatt on 25/11/2015 16:57:27 |
JasonB | 25/11/2015 17:08:33 |
![]() 25215 forum posts 3105 photos 1 articles | "weighshafts sway gracefully back and forth." Are we looking at the same thing, weighshaft on a traction engine does not sway back and forth gracefully or not |
Neil Wyatt | 25/11/2015 19:05:27 |
![]() 19226 forum posts 749 photos 86 articles | <missed smiley alert> Neil |
Howard Lewis | 27/11/2015 20:05:24 |
7227 forum posts 21 photos | On some, (mostly the later locomotives), full size engines, the forces involved were so great that using a reversing lever (Johnson bar in U S A) was not feasible, and so brought about the screw reverser, which delivered greater forces, and allowed more precise setting of the valve gear for expansive working. Howard |
Brian G | 27/11/2015 21:03:53 |
912 forum posts 40 photos | Or the steam reverser, a device which sometimes gained a reputation for allowing much less precise setting of the valve gear for direction, let alone expansion. Brian |
Chris Gunn | 28/11/2015 01:49:06 |
459 forum posts 28 photos | Tim, as the author of the article in question, I am sorry if the descriptions have given rise to any confusion. I am using the descriptions that appear in the drawings, which in this context are pretty standard, weighshafts are mentioned in many articles covering locomotive and traction engine construction. I felt that this was better than using "non standard" descriptions which may have caused more confusion. Chris Gunn |
Tim Stevens | 28/11/2015 16:43:52 |
![]() 1779 forum posts 1 photos | Please don't worry, Chris I just came across a word which was new to me and I felt that I needed to find out more. Which I did. This was a term which my dictionaries and Wiki etc were silent about, so thanks for prompting the question. Regards, Tim |
