John Smith 47 | 11/11/2015 19:54:17 |
393 forum posts 12 photos | Hello I need to drill extremely small holes (c.1mm, possibly less) into styrene and PE. What RPM should I use? Background My main alternative is to find a clever way to mount the 1mm drill bit in my Black & Decker cordless drill (Hp188F30 which has much slower speeds (quoted at "0-450 / 0-1450 RPM" without load) I had previously thought that you'd need a really fast RPM to drill using a really small diameter drill bit. Now, because of melting I'm not so sure!
JasonB | 11/11/2015 20:01:18 |
![]() 25215 forum posts 3105 photos 1 articles | Nothing wrong with using a pin chuck or arcamedean drill, done plenty of holes when plastic modeling with them. This type work well as you can apply pressure to the top piece while rotating the body. I have 4 or 5 of them, keep a different siz ebit in each. Edited By JasonB on 11/11/2015 20:04:30 |
Paul Lousick | 11/11/2015 20:12:02 |
2276 forum posts 801 photos | Get a mini chuck that fits into your cordless drill chuck. Available from flea-bay, hardware stores. |
Ajohnw | 11/11/2015 20:34:47 |
3631 forum posts 160 photos | I use a pin vice along the same lines as Jason. You might find the plastic doesn't melt if you up the feed rate - sort of punch the drill through rapidly. John - |
John Smith 47 | 11/11/2015 21:45:52 |
393 forum posts 12 photos | Aracmedean drill looks reasonable and would avoid overheating. I'm less clear about would you pin chuck though... |
John Smith 47 | 11/11/2015 22:01:53 |
393 forum posts 12 photos | Posted by John W1 on 11/11/2015 20:34:47:
I use a pin vice along the same lines as Jason. You might find the plastic doesn't melt if you up the feed rate - sort of punch the drill through rapidly. John - I tried setting the speed at 5000RPM and doing it v fast. It works a bit. But can then get stuck. Worse, there is no reverse gear in my nice new Proxxon mini drill (Micromot 50/EF) - why didn't any one tell me? So getting it out is rather hard. |
Ajohnw | 11/11/2015 22:18:16 |
3631 forum posts 160 photos | Wind it off by hand. Sounds like you fed it too fast. John - |
Michael Gilligan | 11/11/2015 23:07:08 |
![]() 23121 forum posts 1360 photos | Posted by John Smith 47 on 11/11/2015 22:01:53:
I tried setting the speed at 5000RPM and doing it v fast. It works a bit. But can then get stuck. Worse, there is no reverse gear in my nice new Proxxon mini drill (Micromot 50/EF) - why didn't any one tell me? So getting it out is rather hard. . I would advise against trying to reverse it by swapping the DC leads over ... for at least two reasons:
Edited By Michael Gilligan on 11/11/2015 23:08:22 |
julian atkins | 11/11/2015 23:31:44 |
![]() 1285 forum posts 353 photos | i would suggest that your drills are 'shot'! i decent well sharpened drill of that size should not cause any problems, however high the RPM. there are lots of PCB carbide drills of 1mm on the market and ebay and even an ordinary 1mm drill should be ok. for those of us who do fine work and make injectors 1mm isnt extremely small! cheers, julian Edited By julian atkins on 11/11/2015 23:33:10 |
pgk pgk | 12/11/2015 00:38:57 |
2661 forum posts 294 photos | In a past life I've drilled tiny holes using disposable syringe needles - just twiddling them in fingers by their hub - they're so sharp that they'll go through living bone with patience (and the odd throwaway) - when I;ve needed to pass fixing wires through small fragments. Smaller than 23g are too flexible wthout great care but 22g or 21g would be easy enough. |
John Smith 47 | 12/11/2015 10:56:12 |
393 forum posts 12 photos | OK but nobody is answering the question what is the ideal RPM for drilling 1mm holes into soft plastic e.g. HIPS/styrene. |
Michael Gilligan | 12/11/2015 11:09:01 |
![]() 23121 forum posts 1360 photos | Posted by John Smith 47 on 12/11/2015 10:56:12:
OK but nobody is answering the question what is the ideal RPM for drilling 1mm holes into soft plastic e.g. HIPS/styrene. . John, This is not meant to be confrontational ... although it will probably appear so: The reason nobody is answering your question is that there is no simple numerical answer. The answer will depend upon
MichaelG. |
Jeff Dayman | 12/11/2015 11:16:09 |
2356 forum posts 47 photos | If you are generating heat, slow the drill way down, say to 100-200 rpm, and pull it back out frequently to clear chips. I would not recommend drilling depth more than 6 to 10 times drill diameter in plastics. As said before, it sounds like your design is overcomplicated and needs to be simplified to be more easily producible. No one in industry would design something with drilling small holes in styrene to the full length of the drill unless there was absolutely no other way- it is an invitation to trouble, as you are finding out. Same with trying to bond ABS/Styrene and PE/PP. There are usually ways to redesign things to be simple to make and strong enough to do the job. Styrene and polyethylene are not the optimal choices of material to make machined things with high spring loads. JD |
John Smith 47 | 12/11/2015 11:20:52 |
393 forum posts 12 photos | Posted by Michael Gilligan on 11/11/2015 23:07:08:
To explain my thinking: Re "2." I'm not 100% sure of the mechanics, but I think this is unlikely because: On my little Richmond drill I used an old H&M branded controller (originally for model railways I think) that has a dial that you turn one direction for forwards and the other direction for reverse. Works just fine, reversing the direction for the motor without a problem.
Edited By John Smith 47 on 12/11/2015 11:30:50 |
John Smith 47 | 12/11/2015 11:23:46 |
393 forum posts 12 photos | Posted by Michael Gilligan on 12/11/2015 11:09:01:
Ah fair enough - but I am only looking for an order of magnitude answer. |
John Smith 47 | 12/11/2015 11:57:20 |
393 forum posts 12 photos | Posted by Jeff Dayman on 12/11/2015 11:16:09:
If you are generating heat, slow the drill way down, say to 100-200 rpm, and pull it back out frequently to clear chips. I would not recommend drilling depth more than 6 to 10 times drill diameter in plastics. As said before, it sounds like your design is overcomplicated and needs to be simplified to be more easily producible. No one in industry would design something with drilling small holes in styrene to the full length of the drill unless there was absolutely no other way- it is an invitation to trouble, as you are finding out. Same with trying to bond ABS/Styrene and PE/PP. There are usually ways to redesign things to be simple to make and strong enough to do the job. Styrene and polyethylene are not the optimal choices of material to make machined things with high spring loads. JD Jeff |
John Smith 47 | 12/11/2015 11:59:10 |
393 forum posts 12 photos | Posted by pgk pgk on 12/11/2015 00:38:57:
In a past life I've drilled tiny holes using disposable syringe needles - just twiddling them in fingers by their hub - they're so sharp that they'll go through living bone with patience (and the odd throwaway) - when I;ve needed to pass fixing wires through small fragments. Smaller than 23g are too flexible wthout great care but 22g or 21g would be easy enough. OK so it sounds like to an order of magnitude as little as 5RPM could be my answer, yes? |
Ajohnw | 12/11/2015 13:15:21 |
3631 forum posts 160 photos | For the sort of thing you are trying to do and making some assumptions along that line I think you should look at buying something like this A lot more flexible than you Proxon and still small and relatively light. It looks like it has a couple of pluses. Depth stop and the ability to tilt one axis of the table - good because you can adjust that axis to be square to the drill, The vice might be junk or on the other hand might not be. The 16mm chuck is for woodwork really and for the size of drill you are using you will need a pin chuck as per a previous post. The chucks they fit tend to eventually go wonky when small drills are held. On the other hand they often have a 2 morse chuck fitted and that can be changed to say a Jacobs keyed chuck with a capacity of 1/2 / 13mm or less. That size will just hold 1mm drills so a 3/8" or even 1/4 / 5/16 might be wiser just to make sure. The problem with the 5/8 chuck fitted is that there is too much jaw sticking out and not enough inside when they are fitted with fine drills. There is no real answer to speed. The drill needs to be cutting and producing swarf and not clogging. I'd guess I would try something around 500 rpm or higher with a sharp drill. I wouldn't be at all surprised if the drill took some effort when it was pulled out after drilling the hole especially if it wasn't rotating. John -
Edited By John W1 on 12/11/2015 13:16:56 Edited By John W1 on 12/11/2015 13:18:42 |
John Smith 47 | 12/11/2015 13:44:18 |
393 forum posts 12 photos | Posted by John Smith 47 on 12/11/2015 11:20:52:
Ooops! What I will say is that it didn't bother me much! It was still useful to be able to hit reverse in order to get a stuck drill out - and if it slipped a bit it could be tightened up and hit reverse again!
pgk pgk | 12/11/2015 14:15:05 |
2661 forum posts 294 photos | Posted by John Smith 47 on 12/11/2015 11:59:10:
In a past life I've drilled tiny holes using disposable syringe needles - just twiddling them in fingers by their hub - they're so sharp that they'll go through living bone with patience (and the odd throwaway) - when I;ve needed to pass fixing wires through small fragments. Smaller than 23g are too flexible wthout great care but 22g or 21g would be easy enough. OK so it sounds like to an order of magnitude as little as 5RPM could be my answer, yes? The point (fortuitous pun) I was making is that a sharp enough implement and slow enough speed to avoid your heat issue. Indeed it may even be easier to use a pin that you drill in and leave rather than drilling a hole and then putting in a pin after struggling to pull the drill out. Say something like a three sided grind (as in toolmakers reamer or bone pin) with a thin smear of slow epoxy into some scratches before placement or even some concentric rings around the pin (yeah hard when this small) so that the plastic grips back into them. It'd take a bit of playing with on some scrap. Dentists also have some tiny screw ended pins for attaching crowns and fillings. |
