Locating a clonking sound
Speedy Builder5 | 05/11/2015 21:11:03 |
2878 forum posts 248 photos | I have finally tracked down a loud clonking noise when selecting forward after being used in reverse. I thought it was sort of headstock noise, but finally tracked it down to the undermount single phase motor. This motor is mounted on rubber mounts at each end of the motor frame. Over time, the rubber has worn / lost its elasticity allowing the motor to rotate some 60 degrees or so when it is reversed. In spite of doing up the clamps which pinch the rubber mounts onto the motor it still rotated in its mounts. Edited By Speedy Builder5 on 05/11/2015 21:14:07 |
Nick_G | 05/11/2015 23:14:26 |
![]() 1808 forum posts 744 photos | Posted by Speedy Builder5 on 05/11/2015 21:11:03:
which direction should the segmented belt run in normal forward operation.
I have a segmented belt also. I would also like to know if there is a right and wrong way round.?
Nick |
Ady1 | 06/11/2015 00:42:46 |
![]() 6137 forum posts 893 photos | Link belt on Myford |
AndyP | 06/11/2015 11:25:51 |
189 forum posts 30 photos | The open end of the link on the inside of the belt trails so that in this photo the pulleys are rotating clockwise as we look at them. The powertwist belt which is what I have on my Boxford AUD has arrows printed on it. Andy |
Ian S C | 08/11/2015 10:00:28 |
![]() 7468 forum posts 230 photos | My lathe started clonking in sympathy, I found it was the primary drive belt (Power Twist) was starting to break down, it's been in place for twenty years, and it's only about a month ago that I took a link out because it was too loose, I did not notice the worn links. Ian S C |
KWIL | 08/11/2015 10:13:59 |
3681 forum posts 70 photos | I had a similar "end of life" rubber motor mount and had them repaired by a local rubber moulding firm. A little firmer than original but still a "resilient mounted motor". Bolting down with a rigid strap is not really the answer with a single phase motor. |
