Anyone want to guess the colour code?
pgk pgk21/08/2015 20:28:54
2661 forum posts
294 photos
Local scrappy scored some useful parts for me including some round bar lengths of steel with just a dusting of rust approx inch diameter and 4 foot long. This was from a rubbish clearance from a deceased hobbyist.
Some of the bars have off-white painted ends, some a dull mid green and one the same green wth a black '1' in the middle.
I realise colour codes can be personal amongst stockist but just on the off-chance it rings a bell....?
(The haul also included 2 different v blocks a pair of v blcks with clamps. 2 different size bullfinch burners an engineers clamp and a 'eclipse' holder with assorted blades which include hand slittign saws and files and knives.. about the size of a thin stanley knife in it's original cardboard box. £20 the lot seemed a bargain)
Neil Wyatt21/08/2015 20:34:52
19226 forum posts
749 photos
86 articles
It's almost certainly steel of some sort
Try the spark test on it.
Andrew Johnston21/08/2015 22:23:28
7061 forum posts
719 photos
According to the steel stockist I use white is EN16T and green is EN1A, which may also explain the black '1'.
Ajohnw21/08/2015 22:58:28
3631 forum posts
160 photos
I think the white will be free cutting mild steel. Green may be ke805 or something like that - green/black - memory is rather hazy on that one but pretty sure green was used.
I don't think that mild steel that could be case hardened was marked with white.
JasonB22/08/2015 07:29:58
1+ for what andrew says and also on Parkers chart, the 1 could just be to differentiate 1" from 25mm stock, I tend to do it the other way and mark the metric stuff as I have less of that.
David Clark 122/08/2015 08:55:44
3357 forum posts
112 photos
10 articles
Green is usually en1a I think. Blue en3b. Perhaps the black means leaded. I think en32 was red. It was a long time ago. Try macreadies steel stockholders if they are still about.
Nigel McBurney 122/08/2015 09:02:03
1101 forum posts
White was used for en3B for a long time ,parker steel now mark en16 with white, green is fairly universal for en 1A, the green with no 1 marked in black could be the owner marking it to remind him that it was no1. EN 3b is mild steel but doe not machine as well as EN1b. If its en16 it does not machine easily and is very tough,don't weld unless you know what you are doing.
Michael Gilligan22/08/2015 10:18:13
23121 forum posts
1360 photos
This thread reminds me of the classic film Green for Danger
[quote] When Nurse Linley seems to be on the point of suffering the same mysterious death as the postman, the Inspector realises that a cylinder of gas, normally painted green, has been repainted black to resemble an oxygen cylinder. [/quote]
Edited By Michael Gilligan on 22/08/2015 10:19:12
John Hinkley22/08/2015 10:51:50
1545 forum posts
484 photos
Just checked my stock of steel odds and ends, following our recent move and it all seems to be coded a rather fetching shade of light brown!! Need to get the Scotchbrite out.
P.S. New mill arrived yesterday.  Had to order an engine crane today!  Hope to make a start on fitting the DROs and power feed motor while I wait for its delivery.
Edited By John Hinkley on 22/08/2015 10:55:57
Edited By John Hinkley on 22/08/2015 10:56:32
Neil Wyatt22/08/2015 13:45:06
19226 forum posts
749 photos
86 articles
I have cyan for EN1A and magenta for EN1APb in my stocks.
Nick Hughes22/08/2015 16:46:20
307 forum posts
150 photos
The other thing you're up against is that the smaller bar ends are not individually painted (and 1" Dia is considered small), but the whole bundle of say 100 bars is done as if it was a large single bar. So for a two colour code e.g. Brown/Green, depending where the bar is taken from the bundle, it could have either a Brown, or a Green painted end. This of course means unless the bar is re-painted after removing from the bundle, then just checking the colour code charts would lead you to think that the bar was either EN24T (Brown) or EN1A Freecutting (Green) rather than EN24 Annealed.
Note:- the above colours are from the Parker Steel Colour Code Chart.
Nick.
Edited By Nick Hughes on 22/08/2015 16:52:21
Neil Wyatt22/08/2015 17:10:28
19226 forum posts
749 photos
86 articles
My local stockholders thought it was really funny that I was grasping a copy of the a 'standard' colour chart. Apparently I'm not the first to have come to grief by using it to select from their shortends.
I think some of them change the colours as a protection against theft.
Bowber22/08/2015 18:08:48
169 forum posts
24 photos
We used to add coloured tape to the bars, however there was always some numpty who would cut off the end with the colour code!
And if you came back into the shop grasping the end with the colour code on you didn't do it again!
Steve
