Carbon Fibre tube supplier?
Stuart Bridger05/08/2015 21:59:14
566 forum posts
31 photos
Friedn of mine is looking for a carbon fibre tube 1.6m long by 400mm dia. Astronomy application, any ideas of suppliers?
Thanks
Stuart
Ralph H05/08/2015 22:18:10
74 forum posts
Try Hardy's and Grey's Ltd http://www.hardyfishing.com/en-gb/home/
or Attwater and Sons http://www.attwater.com/.
I can recommend both as they are suppliers to the firm I work for.They should be be able to advise you on a solution.
Edited By Ralph H on 05/08/2015 22:19:38
Ian P05/08/2015 22:27:30
2747 forum posts
123 photos
By coincidence 10 minutes ago I sent an email for a quote for a c/f tube. Its a company I have bought custom tubes from for several years now and have always been very satisfied. (no connection to me)
They are www.Tri-cast.co.uk
Ian P
Ian P05/08/2015 22:28:12
2747 forum posts
123 photos
Posted by Ian Phillips on 05/08/2015 22:27:30:
Ian P
PS I think they do up to 1m diameter at least
Keith Long05/08/2015 22:32:56
883 forum posts
11 photos
That's a serious bit of composite tubing - your friend will likely need deep pockets. Is carbon fibre necessary, would glass fibre do the job?
I would guess you'd be looking at a custom made tube, either filament wound or laid up from pre-preg sheet, if you can find a company that bcan do that sort of size you might have to alter the diameter a bit to make use of an existing former, a custom mandrel wouild be very expensive - ours were and they were only about 150mm diameter.and shorter than you're looking for.
Michael Gilligan05/08/2015 22:58:02
23121 forum posts
1360 photos
Posted by Keith Long on 05/08/2015 22:32:56:
... Is carbon fibre necessary, would glass fibre do the job?
Keith,
If it's for a telescope OTA, then carbon's near-zero coefficient of thermal expansion is very desirable.
Keith Long05/08/2015 23:10:13
883 forum posts
11 photos
I fully realised that Michael
Stuart Bridger05/08/2015 23:46:40
566 forum posts
31 photos
Thanks for the suggestions
Michael Gilligan06/08/2015 05:33:43
23121 forum posts
1360 photos
Posted by Keith Long on 05/08/2015 23:10:13:
My apologies, Keith ... no slight intended.
It's only a fine line between 'necessary' and 'very desirable'
Michael Gilligan06/08/2015 06:18:40
23121 forum posts
1360 photos
Stuart,
It's interesting to see that Orion Optics is using 'sandwich construction'
... 'though I'm not aware what core material is used.
See also, this page from DreamScopes
Edit: This might be of interest.
Edited By Michael Gilligan on 06/08/2015 06:21:39
Edited By Michael Gilligan on 06/08/2015 06:28:46
Michael Gilligan06/08/2015 09:29:37
23121 forum posts
1360 photos
Posted by Michael Gilligan on 06/08/2015 06:18:40:
Stuart,
Oops ... that link seems to be wrong ... Try this
Ian P06/08/2015 09:44:40
2747 forum posts
123 photos
Stuart
Would 372.97mm internal diameter be big enough?
I have a list of mandrel sizes that Tri-cast use and this one at 900mm long seems to be the nearest.
Wall thickness can be whatever you want, most of mine have been between 3 and 6mm
Ian P
Circlip06/08/2015 11:16:28
1723 forum posts
Would think the "Meat" is either honeycomb or extruded (Blue) foam.
Regards Ian.
Michael Gilligan06/08/2015 21:22:45
23121 forum posts
1360 photos
Posted by Circlip on 06/08/2015 11:16:28:
Regards Ian.
Very likely, Ian
I should probably have been more explicit, and written:
"... 'though I'm not aware what core material is used by Orion in these particular tubes."
Nick_G06/08/2015 22:03:01
1808 forum posts
744 photos
There is a company in Runcorn called Sigmatex. (I did some work for them back in my sparking days)
They weave CF in a large number of widths and weights from something resembling fine silk to course mesh. I remember them telling me at the time that they supplied 90% of the F1 teams and a number of aircraft manufacturers. I also remember them telling me that it was also used to produce helicopter blades and to do this the weave layers were placed in varying directions and a mixture of course and fine fabrics.
They seemed quite open and approachable people. You may be able to purchase a 'roll end' off them and combined with a former make your own. ..... Possibly.!
Failing that, I would be surprised if they were not able to point you in the right direction of such a tube supplier.
Regards, Nick
Michael Gilligan06/08/2015 22:13:46
23121 forum posts
1360 photos
Suitable tubes are available here
... wrong side of the pond, I presume.
crying
