Windy | 23/07/2015 12:14:20 |
![]() 910 forum posts 197 photos | As only a hobby machinist but interested in everything mechanical I have Sandvik email me details of there tooling. The latest shows a dampened boring bar with long overhang apart from coolant at high pressure being used how is the bar dampened. It might be of use to us if it's not too complicated to make one. Neil I have sent you a message. Paul |
David Clark 1 | 23/07/2015 12:42:21 |
![]() 3357 forum posts 112 photos 10 articles | I seem to remember some boring bars had carbide running down the centre to stop vibration. |
Muzzer | 23/07/2015 12:59:05 |
![]() 2904 forum posts 448 photos | Never used one myself and I expect they are professionally priced but a quick search reveals that most of them appear to have a mass / spring / damper assembly within the (hollow) body. The damper element being a viscous oil or mechanical friction mechanism. Anyone here tried to make one of these? |
Michael Gilligan | 23/07/2015 14:58:26 |
![]() 23121 forum posts 1360 photos | Posted by Muzzer on 23/07/2015 12:59:05:
.... most of them appear to have a mass / spring / damper assembly within the (hollow) body. The damper element being a viscous oil or mechanical friction mechanism. Anyone here tried to make one of these? . 'fraid not ... But I have used the simple expedient of adding a good lump of Blu Tack I can't comment on any of the alternative products, but the original stuff has remarkable damping properties. ... It may be the most thixotropic material known. MichaelG. |
Nick_G | 23/07/2015 15:16:27 |
![]() 1808 forum posts 744 photos | . I have heard wrapping the bar in lead sheet can sometimes assist in removing harmonic vibrations.
Nick |
Muzzer | 23/07/2015 15:20:42 |
![]() 2904 forum posts 448 photos | Reminds me of that most unfortunate of vehicles, the 2CV. Even by French standards it was thrashed and violated mercilessly by the ugly stick, both on the drawing board and in the flesh. However, one notable feature was the front dampers which were mounted on the front swing arms without any form of coupling to the chassis. Unsprung mass was the least of their worries. And also from a previous era, green Swarfega was a remarkable gel that seemed to be able to hold its form for months. Presumably that would make it "more" thixotropic? Is that how thixotropicity(?) works? Murray |
Gordon W | 23/07/2015 16:12:51 |
2011 forum posts | That 2CV damper was of course filled with oil, and worked very well, and never leaked, so never failed the MOT. I had a fail once 'cos the man had never seen one before and assumed some bits were missing. I am in the process of making a long boring bar, from pipe, and plan to fill it with lead. I will report back when done, about next xmas at the speed things are going just now. |
IanT | 23/07/2015 16:44:59 |
2147 forum posts 222 photos | I've tried soft solder wrapped around the end of a boring arm which seemed to improve things but I will try the Blu Tack suggested by Michael - that one hadn't occurred to me but sounds oddly appealing for some reason.. I have no idea what the mechanics involved in all of this are but it does seem to help by changing one of the many variables combining to cause the chatter in the first place. Obvious things like a speed change, a slight tool height adjustment and a squirt of cutting oil can all help to make a difference. Beyond that, I don't do enough boring to get expert, so I'm always very pleased when it goes well. It's usually preceded by a bit of tweaking, general fiddling about, some bad language and a dollop of superstition (e.g. touching wood etc.) all of which also seem to help. IanT |
Bazyle | 23/07/2015 16:55:41 |
![]() 6956 forum posts 229 photos | Sand in a tube might also be an option. I wonder if lead shot would work better than solid lead. If you remember mixing custard from powder you were instructed to add a very little water to start with and mix. The paste at that point is a tixotropic substance.- sudden movement causes the particles to lock together, but slow movement is possible. Quicksand is another example. Blutack is just a paste (too much liquid phase) and swarfega is a gel so no better than a thick oil. |
Windy | 23/07/2015 16:56:47 |
![]() 910 forum posts 197 photos | Once when doing some light boring the noise did not seem right I just gently rested my finger on the bar and it was better not to be recommended for H and S grounds. Any spare fingers. Paul |
Muzzer | 23/07/2015 16:59:35 |
![]() 2904 forum posts 448 photos | Gordon - apart from changing the mass of the bar which may have a marginal effect on the onset of squeal and chatter, filling the bar with lead doesn't seem likely to affect the outcome much. It's going to be a fine balance, as the very act of hollowing out the boring bar enough to affect anything will reduce its rigidity. To make a real impact I suspect you will need to allow the internal mass to have some degree of movement against a spring plus a damping medium such as a viscous fluid to absorb enough energy to damp out any resonance. Murray |
Dinosaur Engineer | 23/07/2015 17:29:02 |
147 forum posts 4 photos | Making the bar from tungsten ( if you can find any & expensive !) is one of the better ways of reducing vibration. |
KWIL | 23/07/2015 19:49:29 |
3681 forum posts 70 photos | Solid carbide boring bars work very well as regards dampened vibration. Bit more expensive but worth it I have found. |
Bob Strawson | 23/07/2015 20:24:25 |
8 forum posts | Elastic bands stretched around the bar can often curb chatter or vibration. Just wind as many as can be fitted around the bar as tightly as possible without getting in the way of the material. It seems to change the frequency at which the bar will vibrate. The best solution, if you can afford it is tungsten carbide, as previously advised. The old adage,"increase the feed, decrease the speed" is also worth remembering. Bob Strawson |
Bowber | 23/07/2015 22:17:52 |
169 forum posts 24 photos | I would imagine a hole down the centre, needs to be below the size were the strength reduces rapidly. The hardened rod will resist bending and the rubber solution will allow a small amount of flex for the boring bar and should help dampen the vibration. Steve |
norman valentine | 23/07/2015 22:36:35 |
280 forum posts 40 photos |
Edited By norman valentine on 23/07/2015 22:40:00 |
Muzzer | 24/07/2015 12:24:36 |
![]() 2904 forum posts 448 photos | Obviously if you have room to fit a big f*** off boring bar, then you have a simple solution. The difficulty arises where the combination of small bore and big length results in enough spring to make it impossible to machine without encountering instability, even with fairly exotic materials for the bar. Even if you eliminate the nonlinearities in the system (backlash etc), you still have a mass and spring resonant system that will be prone to resonance under certain conditions. The best solution is often to damp out the resonance rather than simply trying to move it out of the way. Given the wide range of operating conditions (load, speed, materials etc), it's going to be pretty difficult to move the resonances where they won't be encountered - and there isn't much of a choice of materials that would allow a significantly stiffer boring bar body. Carbide and expensive steels are possibly the best that are realistically available and we use those already. I don't know if the systems used in high speed industrial tooling (mass, spring, damping fluid etc) would actually work in the conditions we encounter in our workshops. And to be honest, I doubt I would be able to do the calculations to start designing them myself. I suspect there will be quite a few PhDs in this area. Might be an area for experimentation! Murray |
Michael Gilligan | 24/07/2015 13:46:03 |
![]() 23121 forum posts 1360 photos | Posted by Muzzer on 24/07/2015 12:24:36:
The difficulty arises where the combination of small bore and big length results in enough spring to make it impossible to machine without encountering instability, even with fairly exotic materials for the bar. ... Even if you eliminate the nonlinearities in the system (backlash etc), you still have a mass and spring resonant system that will be prone to resonance under certain conditions. The best solution is often to damp out the resonance rather than simply trying to move it out of the way. ... Might be an area for experimentation! Murray . Assuming that you want an 'internal' solution [to keep the size down] ... Some background reading on 'constrained-layer damping' would probably be useful. MichaelG. |
KWIL | 24/07/2015 16:15:48 |
3681 forum posts 70 photos | I forgot to mention that with a VFD you can change the rotational speed to potentially move away from the bar resonance that is causing the problem. |
colin hawes | 24/07/2015 18:24:41 |
570 forum posts 18 photos | If a round boring bar is made tapered along its length it should reduce the likelihood of a problematic resonant frequency being generated. Colin |
