Ian Parkin | 08/07/2015 19:01:20 |
![]() 1174 forum posts 303 photos | Does anyone know how to remove the blades and springs from burnerd ec collets I have a set which look almost unused but are sticky they wont open up after closing without help Theres a washer at the front which looks like if that came off the blades would slide out or am i missing a trick
Ian |
John C | 08/07/2015 19:12:41 |
273 forum posts 95 photos | Ian, I wouldn't bother taking them apart. A good lashing of WD 40 or similar will cure the stiffness. Follow up with some general purpose oil. The forces involved in their use will easily overcome any perceived stiffness. Rgds, |
Ian Parkin | 08/07/2015 19:33:47 |
![]() 1174 forum posts 303 photos | Ive tried that no joy so far |
Tony Pratt 1 | 08/07/2015 20:10:58 |
2319 forum posts 13 photos | From a distant memory you take the 'large washer/cover' off, release the springs carefully & remove the blades, I think Tony |
Ian Parkin | 08/07/2015 21:30:56 |
![]() 1174 forum posts 303 photos | I dont seem to be able to get the washer off it looks like it may fit into a shallow groove |
Tony Pratt 1 | 09/07/2015 17:00:55 |
2319 forum posts 13 photos | The washer got on there so you must be able to remove it? Tony |
Ian Parkin | 10/07/2015 09:43:15 |
I removed the springs first thinking that one blade might slip in and pull through the middle But then had to remove the washer with a big screwdriver and hammer...it does fit into a groove The blades were really gummy I dont think any amount of solvent would have got these clean The washer does fit into a groove in the collet body without the blades the washer would possibly spring the body inwards letting the washer slip into the groove but then I cant get the blades in
anybody any idea's Edited By Ian Parkin on 10/07/2015 09:44:07 |
Nick_G | 10/07/2015 10:06:04 |
![]() 1808 forum posts 744 photos | Posted by Ian Parkin on 10/07/2015 09:43:15:
When you say 'gummy' do you mean dried coolant and oil that has turned into something similar to tar.? If so just chuck them into a bowl of cellulose thinners of nail varnish remover for a while then wipe off and relubricate. You may have to do this a couple of times.
Nick |
Nick_G | 10/07/2015 10:39:21 |
Well i sacrificed a collet that had broken blades and i'm still not the wiser how to get it to bits
. If you put them into the chuck with nothing to grip on and tighten them down will the washer then not slip off.?
Nick |
Ian S C | 10/07/2015 11:25:28 |
![]() 7468 forum posts 230 photos | I was thinking of putting a jubilee clip around the collet, and tighten it up, maybe that will compress it enough to remove the washer. Ian S C |
Ian Parkin | 10/07/2015 11:51:38 |
![]() 1174 forum posts 303 photos | I think I've sorted it now I've flattened the washer and by compressing the body the washer slips on...it wont compress when the blades are in 3 blades slip in easily into say 1,2 and 3 position the others have to go in cock eyed but they eventually slipped into place then replace the springs and its good to go The blades are such a good sliding fit and very limited movement < 2mm that i'm not sure that solvent will get in and remove the varnish like substance But now I know how to take them to bits so alls well |
Nick_G | 10/07/2015 11:55:06 |
![]() 1808 forum posts 744 photos | Posted by Ian Parkin on 10/07/2015 11:51:38:
. To solvent 2mm would be seen as an ocean.
Nick |
Ian Parkin | 10/07/2015 12:03:57 |
![]() 1174 forum posts 303 photos | Just to be clear the 1.5mm movement is the in and out sliding radially so the varnish thats sticking the blade will not come out . the solvent may go in but the varnish will reharden after a while....the fit is very tight in the body even with no lube
I did try soaking in mek for a while |
Antony Price | 13/07/2015 20:58:48 |
36 forum posts 29 photos | Hi Ian Just a thought... have you tried an ultrasonic cleaner? Maplin, and others do a mechanical one , try googling "James Products Ultra 7000 Ultrasonic Cleaner" Its around £45, It may save you all the trouble of dismantling each collet. If you near Leeds I have one for you to try Tony
Muzzer | 13/07/2015 23:30:57 |
![]() 2904 forum posts 448 photos | Sounds from what you are saying that you reckon you can just about get the blades out without touching the washer. And I see there are several more pictures in your album. Judging by the chamfered blades, this is one of the smaller sized collets, like around 1/8" (ie biggest blades) so possibly the most tricky to dismantle. Can't read the size from the photos. There seem to be variants on the design, such as the ones shown in this thread. The interesting things is that here the washer is held in by screws or bolts, which rather supports the suspicion that the washer is what holds the blades in place. As your slots and blades are bunged up at the moment, it won't be easy to compress the body much at all. However, after cleaning up it may be possible to compress the body enough to remove the washer. How deep is the groove and what clearance do you measure between the blade and slot, once cleaned up? You probably need a special tool to compress the body with these non-bolted examples, which may the main reason it's proving so challenging. To clean the blades, I'd use a green pot scrubber fitted to a power sander (the sort with the hook and loop pad) and loads of WD40 / Gunk etc - and some form of blade to get the scrubber into the slots in the body. Murray |
Mini | 17/08/2020 10:19:36 |
3 forum posts 2 photos |
Having used this old discussion as reference, I'd like to add how I was able to move a lot of stuck multisize collet blades again, after having bought two sets (really old and old stock): I applied pure acetone with a paint brush and put the collet in plastic zip bags to keep the solvent from evaporating. The blades start moving under finger pressure after about 30 minutes or an hour, with little use of acetone. The idea is a combined form of: - Nick's method (this thread) "...into a bowl of cellulose thinners of nail varnish remover". - A 2012 document "WD-40 Alternative: Final Design Report" testing and suggesting oil mixed with acetone as penetrating oil. (But the figures in the report tell that pure acetone works even better.)
Hope that helps someone! |
David Davies 8 | 17/08/2020 10:30:46 |
![]() 202 forum posts 1 photos | Just a thought, Caustic Soda would soften even the most obstinate dried oil/grease. Remember to add the caustic to water not the other way round and note that it will get hot when being mixed. Don't use it on aluminium. I know Caustic is nasty stuff but acetone is highly flammable. HTH Dave
Dog on wheels | 27/06/2022 12:57:20 |
9 forum posts | I realise that this is an old thread but I wondered if anyone does know of a (non-destructive) method of disassembling these collets for cleaning? Reading the above, I'm not sure if it was found to be possible or not. I have a couple of collets that have a little corrosion on the blades (and one with a load on the inside of the body) that I would ideally like to try and clean up separately from the main body. |
Tony Pratt 1 | 27/06/2022 14:07:30 |
2319 forum posts 13 photos | Please read the thread, your question was answered back in 2015 by Ian Parkin. Tony |
ega | 27/06/2022 14:25:54 |
2805 forum posts 219 photos | FWIW, I have a note of a post by someone here about dismantling Burnerd Multisize collets: "Well my collets certainly dont have that warning on they are quite easy to take to bits once you know how springs off move one leaf at a time into the centre move slightly back to the rear leafs slide out then easy on the larger sizes more difficult on the smaller ones" The "warning" was against dismantling! |
