Cutters
Alan Rawlins26/05/2015 08:46:07
74 forum posts
Is there any reason why the cutting tool on a flycutter is usually a small square section like 1/4" or 5/16" ? Why not a 1/2" or 12mm cutting tool?
Also what is the reason for the main block, that the cutting tool is fastened to, at such a high angle?
Is there an optimum size that the flycutter should be made to? If so what criteria is used to determine this size?
JasonB26/05/2015 09:34:24
Tool size really comes down to head size eg I have a small flycutter with a 3/4" dia head - not much point putting a 1/2" bit into that same with my largest flycutter wich takes a 10mm bit fine but a 4mm sq tool would be lost.
Size would really be based on the size of your mill and area that you want to sweep. Though I have seen 6" disc type flycutters used on quite modest size mills and lathes
Not sure on angle but would have thought any shallower would make it harder to sharpen the tool unless you used a cranked one.
mechman4826/05/2015 10:28:05
2947 forum posts
468 photos
I have one I made some years ago that uses a left hand cranked tool ...
... Home made fly cutter
Homemade fly cutter
Having an MT3 taper it doesn't fit my WM16 now but I have a new one so its not a problem so maybe will alter this for another use.
George.
Capstan Speaking26/05/2015 10:57:13
177 forum posts
14 photos
Posted by Alan Rawlins on 26/05/2015 08:46:07:
The front face of the toolbit is on the centreline so it has limits unless you want a huge unit.
The angle is to give clearance on a square toolbit. You can have flat ones if you use a lathe tool. I have also made one using just a flat disc and two round toolbits held vertically with pinch screws.
Overall diameter will be limited by the torque and minimum speed of your mill.
Jeff Dayman26/05/2015 13:00:15
2356 forum posts
47 photos
Don't make things too heavy on a flycutter. It will be hard on the drivetrain, particularly belts, the heavier it is, when the motor is trying to get things turning.
They're a simple inexpensive tool and when set up right, nothing makes a nicer finish, with less effort then other methods. JD
Phil P26/05/2015 13:10:25
851 forum posts
206 photos
I have tried the conventional types of fly cutter as described above, but the noise in the drive train due to the intermittent cut was unbearable. I have had much more success when the fly cutter is heavier.
I tend to make mine out of a large steel disc, and insert a round HSS or carbide tipped tool bit through a hole in the face near the outer edge, I secure it with a couple of grub screws.
The whole cutter acts as a flywheel, and damps out the intermittent cuts very nicely.
Phil
mark costello 126/05/2015 14:14:56
800 forum posts
16 photos
If You want to grind down a 1/2" tool bit when a 1/4" would do, it's Your choice. Takes longer to grind.
Alan Rawlins26/05/2015 20:11:18
74 forum posts
Perhaps you are correct but my dumpy little fingers find it difficult to hold a 1/4" tool.
Thank you everyone for your input. I will make one and see how it goes, if it goes well I may post a picture of it, when I have sussed out how to.
Vic26/05/2015 20:54:35
3453 forum posts
23 photos
My bought one takes 3/8" bits. I've also made an insert holder for it as well for tough materials.
Alan Rawlins28/05/2015 16:10:33
74 forum posts
Have just been on internet and found this.http://www.ebay.co.uk/itm/3-piece-Fly-Cutter-Set-1-2-034-Shank-/360413450905?_trksid=p2054897.l4275 Is it a misprint, if not what is so special about it?
JasonB28/05/2015 16:18:06
Common practice on e-bay when an item is out of stock to save having to relist it.
I've had a set of those for years and they are what I tend to use for most of my flycutting.
J
