Request from an organisation wishing for an educational model illustrating the workings of a water wheel
Richard Guthrie | 18/05/2015 09:29:22 |
10 forum posts | As one of the contacts shown on the website of the Northern Association of Model Engineers, I received the following email from Bernard Rostron: Dear Richard
Your name came from the Northern Model Engineers website after being directed there by a keen model engineer Mr Derek Bird of Baildon Bradford
I am the Chairman of the Higher Mill Museum Trust at Helmshore, Haslingden.
We have an 18ft dia waterwheel driving the old fulling mill. Our education officer is anxious to create a simple hand operated model which can be used to held school children understand the power of water and how it can be utilised.
We are looking for someone or a model group who might be able to help us.
The model will include a waterwheel - flowing water - simple gears driving a lineshaft. Ideally it will also incorporate pulleys and simple belt drives to show how water created power to drive the production machines.
This will be quite large so that a group of children can gather round and take turns at operating it ~ it will not be a miniature nor will it need to be a scale model. There are some funds available to cover costs
Please will you contact me if you can put me in touch with someone who might be interested
Kindest Regards Bernard Rostron ~ Rochdale
Hopefully someone out there can offer positive assistance,.
Richard Guthrie
EDIT Address, e-mail and phone number removed to save getting spammed, PM Richard for Bernards contact details
Edited By JasonB on 18/05/2015 10:35:52 |
Ady1 | 18/05/2015 10:36:51 |
![]() 6137 forum posts 893 photos | There may also be a shortcut if he wants to try it There were loads of different models in the National Museum of Scotland for example, which I marvelled at as a youngster and waterwheel models were included Tthese models have disappeared as a culture of de-industrialisation sweeps across Britain and they must be stored somewhere Each one was in a big glass case with elevated 360 degree viewing and all us kids did was push a button to watch it work Might be worth calling a few museums to see if they have any going spare |
martin perman | 18/05/2015 10:51:29 |
![]() 2095 forum posts 75 photos | Richard, If the museum is part of the Accreditation scheme or belongs to the Museums Association they print lists of exhibits they wish to dispose of, they are required to find another home for an item they no longer use or display. For instance this website http://www.museumsassociation.org/about/frequently-asked-questions has a section called "search an Object" which shows what it is and whether its up for disposal etc and where it is. A museum I volunteer for acquired some engines from the IWM for instance.
Martin P |
Neil Wyatt | 18/05/2015 11:50:30 |
![]() 19226 forum posts 749 photos 86 articles | Dozens of rugby tickets, a fire hose and a full-size lego mammoth...
Neil |
Ian S C | 18/05/2015 14:13:42 |
![]() 7468 forum posts 230 photos | If it is to be a permanent fixture, one of the first things you need to find out is the water supply, and its elevation, this will help in deciding whether the wheel is over shot, under shot, or a breast wheel. There are so many variations, so some discusion with the museum would be required. This sounds like an interesting project, I'm thinking that if it is required to do the work listed above it might be around 6ft diameter, and 2ft/3ft wide, but would need only a fraction of the water that the 18ft wheel would use. Ian S C |
Bazyle | 18/05/2015 14:56:19 |
![]() 6956 forum posts 229 photos | I'm thinking they don't want a fancy scale model as they have the real thing. They want a distraction that involves small childern doing some of the work to lift the water ( eg in kiddie buckets up some steps) up to a tank and then let it go and see it make things move and do something if only for 30 seconds. The wheel could be mde out of things they can relate to like aluminium drinks cans. Things to operate probably must include a generator and LED to help them appreciate just how much work goes to waste when they leave the light on in the bathroom. Other moving things can be a trip hammer and whatever the full size museum has. You probably don't want to do the work yourself but find A) the nearest model engineerng club to Haslingden, B) advise them to get the nearest school that still has tech capability involved as a charity project. |
Tim Stevens | 18/05/2015 20:43:16 |
![]() 1779 forum posts 1 photos | In terms of 'What can it drive?' they need to realise that this project is at the wrong end of the scale. Tiny aeroplanes work because the weight relies on the cube of the size and the lift on the square. Here the weight of water is the cube bit, so there is no advantage in making it small. So, the output is going to be tiny and the bearings etc need to be super. And water resistant. Could they supply some Mercury instead of the water? No, don't bother to answer that ... Cheers, Tim Edited By Tim Stevens on 18/05/2015 20:43:38 |
Ian S C | 19/05/2015 12:37:50 |
![]() 7468 forum posts 230 photos | Tim, the scale effect is why I suggested the wheel would need to be 6ft or so if it is to drive anything. If for example you wish to drive a generator, it would need to be geared up about 10 :1 to get sufficient rpm, so a fairly small generator. Ian S C |
Bazyle | 19/05/2015 12:50:57 |
![]() 6956 forum posts 229 photos | Outside this national trust preserved forge there is a small water wheel at the front where you can see it from the road. Not part of the original installation but it is a real (as in not a model but an original preserved item) wheel powered pump about 2-3 ft in diameter. You can see it on google street view. Fenced off nowadays but you used to be able to grab it and feel the actual force it was producing. |
mark costello 1 | 19/05/2015 22:08:46 |
![]() 800 forum posts 16 photos | A small grain mill might attract attention. |
