How to clean and lubricate
Malcolm Bannister | 14/05/2015 13:45:01 |
20 forum posts | Hi Guys... I've accquired an old Gents master clock which runs OK but it's a bit mucky. I'm wondering what to use to clean and re-lubricate it. Any ideas would be gratefully accepted. Thanks. Malc
Martin Kyte | 14/05/2015 13:56:01 |
![]() 3445 forum posts 62 photos | Cousins Material House do a handy oiler for clocks. https://www.cousinsuk.com/product/pocket-oiler-multi-purpose I've always has next day service from them. regards Martin |
Swarf, Mostly! | 14/05/2015 16:00:53 |
753 forum posts 80 photos | Hi there, Malcolm, There's a Yahoo Group for Synchronome & other electric master clocks. Best regards, Swarf, Mostly!
Bazyle | 14/05/2015 18:20:49 |
![]() 6956 forum posts 229 photos | Mucky?. Don't use standard ammonia based domestic 'brass cleaners; on clocks as they can cause cracking and corrosion in brass parts a long time later. That's why there are special cleaning products for clocks. Might be an old wives tale as I'm no clock expert but do remember reading that in some old horology books and perhaps ME some time ago. |
john fletcher 1 | 14/05/2015 18:26:52 |
893 forum posts | If you join Vintage Radio. Org there are some experts on Gents and other electric clocks, who will give you a lot of advice.John |
Michael Gilligan | 14/05/2015 21:27:30 |
![]() 23121 forum posts 1360 photos | Posted by Bazyle on 14/05/2015 18:20:49:
Mucky?. Don't use standard ammonia based domestic 'brass cleaners; on clocks as they can cause cracking and corrosion in brass parts a long time later. That's why there are special cleaning products for clocks. . Very true ... but do beware: One of the "classic" clock cleaning fluids [Horolene] is, or was, Ammonia-based and caused exactly this problem [Zinc depletion]. Malcolm: Strip it and clean it first and [to stay on the right side of the enhusiasts]; note that the Gent's version is called Pul-Syn-Etic, not Synchronome; it was a devious bit patent avoidance ... I will leave you to find out the difference MichaelG. |
Malcolm Bannister | 15/05/2015 10:05:03 |
20 forum posts | Thanks Guys... I just used "Synchonome" because I hadn't heard of Pul-Syn-Etic. I stand corrected! I recall from my days as a Lab Techie that ammonia can have nasty effects on copper and its alloys. I'll try IPA or 1-1-1 Trichloroethane, they're both fairly innocuous solvents. I'm beginning to regret scrapping the timer part with the big brass wheel and mercury switches now Thanks for the advice. Malcolm |
Russell Eberhardt | 15/05/2015 11:10:59 |
![]() 2785 forum posts 87 photos | Solvents alone won't remove the tarnishing on brass. Yes, Horolene does contain ammonia but when diluted according to the instructions it is less than 2 %. I can't see there being any long term problem as long as it is rinsed off in hot water after cleaning. Russell. |
Michael Gilligan | 15/05/2015 17:19:47 |
![]() 23121 forum posts 1360 photos | Posted by Russell Eberhardt on 15/05/2015 11:10:59:
Solvents alone won't remove the tarnishing on brass. Yes, Horolene does contain ammonia but when diluted according to the instructions it is less than 2 %. I can't see there being any long term problem as long as it is rinsed off in hot water after cleaning. . Good points made there, Russell Horolene, followed by thorough washing should be fine on modern brass ... The real problem comes with the antique stuff; where the alloy is often less than perfect, and the plates were hand made [no stock sheet available then]; it is very difficult to remove all trace of Ammonia from the microscopic cracks, and any contamination can induce 'stress corrosion'. MichaelG. |
