HUCO Couplings
Roger Guy Owen09/04/2015 12:57:37
1 forum posts
I am building a 9F in 5" gauge. I want to source 2 "HUCO" Couplings with 5 mm plain bushings to fit each end of the reversing rod. How can I source these couplings? Can anybody help me please?
JasonB09/04/2015 13:14:20
Try someone like RS as they do quite a few and several of the online bearing and gear suppliers do UJs
KWIL09/04/2015 14:57:22
3681 forum posts
70 photos
Ondrives, Chesterfield, do a wide range of couplings
Neil Wyatt09/04/2015 17:34:38
19226 forum posts
749 photos
86 articles
Anywhere that sells R/C model boat spares should be able to let you have them off the shelf. You can buy single or double jointed couplings plus brass inserts in various threaded or plain sizes. I have some M4 (spoken for!) that could easily be drilled out to 5mm.
They ain't particularly cheap!
Ian P09/04/2015 19:58:06
2747 forum posts
123 photos
Posted by Roger Guy Owen on 09/04/2015 12:57:37:
I thought Huco was a brand name rather than a type of coupling.
I've no idea what a reversing rod is but I have a assortment of shaft couplings (not all Huco), what is it you actually need?
Ian P
Neil Wyatt09/04/2015 21:35:01
19226 forum posts
749 photos
86 articles
In R/C Huco is synonymous with miniature universal joints, I assumed this was what the O/P wants?
Ian P09/04/2015 21:41:10
2747 forum posts
123 photos
Posted by Neil Wyatt on 09/04/2015 21:35:01:
Well yes, but reversing rods are not often used in the r/c world. The OP I think wanted something for a steam related.
Ian P
stan pearson 109/04/2015 22:34:02
135 forum posts
I am also building a 5" 9F and bought mine from Norman spink now Blackgates took over so they should keep them, the couplings are used on model boat propeller shafts so as said most model shops have them, there not very pretty so I will make my own.
Stan
Trevor Drabble13/04/2015 20:13:39
339 forum posts
7 photos
May I suggest you also try BB Engineering Supplies from Dewsbury on 07976 539675 . He usually has a number of different styles of quality UJ available . Think he also has a presence on Ebay and that he will be at Harrogate in May. I have no connection with Company other than as a satisfied customer .
Michael Gilligan13/04/2015 21:53:40
23121 forum posts
1360 photos
Roger,
To help determine what exactly you are seeking:
... Here is HUCO's 'Coupling Slector'
stan pearson 113/04/2015 22:16:37
135 forum posts
The Huco couplings are nothing like the real thing I still think you are better making your own proper u joints or ring Mike Hewson he does them for the reverser.
Stan
Bazyle13/04/2015 22:29:44
6956 forum posts
229 photos
Not looked at the 9f design but assume instead of a traditional long flat reach rod from the reversing quadrant it has a rotating shaft, hence couplings, to a worm drive on the weightshaft.
It does seem a bit odd that someone who is capable of building an entire 9F would want to stick a couple of commercial bright red (all my boat ones seem to be red) plastic dodahs on it. Something must have got lost in translation. Meccano UJs might be a possibility;.
Michael Gilligan14/04/2015 07:43:54
23121 forum posts
1360 photos
Posted by Bazyle on 13/04/2015 22:29:44:
Bazyle,
I think what's been 'lost in translation' is the fact that Huco is a manufacturer of [amongst other things] shaft couplings, in a wide range of designs.
Specifying a 'HUCO Coupling' without identifying which one, is as meaningless as saying "secure with Loctite" ... and the fact that tatty red plastic universal joints are generically referred to as 'HUCO type" must be frustrating to say the least. [albeit very convenient for the purveyors of tat]
Mike Poole14/04/2015 08:47:08
3676 forum posts
82 photos
The Huco couplings I have encountered are usually to take care of minor shaft misalignment and are backlash free for the drive to encoders or synchros.
Michael Gilligan14/04/2015 08:54:52
23121 forum posts
1360 photos
Posted by Michael Gilligan on 14/04/2015 07:43:54:
added hyperlink ^^^
