Milling machine drilling
Jacob Williams | 04/03/2015 13:46:11 |
![]() 5 forum posts | Hello folks, I'm new to the site/forum and a friend of mine who is an experienced model engineer and he has asked me to find the solution to a problem he has given me . The problem is that I want to drill a 26mm hole in a block of aluminium but the largest size drill bit is 24mm, how can the 26mm be drilled accurately and to the correct size an shape only using a milling machine ? He knows the answer but want me to find the solution and for the life of me I can't figure it out, Any thoughts? kind regards jacob |
Bill Dawes | 04/03/2015 18:05:31 |
605 forum posts | This is an issue frequently encountered. I drill to largest size I can then bore the rest with a boring head I have. On a hobby machine such a boring head is useful but a fiddle as you have to stop the machine and set a new cut after every new traverse through the material thickness, works well enough though. Bill D. |
martin perman | 04/03/2015 18:13:10 |
![]() 2095 forum posts 75 photos | There is another way that I was taught many years ago as an apprentice but it would help if you could sharpen drills by hand and that is to offset the centre of the drill bit when sharpening so that drill will drill oversize, this can only be done if your looking for not to big a hole. Martin P |
jason udall | 04/03/2015 18:36:11 |
2032 forum posts 41 photos | First..your mate has set you this challenge. .. But how to solve this depends on the capabilities of the mill. Cnc? Rotary table.? 26 mm end mill? As has been said.. boring head?... Ahh someone has also suggested miss ground drill... |
jason udall | 04/03/2015 18:40:00 |
2032 forum posts 41 photos | Just read my post above...sorry if it sounds "off"..not meant to be...just have you looked for a solution ..its a bit like someone telling you how the film ends...spoiler. . |
John Stevenson | 04/03/2015 18:44:13 |
![]() 5068 forum posts 3 photos | The critical words are accurately and to the correct size.Only two methods will tick all the boxes, a reamer and boring with a boring head.
However if you want to be pedantic with your friend tell him to hold the block in the spindle and use a cheap lathe boring bar stuck up vertical in the vise, Cut is applied by moving one of the slides. |
pgk pgk | 04/03/2015 19:28:17 |
2661 forum posts 294 photos | ..and if you don't have a boring head or reamer and have to buy stuff then buy a reduced shank 26mm drill bit Actually another way to do it that was demonstarted by toms techniques was to regrind a fly cutter to act as a boring bar. My smallest flycutter is 1 in diameter - so j..u..s..t doable. Or make a smaller flycutter or a one-off boring tool. |
MalcB | 04/03/2015 19:53:39 |
257 forum posts 35 photos | Theoretically, for accuracy and rigidity a microbore boring bar is probably one of your better options. At 24-26mm diameter you should be able to cover the 2mm range required. More rigid than some of the lighter boring heads around, but in practice most would finish with one as these kits which are more affordable and easier to get hold of.
Capstan Speaking | 04/03/2015 20:04:05 |
![]() 177 forum posts 14 photos | Posted by pgk pgk on 04/03/2015 19:28:17:
..and if you don't have a boring head or reamer and have to buy stuff then buy a reduced shank 26mm drill bit Actually another way to do it that was demonstarted by toms techniques was to regrind a fly cutter to act as a boring bar. My smallest flycutter is 1 in diameter - so j..u..s..t doable. Or make a smaller flycutter or a one-off boring tool. Seconded. Without the proper kit, a 12mm bar with a cross-hole, tool bit and a pinch screw. Clumsy, tricky but cheap and simple. It's no jig borer but it could be decent with care. |
Ian S C | 05/03/2015 08:42:01 |
![]() 7468 forum posts 230 photos | I take it from what Jacob says, the job is to be done with the tool at hand, a 24 mm drill, to drill 26 mm. Resharpen with the point 1 mm off centre. The piece will need to be clamped in a vice, and the vice allowed to float. Or, use the drill as a boring bar in the lathe, first drill 24 mm. Maybe no lathe. Ian S C Edited By Ian S C on 05/03/2015 08:44:44 |
