methylated spirits
UJ Newton06/02/2015 16:51:18
23 forum posts
Want to soft solder a meths burner for a very small boiler but am not sure which soft solder to use..Spent long enough on internet to write a thesis on meths !but still dont know what temperature it burns at!
Mike06/02/2015 17:04:13
713 forum posts
6 photos
Try www. stirlingengineforum.com/viewtopic.php?f=1&t=935 . They give the temperature of a meths flame as 1100 degrees C.
UJ Newton06/02/2015 17:34:43
23 forum posts
Crikey,thats warm ..think I might just buy a gas burner ..Thanks Mike
martin perman06/02/2015 17:38:33
2095 forum posts
75 photos
I repair meths stoves for boiling water in kettles and use soft solder, your burner is via a wick I assume so the container shouldnt get that hot.
Martin P
UJ Newton06/02/2015 18:01:35
23 forum posts
Ok Thanks Martin..whichsolder do you use?
martin perman06/02/2015 18:23:12
2095 forum posts
75 photos
Lead sticks and bakers fluid, no idea of grade as it was acquired from my father in laws tools which he left me, I make fuel tanks for my petrol engines without any problems.
Martin P
Neil Wyatt06/02/2015 18:35:26
19226 forum posts
749 photos
86 articles
Flame temperature isn't a good guide to it's actual heating ability. Bear in mind you can pour whisky or brandy on ice cream and burn it without the ice cream melting (why would ANYONE want to burn such things?)
You need a blowpipe to get a meths flame intense enough for even silver soldering the tiniest of items.
UJ Newton06/02/2015 20:33:09
23 forum posts
Ha ha..I burn them..Being in catering I get paid to..Utterley ridiculous!
Glad about meths though..I m sure I cam build burner and tank lot cheaper than buying a gas one..Fumes arent the same either
Neil Wyatt06/02/2015 20:33:44
19226 forum posts
749 photos
86 articles
Just read that properly - this is for the burner NOT the boiler.
I'd suggest using Comsol (286 degrees C) but bear in mind that the evaporating meths will cool the burner and once its all evaporated, there's nothing left to burn.
fizzy06/02/2015 21:03:24
1860 forum posts
121 photos
Come on Neil.......don't you put poison darts into a blow pipe......
UJ Newton06/02/2015 21:05:35
23 forum posts
JohnF06/02/2015 22:24:10
1243 forum posts
202 photos
Hi UJH i would use tin and resin flux or the self cleaning flux used by plumbers, this is slightly acidic so you need to wash of with water when finished, same with killed spirits. You could equally use tin mans solder 60/40 lead/tin but tin flows better and makes a stronger thinner joint. Tin you can buy the "lead free" solder at the plumbers merchant which is near enough pure tin.
