Chris Denton | 18/12/2014 20:35:31 |
275 forum posts | Evening, I need some conical washers, also known as cup & cone washer or spherical washer. M5 size.
Any my ideas where to get them, as I can't find them! |
Phil Whitley | 18/12/2014 20:55:10 |
![]() 1533 forum posts 147 photos | If you do a google search on M5 conical washers you will find a wide variety of suppliers and types of washers. Any industrial fastner stockist will have these, or know where to get them. We have one in Kingston upon Hull called F R Scott, who are very good, depends where you are in the country and what metal they need to be made of. Phil. |
Chris Denton | 18/12/2014 21:11:07 |
275 forum posts | It's this type that I'm after: http://www.orthopedic-implants.net/images-parts/conical-washer-1.jpg
Still unable to find any on google in the UK? |
pgk pgk | 18/12/2014 22:07:20 |
2661 forum posts 294 photos | If it's for orthopaedic purposes then they are a specific stainless composition. Unlikely that is your intent when posting here but you could always call veterinary instrumentation - if they haven't got them they can always point you where. Not that I immediately figure what they are used for. Dynamic compression plates have an interesting grooved slot for each hole which matches to conical head screws placed neutrally or loading for compression rather than using screws needing a conical washer. But ortho stuff usually jumps from 4.5mm to 6mm. |
Chris Denton | 18/12/2014 22:18:23 |
275 forum posts | Just an example picture. I just need the cup and cone function, not for orthopaedic purposes! |
Michael Gilligan | 18/12/2014 22:20:55 |
![]() 23121 forum posts 1360 photos | Chris, It may be time to indulge in some pedantry ... Despite the description, that looks more like a spherical washer arrangement, than conical one. ... maybe you would get better UK results by searching for spherical. MichaelG. Edit: This might be a good place to start looking. Edit: Apologies Chris ... I've just noticed that you did mention 'spherical" in your opening post. . Edited By Michael Gilligan on 18/12/2014 22:21:57 Edited By Michael Gilligan on 18/12/2014 22:24:59 Edited By Michael Gilligan on 18/12/2014 22:34:37 |
Keith Long | 18/12/2014 22:26:22 |
883 forum posts 11 photos | WDS - **LINK** - first hit on the search term "M5 spherical washer" starts at M4 and 2BA Edited By Keith Long on 18/12/2014 22:26:43 |
GoCreate | 18/12/2014 22:31:28 |
![]() 387 forum posts 119 photos | From google search
Nigel Edited By tractionengine42 on 18/12/2014 22:33:58 |
mechman48 | 19/12/2014 22:56:11 |
![]() 2947 forum posts 468 photos | If you're looking for compression ability try... George.
Vic | 20/12/2014 10:00:39 |
3453 forum posts 23 photos | You beat me to it George. The correct name is indeed Belleville Washer. The only reason I know this is that they are used in some Airgun Regulators. |
Chris Denton | 20/12/2014 10:27:00 |
275 forum posts | Thanks for the replies. I contacted one of the companies about minimum quantities and postage costs etc but got no reply.
Its probably easier to make my own I've realised, so I bought a 9mm ball end cutter and will make the other convex part on the lathe as I only need a couple of them.
Thanks. |
