Cross slide handle
how to remove it
Robin teslar06/11/2014 22:30:24
127 forum posts
8 photos
Seems a daft question, but I cant see how the handle is secured to the cross slide lead screw. There are no obvious pins or grub screws, just solid metal. If it were just screwed onto the shaft then , even with a lock nut , it would tend to come unscrewed with use
Anyone any ideas?
Robin
Michael Gilligan06/11/2014 22:38:37
23121 forum posts
1360 photos
Robin,
Here is a picture of the rather battered example on my recently purchased ML7-R
Just remove the Ball Handle and then unscrew the Dial.
p1180382_s.jpgMichaelG.
Martin W06/11/2014 23:25:46
940 forum posts
30 photos
Michael
I think that Robin was asking how to remove the handle as there are no obvious retaining fixings frown. Unfortunately I can't help as I don't own a Myford.
Cheers
Martin
Robbo06/11/2014 23:38:42
1504 forum posts
142 photos
Robin,
Are we talking about a Myford ML7? You don't say in title or OP.
But if so, then put a spanner on the flats of the Dial, and unscrew the handle, usual way.
Robin teslar06/11/2014 23:47:50
127 forum posts
8 photos
Posted by Robbo on 06/11/2014 23:38:42:
Robin,
Well thanks for the tip, yes ML7 I didnt expect the mechanism to be so crude and that dial is pretty naff
In my machine shop years, I always worked on much bigger machines and never gave this trivia any thought
With an ML7 you have to be creative in unexpected ways
Cheers
Robin
Chris Trice07/11/2014 01:30:43
1376 forum posts
10 photos
I converted the handle on the cross slide of my ML10 to a Super7 type and converted a Super7 topslide to fit the ML10 cross slide so both feedscrews have resettable Super7 style index dials. Much nicer to use. I also made a reduction gearbox (2.5 to 1) to reduce the gearing on the ML10 saddle handle to match the saddle travel of a Super7.
Michael Gilligan07/11/2014 08:02:25
23121 forum posts
1360 photos
Posted by Martin W on 06/11/2014 23:25:46:
Michael
Fair comment Martin ... it had been a rather tiring day.
The Ball Handle and the Dial just act as locknuts for each other.
ergo ... apply spanner to flats on Dial to hold it still; then unscrew the Ball Handle [yes, it's a right hand thread]
Edited By Michael Gilligan on 07/11/2014 08:05:15
Neil Wyatt07/11/2014 08:25:54
19226 forum posts
749 photos
86 articles
I wonder if you could upgrade by fitting the dial off a mini-lathe?
devil
Michael Gilligan07/11/2014 08:34:50
23121 forum posts
1360 photos
Posted by Neil Wyatt on 07/11/2014 08:25:54:
devil
Naughty, Neil
... but there's many a true word < etc.>
Bazyle07/11/2014 09:20:34
6956 forum posts
229 photos
At least you have a dial which some small lathes did not have from new. No need for one off a minilathe as hey you've got a lathe so make one. Remaining question is whether you have the wit to design one or need help there.
For general information there are a few machine tools where the securing screw goes all the way down from the ball end so might be overlooked as not seeming to be connected.
Neil Wyatt07/11/2014 09:55:20
19226 forum posts
749 photos
86 articles
To be serious, for a moment, George Thomas designed both adjustable dials and a geared arrangement for the Myford topslide (in the Model Engineers' Workshop Manual).
You could modify the latter to use a suitable gear ratio so that it has very convenient and accurate number of divisions.
Michael Gilligan07/11/2014 10:51:53
23121 forum posts
1360 photos
Neil,
I realise that they overlap, but: Your last post might be more relevant to Robin's other thread.
Enough!07/11/2014 18:18:31
1719 forum posts
See my post in Robin's "Cross Slide Micrometer Wheel" thread (actually mine was from a mini-mill) .... cheap, easy to implement and it's resettable (which I forgot to mention).
Nick Hughes07/11/2014 20:18:28
307 forum posts
150 photos
From the Myford Ltd website:- **LINK** . Also available in metric and they fit the small vertical slides (That's what I've used them on).
Gordon A07/11/2014 23:34:33
157 forum posts
4 photos
Would this item on "the bay" be suitable? No. 321545610372
Gordon.
