I felt that it was necessary to close off the threads I created some months ago, by offering the following information.
Sam Stones | 26/10/2014 21:57:53 |
![]() 922 forum posts 332 photos |
Now that I have a decent steel wire drive between the main-spring barrel and the fusee, I found myself pondering over the possibility of setting the balance wheel screws to improve the clock’s timing. As reported before, my version of John Stevens’ skeleton clock has several issues of time-keeping. My very simple attempts at torque measurement revealed the cause of poor time-keeping. Although crude, they provided enough information to show a distinct fusee inaccuracy, a situation which I’m no longer in a position to rectify. A few months ago however, I commenced a series of tests and adjustments, and graphed the results. My final plot below illustrates two factors. The heavy line displays daily errors. I took these at 5 am each morning based upon the assumption that they were perhaps the least affected by (Melbourne’s) ambient temperature variations. I was not serious enough to collect night-time readings. The caterpillars crawling up and down the slopes are the results of hourly daytime variations. Given that the fusee does not accurately compensate for the varying output torque of the main spring, my intention was to set the timing screws on the balance wheel to the best compromise. After several weeks of timing tests and adjustments, I believe that I have set the mass of the balance wheel to the best compromise. Here are my observations:
Until about day 6 or 7, the balance wheel arc (swing) appears to remain fairly constant.
My conclusions.
I shall now be content to wind the clock when it needs it, and set the fingers to the appropriate time. Best regards to everyone. Sam (aka Dennis) Stones Melbourne
john jennings 1 | 27/10/2014 14:40:49 |
69 forum posts | You may have explored all below to the point of insanity - apologies if so! "Given that the fusee does not accurately compensate for the varying output torque of the main spring" In principal that is what fusees do, If your drive force is varying so as to affect the rate of the timepiece there are two likely causes. One.: The profile of the fusee helix is wrong or does not match the properties of the spring. Is the profile you used a published one or is it made up or derived in some way? Trying another profile may be an answer but would involve much time and effort. Two: The fusee is suitable/correct but the mainspring and fusee need setting up. Basically this involves altering the amount of spring still wound when the stop work is in its fully down position. This tuning should get a better fusee action and constancy of torque. You also conclude that the escapement is very sensitive to driving force. This worries me as the escapement is supposed to ration the unwinding of the mainspring with a time dependent element. . Now an increase in driving force by a well positioned finger on the driving train will cause a speed change. It shouldn't cause the train to free wheel. If your train is seriously sensitive it would appear to be effectively a freewheeling set up and not a time latched/unlatched process. Is your escape wheel and its pallets adequately depthed ? Does the escape wheel bounce (recoil) or stop (deadbeat) or dribble round ? This may be difficult to observe with a lever escape which appears to be used. John
Sam Stones | 27/10/2014 23:14:40 |
![]() 922 forum posts 332 photos | Hi John, Many thanks for your prompt reply. There is certainly no need to apologise. If anything, I must apologise for failing to provide references to previous postings on this subject. A scan of the relevant threads reveals that I spawned (or contributed to), no less than twenty (20) which are either relate directly or are slightly off topic with this skeleton clock. I would be quite happy to lump the references together in chronological order if it would help. Here are a couple of pictures from my albums to start with - The main-spring output was determined by calculation using the (approximate) radii measured off the fusee. A sort of inverse determination. In answer to your question - “Is the profile you used a published one or is it made up or derived in some way?” Yes. It was a 2” radius profile, taken directly from the drawing thus – For various reasons John, I’m no longer in a position to alter the fusee profile. In terms of setting up the fusee and main spring, I fear that their combination fails to provide useful `access’ to the so-called spring flat-spot. In other words, up to the point when the stop-work lever `kicks in’, the main spring is almost completely wound. Adding any more clicks to the barrel ratchet fully winds the spring, and the stop-work mechanism doesn’t engage. Removing barrel clicks and the clock stops before all of the fusee line has been used up. At the start of day 8, the arc (swing) of the balance wheel decreases, and the clock speeds up. See the dotted line between day 8 and day 9 on my graph. John, I’m don’t understand your statements - . . . the escapement is supposed to ration the unwinding of the mainspring with a time dependent element. or Now an increase in driving force by a well positioned finger on the driving train will cause a speed change. It shouldn't cause the train to free wheel. If your train is seriously sensitive it would appear to be effectively a freewheeling set up and not a time latched/unlatched process. Applying extra driving force causes the balance wheel to spin through an increasing arc until the impulse pin travels around far enough to strike the outer edge of the escapement lever. I would need to understand what freewheeling means in this context. Finally, from what I can see of the escapement wheel (under low power magnification), it appears to lock with no detectable twitching. As for adequate depth, I estimate about 0.01” (0.25 mm) for both entry and exit pallets. The geometry of the escapement as a whole, conforms well with the drawings, as far as I can tell. I would welcome your further comments. Regards, Sam Edited By Sam Stones on 27/10/2014 23:16:25 |
Sam Stones | 27/10/2014 23:29:15 |
![]() 922 forum posts 332 photos | I'm back again after suddenly realising that my torque measurements carried out two or three years ago, don't tally with the eight-day clock rate variations. So what has changed?
Do these throw any extra light on the subject? Regards, Sam |
Michael Gilligan | 28/10/2014 08:24:25 |
![]() 23121 forum posts 1360 photos | Sam, I am more than happy to simply "observe" the expert discussion between John and yourself, but [from what little I understand of fusee action], I suspect that items (2) and (3) will have had quite significant effects. MichaelG. |
jason udall | 28/10/2014 08:42:01 |
2032 forum posts 41 photos | Having no experience in clock design.. An observation. . When a system has a non linear behaviour. ..when you need linear or even constant..it is not unusual to limit the scope to the linear portion of the graph...think using say only two thirds of spring travel... Like using only the center portion of a lense.. |
Neil Wyatt | 28/10/2014 10:52:00 |
![]() 19226 forum posts 749 photos 86 articles | > .think using say only two thirds of spring travel... I think this is what Sam means when he says the combination he has fails to provide access to the 'so called spring flat spot'. Neil |
Sam Stones | 28/10/2014 21:16:42 |
![]() 922 forum posts 332 photos | My thanks to John, Michael, Jason, and Neil for their contributions. As for an `expert discussion’ Michael, I’m still learning. John (Jennings 1) is clearly the leader. Although it defeats the `eight-day’ objective, I have pondered whether to wind the clock more frequently, choosing start and stop positions appropriate to the `best’ overall results. Without changing the rate, my choices (as has been suggested) would be as per the graph here:- In other words, using the first two thirds of the wind from just under fully wound to about two thirds (roughly five days). My other simpler option would be to wind the clock when it needs to be wound, and reset the fingers. Regards, Sam |
Michael Gilligan | 28/10/2014 22:02:06 |
![]() 23121 forum posts 1360 photos | Sam, I am way out of my depth here [my particular interest being electro-mechanical clocks], but I think it worth noting that the fusee in the drawing is only a circular approximation to the likely profile. ... A parabolic curve [or thereabouts] is, I believe, normally used. Matching the fusee curve to a real spring is, apparently, a long and tedious job [and one I have never done]. You may find this description worth reading. MichaelG. |
Sam Stones | 29/10/2014 03:28:01 |
![]() 922 forum posts 332 photos | Thank you Michael, At four score next year, I must say "That's a weighty piece of literature!" |
Sam Stones | 29/10/2014 03:28:03 |
![]() 922 forum posts 332 photos | Thank you Michael, At four score next year, I must say "That's a weighty piece of literature!" With my long-gone workshop; another lump of brass; and a guaranteed 12 months of uninterrupted effort, I think I could just manage a new fusee or two. Perhaps I should have gone the electronics route? Regards, Sam
Edited By Sam Stones on 29/10/2014 03:33:31 |
Michael Gilligan | 29/10/2014 07:44:25 |
![]() 23121 forum posts 1360 photos | Sam, Your clock is a lovely piece of work I would just treat it as a beautiful mechanical sculpture [safe in the knowledge that it could be made to run more consistently if needs be]. Wind it once a week, and re-set the hands to GPS [or whatever reference you prefer] when you feel so inclined ... being sure to take a few moments to savour what you have created. MichaelG. |
OuBallie | 29/10/2014 08:50:48 |
![]() 1181 forum posts 669 photos | Well said MichaelG. I take my hat off to you Sam! Geoff - A 'WhooHoo' post from me shortly |
Neil Wyatt | 29/10/2014 10:58:55 |
![]() 19226 forum posts 749 photos 86 articles | Indeed stop fretting, be content with a clock that is exactly right four times a week, most are only right once or twice. Neil |
Gordon W | 29/10/2014 11:44:13 |
2011 forum posts | My old clock is right twice a day, it has stopped.. Very old joke. |
