cap or not cap!
jonathon cary | 27/09/2014 12:12:11 |
44 forum posts | I want to buy a 1/2 hp motor for 2 elderly motorless small machines I have but am not sure which..Either a Clarkes which is about £110 or other new ones on ebay which are capcitor start and run for about £70.Wondered if the latter tupe would be ok and last a while..I know cap run types are used in washing machines so should be adequate for my light use..Thank you |
jonathon cary | 27/09/2014 12:14:58 |
44 forum posts | my phone types all sorts for ? signs! |
jonathon cary | 27/09/2014 12:15:55 |
44 forum posts | pounds sterling |
Les Jones 1 | 27/09/2014 17:29:35 |
2292 forum posts 159 photos | Hi Jonathon, Les. |
Phil Whitley | 27/09/2014 17:44:20 |
![]() 1533 forum posts 147 photos | I would pop down to the local electrical engineers or rewinders, they will probably sell you a British made 1/2 hp for about £25 to £50 second hand, far bttr bet than italian or chinese. I have noticed that some of the Clarke motors hum very loudly which is a clear indication of a poorly wound and therefore inneficient motor. Phil |
Ian S C | 28/09/2014 09:43:35 |
![]() 7468 forum posts 230 photos | All the old wringer type washing machines had either 1/4 or 1/3hp induction motors, split phase ie. no capacitor. The Hoover Twin Tub of the same era had universal motors. Here in NZ, if you pay more than $NZ25 you'r being ripped off for an old 1/4hp motor. If there is a bit of a load to start against maybe cap start would help, but I run my wood lathe on a 2/3hp split phase motor ex an old petrol bowser (it's flame proof). Ian S C |
jonathon cary | 28/09/2014 13:54:20 |
44 forum posts | Thank you for the info Phil..Clarkes/Machinemarts need a starter which is ?25 extra..Tec is what I was looking at and most likely.. A local electrical engineer who can rewind motors could be difficult to find around Cambridge, No one here but great thinkers! I hope i never need it fireproofing!! |
martin perman | 28/09/2014 14:04:38 |
![]() 2095 forum posts 75 photos | Try here http://electricmotorservices.co.uk/index.php?region=cambridge or herehttp://www.cambridgerewinds.co.uk/ |
Neil Wyatt | 28/09/2014 14:20:52 |
![]() 19226 forum posts 749 photos 86 articles | FWIW I have a 3-phase 1/2 HP Tec from Transwave on my lathe and it's smooth as silk. Neil |
Les Jones 1 | 28/09/2014 14:58:54 |
jonathon cary | 28/09/2014 17:59:09 |
44 forum posts | Hallo Martin.Didnt see you at Haddenham this year.. |
martin perman | 28/09/2014 18:04:16 |
![]() 2095 forum posts 75 photos | I was there with my Lister A, not in the main area as when I turned up early Friday morning there was no longer any space so I and others were put between the Rally office and Craft tent. Martin P
daveb | 28/09/2014 18:15:47 |
631 forum posts 14 photos | The motor starter from Machine Mart does not have no volt release, it's just a push button switch with (perhaps) a thermal trip. Tool Station stocks reasonably priced DOL starters and overloads, the case and insides are fine but the moulded push buttons are a bit fragile. |
jonathon cary | 28/09/2014 18:42:11 |
44 forum posts | glad I found this forum.With my electrical knowledge I d have put a plug on it and,well, plugged it in ![]() |
Les Jones 1 | 28/09/2014 20:14:23 |
jonathon cary | 29/09/2014 01:17:13 |
44 forum posts | Thanks Les..1/4 may be a bit small..I m looking ahead..Ordered a 1/2 hp TEC ..DOL starters seem reasonable price so should be ok..Thank you everyone I did nt look that far for stationary engines Martin.I will next year ,hate missing any |
Chris Denton | 29/09/2014 17:01:43 |
275 forum posts | www.inverterdrive.com are good for motors. Edited By Chris Denton on 29/09/2014 17:02:08 |
Howard Lewis | 30/09/2014 16:59:44 |
7227 forum posts 21 photos | Jonathon, If you are in Cambridge, UK, you might like to contact Shoebridges in Stanground, Peterborough. They rewind and repair motors, and so could help, if only with advice. And they are about forty miles away. They got me out of trouble, saving buying a new motor, when I thought that the motor on my Myford had gone west. Howard |
jonathon cary | 30/09/2014 18:09:57 |
44 forum posts | motor arrived but no starter yet..Having found the cheapest one at ?39 I m not buying one! If I have to I ll take the mitor out of our old Henry(hoover!) and use that until I feel rich again(again!) Is there something unpleasant or dangerous happens to motors which dont use starters..would a low power circuit breaker help? ?Henry never had one.. |
Neil Wyatt | 30/09/2014 18:37:19 |
![]() 19226 forum posts 749 photos 86 articles | Hi Jonathon, The function of starters as 'stoppers' is perhaps more important than as starters. Their 'no-voltage release' safety function is to stop the machine starting on its own when power is reapplied, obviously the potential; for destruction and mayhem is much less with a vacuum cleaner than a lathe. Neil |
