Dusty | 02/04/2015 20:25:19 |
498 forum posts 9 photos | Having located my long lost grill grinding jig I thought now I can get on and modify it according to Graham Meek's posting. What do I find, it has been spirited away, that is unless I have been looking in the wrong place. My drawer full of drills needing grinding will now have to wait untill I need to use them, that is unless one of you guys has the details. I do have a rough idea of the modifications but it would help if I could see the original post. |
JasonB | 02/04/2015 20:28:00 |
![]() 25215 forum posts 3105 photos 1 articles | Its on the Web, PM about to be sent |
Dusty | 02/04/2015 20:34:48 |
498 forum posts 9 photos | Jason, your a hero, many thanks. should keep me out of mischief for the next couple of weeks. |
JasonB | 02/04/2015 20:36:18 |
![]() 25215 forum posts 3105 photos 1 articles | Just sent you another link |
capnahab | 02/04/2015 22:22:07 |
194 forum posts 17 photos | sorry to abuse your goodwill Jason, Please can you send me a link too. |
Dusty | 03/04/2015 11:17:51 |
498 forum posts 9 photos | Many thanks Jason, the one thing I need and which is not shown in either of the links is the ofset in the large dia pivot for the pivot pin. I suspect that it is in the order of 1/4" or 6mm, if anyone can remember I would be most grateful, the rest I am quite comfortable with. |
Dusty | 03/04/2015 11:22:42 |
498 forum posts 9 photos | Non so blind as them that can't see. When you open your eyes all is revealed, or you read instead of skimming it is according to Gray 5mm or thereabouts. |
Doubletop | 04/04/2015 11:30:10 |
![]() 439 forum posts 4 photos | I arrived here expecting to finally have the answer to how to use the 'attachment' that came with my U2 Chinese knock off Deckel tool and cutter grinder to find a reference to a post that doesn't exist and 8 pages that don't appear provide the information either. Jason - if you could PM the missing part please, it would be appreciated? I may then be able to make some sense of the other 8 pages. Why is it missing anyway? I'll add that not having understandable instructions for the U2. For my larger drill sizes I used the instructions for 4 facet drill grinding for the Quorn and found them to be far superior to the original grind. However, being able to use the 'attachment' would be preferable for the smaller sizes. Pete |
Tony Pratt 1 | 04/04/2015 11:49:41 |
2319 forum posts 13 photos | I for one can't understand the reason behind deleting posts which were put on by a 'former member', it makes no sense and isn't the first time it has happened. Tony |
KWIL | 04/04/2015 12:15:17 |
3681 forum posts 70 photos | Conflict of Magazine publishing interest I suspect, apart from the hurtful comments made at the time. |
Neil Wyatt | 04/04/2015 12:41:46 |
![]() 19226 forum posts 749 photos 86 articles | Posts are only removed if they break forum rules or at the request of the poster, which may be for any of several legitimate reasons. Neil |
Neil Lickfold | 05/04/2015 23:08:22 |
1025 forum posts 204 photos | So, what is the geometry that allows a drill to be able to drill 1000's of holes ? Are there any pictures for this geometry ? Neil |
Neil Wyatt | 06/04/2015 12:39:13 |
![]() 19226 forum posts 749 photos 86 articles | 4-facet drill geometry is very good,. Wait a few weeks for the 25 Years of MEW special and you may be rewarded Neil |
JasonB | 06/04/2015 13:06:09 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Neil Wyatt on 06/04/2015 12:39:13:
4-facet drill geometry is very good,. Wait a few weeks for the 25 Years of MEW special and you may be rewarded Neil What a free set of 4-facet drills as a gift with each copy |
Doubletop | 10/04/2015 22:49:22 |
![]() 439 forum posts 4 photos | This thread got me searching again for some better instructions for my Chinese Deckel SO clone. Success! if you've got one search Yahoo groups for the Quorn group sign up for the Quorn3 group (other than) and check out the files section. Its clear to me now that the Chinese translated the Deckel SO manual into Chinese and then it was re-translated back into English. My machine came with a Chinese manual, I can't read it but the relationship is clear. If you've got a copy of the English manual available on the RGD site you can see the same errors that have crept into the Chinese version in the original translation. (e.g. paragraph breaks, '13' should be 13deg etc) Anyway it all makes sense now, and the instructions match the diagram with the control labels. Now to get my drill grinding attachment to do something sensible and then see if Graham's improvements can be accommodated. Pete |
John Stevenson | 10/04/2015 23:05:52 |
![]() 5068 forum posts 3 photos | Biggest problem with the Chinese clones is they are advertised as a tool and cutter grinder when they are not.
They are a single lip cutter grinder made for regrinding and making engraving cutters for the Deckel and Alexander engraving machines.
At this task they exceed very well, at tool and cutter grinding they suck.
The main reason being is that an engraving cutter is ground on the left hand side of the cutter as it points away from you. A milling cutter is ground on the right. On the Clones the wheel is on the left of the cutter and you have to jump thru hoops to get the wheel on the right hand side of a milling cutter. This is not sour grapes, I have one and have spent ages trying to regrind various general cutters with it. Not saying it's impossible to use but it's about as intuitive as using a mill stone.
However it makes a brilliant job of grinding engraving cutters which ironically is what the original was designed for. Long, short, Deckel and Alexandra never advertised this as a tool and cutter grinder. |
Doubletop | 11/04/2015 02:47:11 |
![]() 439 forum posts 4 photos | John Agreed, I've a limited success on sharpening milling cutters as well. However, I'm interested in getting the drill sharpening attachment to do something sensible. as I've a growing stock of blunt drills that need dealing with. The instructions to hand until yesterday were far from intuitive but now there's a chance of success and even better if Graham's tips can be applied. Pete |
capnahab | 12/04/2015 13:10:08 |
So I have the picador setup as shown. Having read some of Harold Hall 'tool and cutter grinding' (Most excellent and highly recommendable imho) I agree the drill is too far out. Even correcting this I have trouble with the secondary relief which is so bad that it leads the cutting edge and rubs on the workpiece. I am not sure how to correct . The drill is a chinese one from Costco to try , HSS and when sharp is surprisingly good. Edited By capnahab on 12/04/2015 13:10:55 |
Tony Pratt 1 | 12/04/2015 13:34:28 |
2319 forum posts 13 photos | Hi Capnahab, You have the drill sticking out way too far! Try bringing it back in and you should see the geometry change. Tony |
capnahab | 12/04/2015 13:56:55 |
194 forum posts 17 photos | Sorry Tony , Perhaps I didn't make it clear, Yes after reading Harold I corrected that and went to having the drill protruding about 1/16 as per the box instructions. The pictures of the drill are after that . Edited By capnahab on 12/04/2015 13:57:07 Edited By capnahab on 12/04/2015 14:01:36 |
