Not a good idea - or is it?
Ajohnw | 07/10/2016 16:01:33 |
3631 forum posts 160 photos |
Interesting site. Weldon run out 3um. Best ER collets and best chuck 3um if you buy 2um collets. I can't find the item in the photo - where is ut ? John - |
Martin Kyte | 07/10/2016 16:04:34 |
![]() 3445 forum posts 62 photos | No, just stuck the 2morse in the lathe mandrel and an used a DTI on a milling cutter shank held in the jaws. Martin |
Roy M | 07/10/2016 17:48:53 |
104 forum posts 7 photos | John, from WNT home page, go to tool holders---rotating tools---- micro precision collets. Hope this helps. I used to deal with them until about 4 months ago. If you can get onto their site proper, there is masses of info on everything you need to know about machining, hope this helps. Roy. Just a thought, for all those interested, the flat on the cutter shank is positioned so that it is not directly opposite a cutting flute. This effectively reduces the cutter run out. Edited By Roy M on 07/10/2016 18:07:43 |
JasonB | 07/10/2016 20:07:43 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Roy M on 07/10/2016 17:48:53:
Just a thought, for all those interested, the flat on the cutter shank is positioned so that it is not directly opposite a cutting flute. This effectively reduces the cutter run out. Edited By Roy M on 07/10/2016 18:07:43 How would that work if you are using the side of teh cutter where the flute follows a helix around the tool? |
Roy M | 07/10/2016 20:40:04 |
104 forum posts 7 photos | JasonB, I'm not sure that the flutes always go around the tool, especially on a two flute slot drill. If you would like to try clamping the cutter in a different position I'm confident you will see a difference. If you are working to less than .003 mm on a home mill, I guess it would be quite important. I suppose it just follows the same logic as positioning the drill correctly in the lathe tail stock chuck. Roy M. |
Emgee | 07/10/2016 20:53:05 |
2610 forum posts 312 photos | Hi Roy M Please advise on fitting a drill correctly in the tailstock chuck. Emgee |
Roy M | 07/10/2016 22:10:14 |
104 forum posts 7 photos | Emgee, the cutting edges of the drill should be set vertically, so that any mis-alignment in the 'y' direction(which is adjustable) is minimised, this in turn assists the drill to cut size and true. Roy M |
Hopper | 07/10/2016 23:47:00 |
![]() 7881 forum posts 397 photos | Posted by Ian S C on 07/10/2016 10:48:12:
Hopper, when I first started with my mill, using a Jacobs chuck, the chuck was held to the MT3 arbor by a JT 6 taper, it was the MT 3 taper that let go. The JT taper is designed to be semi permanent, unlike the MT taper that is designed to be removed from it;s socket. Ian S C Silly me, I had assumed anyone milling with a drill chuck would have a draw bolt in place to hold the Morse taper end in place. |
Emgee | 08/10/2016 09:26:11 |
2610 forum posts 312 photos | Thanks for the tip Roy M will keep it in mind, you mention Y axis in your reply but on my lathe the axis are referred to as X and Z, the latter being traverse from tailstock to chuck so I believe your Y is my X ? Emgee |
Ian S C | 08/10/2016 12:47:42 |
![]() 7468 forum posts 230 photos | Hopper, it was before the days of forums like this one, I had the machine with only a Jacobs chuck, I had a 1/4" end mill, so you just get milling, no one to tell me not too, but I soon learned. At that time I had never heard of a draw bar. Ian S C |
