Not a good idea - or is it?
JasonB | 06/10/2016 14:50:19 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Ajohnw on 06/10/2016 13:37:03:
Posted by JasonB on 06/10/2016 13:34:13:
Or a thread for people who again don't read the posts and refer to the wrong magazine
John - But if you read the first post you would have known what Mag it was in |
Another JohnS | 06/10/2016 15:10:02 |
842 forum posts 56 photos | Re: End mill holder wear; Googled and found the following link. Forrest Addy is well known in at least North America, and I believe, well regarded. He starts the following link: I'm just the messenger; professional machinists I used to work with (scientific instrument/device makers) put me on to the end mill holder issue. The googled link above may explain holder/collet wear in a clear manner. Anyway, just FYI, comments welcome. John. |
Michael Gilligan | 06/10/2016 15:17:29 |
![]() 23121 forum posts 1360 photos | Posted by Martin Kyte on 06/10/2016 13:57:19:
"That's awful, I'd expect any decent milling chuck to be less than a thou TIR, and preferably only a few tenths. Andrew" Totally agree Andrew, I was a little surprised myself. I would have expected better from a Jacobs. Martin . Now I'm really confused, Martin MichaelG. |
Muzzer | 06/10/2016 15:19:52 |
![]() 2904 forum posts 448 photos | There's a torrent of chaff going on here. But put simply, if your chip load (radial cut per tooth) is going to be in the region of 1-4 thous and your TIR is 4 thous, all the cutting will be done by one tooth. If you do that with a small diameter cutter in a typical hobby machine, it may work out expensive (breakages). With a bigger cutter it may simply cut oversize noisily before the cutter works its way out of the chuck. This isn't about safety or chucks falling off tapers. How many posters here have actually measured the TIR at the cutting edge on their machines before commenting? <almost complete silence>. I suspect the 4 thou quoted earlier may be relatively good. |
Martin Kyte | 06/10/2016 15:26:10 |
![]() 3445 forum posts 62 photos | Don't see why you are confused. 1. I just cannot imagine breaking an end mill with 4thou runout. 2. I thought Jacobs chucks were better than that and I suspect most are. 3. If needs must hold milling cutters in a Jacobs rather than doing it properly, you already expect sub-optimum performance. So you must have had a sensible reason for doing it in the first place (Like producing a counter-bore or getting in somewhere to clean up a casting with a ball nose). It really is not normal practice but we all stretch a point now and again. regards Martin |
MW | 06/10/2016 16:00:13 |
![]() 2052 forum posts 56 photos | Posted by John Alexander Stewart on 06/10/2016 15:10:02:
Re: End mill holder wear; Googled and found the following link. Forrest Addy is well known in at least North America, and I believe, well regarded. He starts the following link: I'm just the messenger; professional machinists I used to work with (scientific instrument/device makers) put me on to the end mill holder issue. The googled link above may explain holder/collet wear in a clear manner. Anyway, just FYI, comments welcome. John. I do agree that to take very heavy cuts or use big (more than 1/2" ) cutters in a weldon shank endmill holder probably isn't a good idea, not even the makers of these things would condone that, hence why they don't generally go over that size. You wouldn't catch me dead holding a 7/8" cutter in an end mill holder, no way josé! I would always use a collet or drawbar taper type for that. Like he said, it's a compromise, but then they are relatively easy to make and will sufficiently hold 1/4" cutters nicely for a good long while, provided you don't offend or abuse the above stated. Michael W Edited By Michael Walters on 06/10/2016 16:00:28 |
JasonB | 06/10/2016 16:05:25 |
![]() 25215 forum posts 3105 photos 1 articles | I don't know Michael, these Weldon holders seem to go upto 40mm dia and are good for 25,000rpm I've got some 3/4" shank weldon type cutters which cut 1" dia ok |
Ajohnw | 06/10/2016 17:34:42 |
3631 forum posts 160 photos | Posted by JasonB on 06/10/2016 16:05:25:
My understand is that when power transfer is needed they are the best. Nice and simple too so less tolerance build up another plus at any size. The link isn't a blank end arbour with a hole reamed or bored in it though. Things do wear out too, even collets. On the basis I would say BS to the link. John - John - |
MW | 06/10/2016 17:45:41 |
![]() 2052 forum posts 56 photos | Posted by JasonB on 06/10/2016 16:05:25:
I don't know Michael, these Weldon holders seem to go upto 40mm dia and are good for 25,000rpm I've got some 3/4" shank weldon type cutters which cut 1" dia ok I stand corrected, i assumed they were only a remedial kind of workshop build for small cutters but clearly even some swish looking ones with big sizes are about! Michael W |
JasonB | 06/10/2016 18:29:43 |
![]() 25215 forum posts 3105 photos 1 articles | I thought you would have come across them Michael, as someone who teaches others to use CNC machines. These are often used on auto change tool holders on CNC machines |
Roy M | 06/10/2016 18:56:49 |
104 forum posts 7 photos | John Alexander Stewart . Ref end mill holder wear. I noticed the date on the link. 2001. It is worth mentioning that the design in cutting tools and tool-holding has progressed enormously in the last 15 years. Even the concept of taking big cuts with big cutters has been re-evaluated, spindle speeds of 20,000 Rev/min were in the infancy back then and now are common place in newly equipped machine shops. Cutting forces have been reduced by improved cutter geometry. Also no mention was made of shrink fit tool holding. ( just more 'stuff' to scramble the brain!). Hope this gives you a new line for research, Roy M. |
MW | 06/10/2016 19:14:42 |
![]() 2052 forum posts 56 photos | Posted by JasonB on 06/10/2016 18:29:43:
I thought you would have come across them Michael, as someone who teaches others to use CNC machines. These are often used on auto change tool holders on CNC machines I honestly haven't! i are in with a bunch of collet boys unfortunately Always get their name mixed up with automation, it's all the same surely! When i used mills it was generally bridgeport, large dc steppers, with hydraulic quick change shanks. Michael W Edited By Michael Walters on 06/10/2016 19:26:03 |
Michael Gilligan | 06/10/2016 20:33:46 |
![]() 23121 forum posts 1360 photos | Posted by Martin Kyte on 06/10/2016 15:26:10:
Don't see why you are confused. < etc. > . Confused because [so I believe] your original remark was about Drilling Chucks; but then you agreed with Andrew, about Milling Chucks ... and appeared to do so without breaking-step. Just explaining my confusion ... I don't really want to continue the discussion. MichaelG.
Ajohnw | 06/10/2016 20:45:00 |
John - |
Hopper | 07/10/2016 01:32:22 |
![]() 7881 forum posts 397 photos | Re the concern about drill chucks falling off their internal taper when used for millng with sideways load, I just noticed one well regarded supplier sells an ER collet chuck machined with an internal JT1 or 2 taper so it is fitted to a standard drill chuck arbor for use, eg MT2 one end, JT2 t'other. They do say that a small screw in the bottom end of the JT1or2 taper is used to retain the collet chuck for milling puropses. So if an ER collet chuck can be retained and used sucessfully on a tapered arbor for milling, I wouldn't be too worried about a drill chuck coming adrift, providing it had that internal screw, as many do. |
Ian S C | 07/10/2016 10:48:12 |
![]() 7468 forum posts 230 photos | Hopper, when I first started with my mill, using a Jacobs chuck, the chuck was held to the MT3 arbor by a JT 6 taper, it was the MT 3 taper that let go. The JT taper is designed to be semi permanent, unlike the MT taper that is designed to be removed from it;s socket. Ian S C |
Swarf, Mostly! | 07/10/2016 11:01:08 |
753 forum posts 80 photos | Posted by John Alexander Stewart on 06/10/2016 14:35:49:
Weldon shank end mill holders. Ok - not that it matters much to us, but for precision machining, OR for long production runs: 1) There is play in a Weldon-shank end mill holder. (there HAS to be, otherwise one can not put the end mill in!) This means that, by definition, the end mill is not centered, thus will wobble; 2) Long production runs, the end mill flexes around the juncture of the set screw, leading to wear on the collet. And, when they start to wear, the wear increases quickly, and the end mill is not held securely. At least ER collets will hold end mills securely for the length of the collet-endmill interface, and the end mill is at least close to centered... Food for thought; John. Hi there, John, I have no dispute with any of your post - my comfortable operating zone is sort of defined in the first part of your first sentence (between the words 'OK' and 'but' ) . Best regards, Swarf, Mostly! Edited By Swarf, Mostly! on 07/10/2016 11:02:53 |
Roy M | 07/10/2016 13:26:28 |
104 forum posts 7 photos | |
Martin Kyte | 07/10/2016 14:11:49 |
![]() 3445 forum posts 62 photos | So out of curiosity I measure the runout on my Jacobs chucks. Both very old 1/2" jobs and as far as I know have never been stripped and cleaned. The first one was around 2thou TIR and the other one considerably worse at 4thou. I have a tiny one which is 1Morse on a sleeve that came in at 1.5thou. This was at approx 1/2" from the jaws. So they are worse than I thought but still within Jacobs spec. regards Martin |
Ajohnw | 07/10/2016 15:45:09 |
3631 forum posts 160 photos | Did you measure it by holding say some silver steel in it and rotating that in a checked V block and measuring the run out at the end of the taper ? The V block can be checked with the same bar assuming that the surface is flat and that can be checked by reversing it. John - |
