Roderick Jenkins | 23/04/2018 13:09:43 |
![]() 2376 forum posts 800 photos | I sorted the pictures I took of our trip to Blists Hill Victorian Town last week. We were lucky to be there on a casting day:
By mid-afternoon it was all broken down. The foundryman said it took a week to do all the moulding and set the flasks up then fettle the castings and paint them. Our cast iron welly remover is now proudly sitting on our back doorstep.
Of course, No visit to the area would be complete without a picture of the historic and iconic Iron Bridge:
They aim to have it back from restoration in November. There is a walk way on the other side that allows a look through some gritty windows the get a rather ethereal look at the the structure.
Cheers, Rod Edited By Roderick Jenkins on 23/04/2018 13:11:39 |
Muzzer | 23/04/2018 14:26:29 |
![]() 2904 forum posts 448 photos | Posted by Andrew Johnston on 22/04/2018 21:06:06:
I was somewhat delayed entering the workshop as we've had about half a dozen power cuts this evening,the shortest a few seconds and the longest lasting nearly an hour. Andrew When I lived there I put the high frequency of power cuts in E Anglia down to the flat countryside resulting in more lightening strike on the power lines. I suspect the shorter interruptions are automatically reset and the longer ones required a man in a van to go out and fix something. We used to just get in the car if it didn't restore quickly and go have a meal somewhere. But it was getting quite tedious inn the end. Murray |
Rik Shaw | 24/04/2018 12:54:26 |
![]() 1494 forum posts 403 photos | There are seven chilled cast iron sash weights under the flames with more wood waiting. Fingers crossed that this is a de-chilling exercise and not a waste of time exercise. Rik |
Bazyle | 24/04/2018 13:20:17 |
![]() 6956 forum posts 229 photos | Rik, I doubt that will have any effect I'm afraid. I have tried days in the wood stove running it hotter than usual but still not enough. Wood doesn't really get hot enough unless being blown. |
David Standing 1 | 24/04/2018 13:26:05 |
1297 forum posts 50 photos | Posted by Neil Wyatt on 22/04/2018 22:13:12:
I got sent a video of a 1988 performance by my first band. Now I have proof I once shared a stage with Benjamin Zephaniah, although he was compère not our lead singer!
If I were you, I would quietly delete the post and keep all that information to yourself ! |
Ian S C | 26/04/2018 12:35:34 |
![]() 7468 forum posts 230 photos | Our Men's Shed (just getting started) has been given a rather scruffy Model A Boxford lathe, I spent the morning cleaning the lathe, and sorting some of the bits and pieces that came with it. the only damage I have found so far is in the 4 jaw chuck, 3 out of 4 of the square key holes have a side out of them. The chuck is fairly tight on the spindle, I have not tried too hard to get it off yet. On looking up the hand book I can see the reason for the broken holes, the book says put the chuck key in a hole and give a good bump with your hand. There is a 3 jaw chuck, plus a brand new Bernard 3 jaw that needs a back plate. Looks like I have a wee job on getting the machine up and running, but from what I see it is actually in not too bad condition. Ian S C |
Michael Gilligan | 27/04/2018 11:05:49 |
![]() 23121 forum posts 1360 photos | It's nothing very original, but this **LINK** is worth a look. http://moticeuropeamericasblog.blogspot.co.uk/2018/04/cracks-in-pipe.html Nice illustrations of Stress Corrosion Cracking MichaelG. Edited By Michael Gilligan on 27/04/2018 11:06:07 |
Ian S C | 27/04/2018 12:20:35 |
![]() 7468 forum posts 230 photos | Here's a photo of the Boxford at the Darfield Men's Shed. Ian S C |
Muzzer | 27/04/2018 12:23:35 |
![]() 2904 forum posts 448 photos | Bear in mind this is pretty much specific to stainless steels. Not many of us actually subject that material to high stresses in a corrosive environment and safety critical application. The mechanism seems to share a lot in common with the issue of "pinholing" of 304 (also Austenitic) which I am now more expert in than than I would like, due to my unhappy encounter with Franke (of sink fame). The chromium seems to combine with the likes of chloride ions, resulting in a loss of corrosion resistance. So I am now the proud owner of a Franke sieve where the sink used to be. A sieve that I have blocked with metal loaded epoxy adhesive. Murray |
Michael Gilligan | 27/04/2018 12:41:34 |
![]() 23121 forum posts 1360 photos | Posted by Muzzer on 27/04/2018 12:23:35:
Bear in mind this is pretty much specific to stainless steels. Not many of us actually subject that material to high stresses in a corrosive environment and safety critical application. . The photos are specific to stainless steels, but I'm sure my first acquaintance with Stress Corrosion Cracking was related to aircraft skins. MichaelG. |
duncan webster | 27/04/2018 13:47:47 |
5307 forum posts 83 photos | Posted by Michael Gilligan on 27/04/2018 12:41:34:
Bear in mind this is pretty much specific to stainless steels. Not many of us actually subject that material to high stresses in a corrosive environment and safety critical application. . The photos are specific to stainless steels, but I'm sure my first acquaintance with Stress Corrosion Cracking was related to aircraft skins. MichaelG. This is why we shouldn't use SS in boilers where it is in contact with high temperature, high pressure water unless very sure what grade it is. Tap water contains chloride, and when we boil it away it gets more concentrated |
Speedy Builder5 | 27/04/2018 18:36:23 |
2878 forum posts 248 photos | Ian S C, |
Andrew Johnston | 27/04/2018 20:48:25 |
![]() 7061 forum posts 719 photos | First try out of the new flycutter: Not much metal needed removing from the chimney base so with a 1mm DOC and 0.2mm feed per rev, at 41rpm, the mill, and flycutter, didn't even break sweat. The chimney base seems a nice fit on the smokebox, meaning my alignment and cutter setting with gauge blocks must have been about right: Andrew |
Bazyle | 27/04/2018 23:37:21 |
![]() 6956 forum posts 229 photos | With rain forecast for tomorrow I'm glad not to be a birdwatcher as the annual dawn chorus walk near me sets off at 5.30am tomorrow. In fact I don't intend even to get up in time for the post walk breakfast in the village hall at 8am. If I push myself I will get to the Men's Shed by 10 in time for the first tea break. |
Ian S C | 28/04/2018 11:35:47 |
Here's one of my trailers on my old bike, the other one has two wheels. Ian S C
Edited By Ian S C on 28/04/2018 11:46:49 Edited By Ian S C on 28/04/2018 11:50:27 |
Andrew Johnston | 28/04/2018 19:39:25 |
![]() 7061 forum posts 719 photos | Among other things I machined the curved surface on both perch brackets: I can now store the flycutter until such time as I start machining the cylinder block and other items that sit on the boiler. Andrew |
ChrisH | 29/04/2018 00:21:38 |
1023 forum posts 30 photos | Good day out today, drove through lovely countryside to Dartmoor with it's stunning views for a picnic lunch, then on down into Plymouth to get some essential suppliers for the next brew from excellent home brew shop The Hop Shop in Mutley, then back via the A30 stopping at Monkton at the Otter Valley Ice Cream lay-by for the best chocolate ice cream, in the world (said all Jeremy Clarkson). Probably (apologies to Carlsberg)! Brew day Monday now to look forward to. Chris
J Hancock | 30/04/2018 17:11:48 |
869 forum posts | Fitted new brushes into my '93 Hoover ' Never Die' washing machine. Perfect again now. Shocked to find ALL new machines are cold fill only. For 'efficiency'. Never mind that it is 3x more expensive to heat water using electricity. |
duncan webster | 30/04/2018 17:37:30 |
5307 forum posts 83 photos | Modern machines use so little water that if you connect them to the hot system you get mostly cold in the washer and hot in the pipework, where it then goes cold. You have to heat it electrically no matter what. |
J Hancock | 30/04/2018 19:06:19 |
869 forum posts | And that's the other thing, my 'Never Die' is a 5kg load max, all these new ones are 7kg min.,then 9 and 11kg. How big are these families ?
This thread is closed.
