Tool post height
brian jones 1109/07/2021 08:38:16
347 forum posts
62 photos
Posted by Vic on 08/07/2021 23:17:07:
I think my little 8 1/2” x 14” is meant to take 10 or maybe 12mm tooling? I bought a 16mm TNMG holder and trimmed a couple of mm off the bottom and it works well. The holder is quite tough but it wasn’t too much trouble to trim it down with a carbide mill.
wow that looks like the dogs............ ca $10 on Ali
looks like you would use that with a standard myford clamp
https://www.myford.co.uk/acatalog/TOOL-CLAMP--74-1409-1-1278.html
I'll go and check tool height and revert
Vic09/07/2021 10:22:46
3453 forum posts
23 photos
Posted by Martin Kyte on 09/07/2021 08:04:07:
Does all this beg the question, why use bigger tooling than that which will fit?
regards Martin
Edited By Martin Kyte on 09/07/2021 08:04:19
The smallest tool holder for some inserts is 16mm so no choice. The TNMG is a case in point. I’ve just got some polished inserts for aluminium at a very good price and they work really well. The tool holders are cheap on the auction site.
Alan Jackson09/07/2021 10:32:12
276 forum posts
149 photos
MLA version QCTP with no overhang
Alan
JasonB09/07/2021 11:22:31
25215 forum posts
3105 photos
1 articles
Alan, unless I'm missing something the holder still has no direct line of support under the tool and is over hanging from the toolpost which is the "disadvantage" people are talking about
brian jones 1109/07/2021 14:35:01
347 forum posts
62 photos
my lathe never been that clean, eat you dinner off it
old mart09/07/2021 14:50:55
4655 forum posts
304 photos
For those who would like TNMG inserts, but don't have a big enough lathe to take the common size 16, (there are smaller, but they are like hens teeth), you can look at WNMG 06 which has all the advantages but is smaller.
Steviegtr09/07/2021 15:32:03
2668 forum posts
352 photos
The reason i posted about using the larger tooling was not because there is anything wrong with the smaller items.
The are so many cutters in the larger sizes of good quality over the smaller items, E.G. I have a 16mm boring bar ,which is a TIZIT, used . I paid £8.00 for it.
Steve.
Alan Jackson09/07/2021 17:27:37
276 forum posts
149 photos
Posted by JasonB on 09/07/2021 11:22:31:
Jason, You are quite correct but the cutting tool does not reach (cantilever) beyond the lower support so there is no moment created to make the topslide tend to flex or pivot. If I need a more solid toolpost I use a four way or triangular toolpost.
Alan
Edited By Alan Jackson on 09/07/2021 17:37:32
Vic09/07/2021 19:04:48
3453 forum posts
23 photos
I found at the model engineering shows all the bigger stuff was cheaper. I suppose because many model engineers have modest size machines. I’ve paid as little as six or seven pounds for a tool holder. Having machined a Sandvik tool holder for a friend I was confident of being able to machine them when needed.
brian jones 1109/07/2021 21:27:16
347 forum posts
62 photos
that looks very solid to me, and simple. These triangle tips have a lot going for them
BTW has anyone come across a prog for decoding carbide language for tools and tips, ie you just put in the code and it spits out the spec
I saw it mentioned somewhere now lost in the mists of dementia
DiogenesII10/07/2021 06:31:20
859 forum posts
268 photos
There's a useful pdf you can download here - (it's the one that used to be visible at Carbide Depot..)
Midwest Supply - Carbide Insert Designation
Howard Lewis10/07/2021 15:38:55
7227 forum posts
21 photos
Re Carbide tip codes.
There was a thread on here, not too long ago.
Look through previous threads, or use the search facility.
brian jones 1110/07/2021 15:41:30
347 forum posts
62 photos
heres my take on the tool height dilemma
hope it make sense - for illustration only as you must check your own dimensions
so with the desirable and plentiful 12mm holder you can
a) skim 2mm off the holder base (or part skim as suggested leaving a step on the overhang)
b) Skim the top of the topslide - but then the 4 way block will be wrong and you will need shims for a 5/16" hss
c) Make up a 4mm shim piece to fit under the holder and use the elephants foot
d) buy a new chinese machine and stop dickering around
What do you think
Obtw I have made the assumption that a 12mm holder will also mean the height of the tool tip - is this always right?
Another member mentioned the use a  16mm holder and doing some skimming to make it fit.  According to my estimate it should fit as is under an elephant foot see below - pls advise as I dont have one of these yet and I was thinking of getting a set with  triangle pieces (in fact it was steviegtr as above)
Edited By brian jones 11 on 10/07/2021 16:02:34
Edited By brian jones 11 on 10/07/2021 16:06:07
Howard Lewis10/07/2021 15:48:42
7227 forum posts
21 photos
Personally am averse to making any irreversible changes to the machine, so would advocate milling the underside of oversize tool shanks.. (But not enough to weaken them seriously. 2 mm off a 12 mm will not be as weakening as 2 mm off a 8 mm shank.
Stiffness is BD^3 / 12 , so keep D as large as possible in the interests of rigidity.
One or two tool shanks have been reduced in depth, but leaving the area immediately near the carbide tip at full section, for that reason..
brian jones 1110/07/2021 15:48:54
347 forum posts
62 photos
Posted by Howard Lewis on 10/07/2021 15:38:55:
Indeed I have been scrabbling around, but most of the links are to iso type tables (15 or so)
what I wanted was to input the code and the app would spit out the decoded result.
this could all be done on Xcel but I have so many dozens of unfinished little jobs I was hoping someone may have got there first
OBTW one member wisely noted that referencing US mfg beware as they use imp units vs metric for rest of the world and the coding maybe different
JasonB10/07/2021 16:10:55
25215 forum posts
3105 photos
1 articles
6mm and 8mm are also readily available you could just buy those and not modify anything, a bit cheaper too. Look through this album of mine virtually all done with 6 & 8mm shank insert tooling.
You may be surprized at what can be taken off with just a 6mm tool that happens to be in a QCTP with the overhang "problem" mentioned by others and all this on a far eastern machine. 1/4 depth of cut so 1/2" off diameter in one pass.
Even a Myford will do similar, this is Rod's video who commented earlier that his toolpost works fine too.
Edited By JasonB on 10/07/2021 16:15:58
Neil Wyatt10/07/2021 22:08:43
19226 forum posts
749 photos
86 articles
Posted by JasonB on 10/07/2021 16:10:55:
Says it all really
brian jones 1110/07/2021 22:30:02
347 forum posts
62 photos
Ok for clarity then what tools are you using in the vids, they dont look like inserts, brazed tip? HSS
it is said that you can get a finer sharp edge on HSS so make cutting easier. too sharpe an edge on carbide makes them liable to chip the edge too easily especially on manual feed.
It also appears that the combination of surface speed, depth of cut and feed rate are what can make all the difference
saw a vid on this on here somewhere - fascinating 3" billet taking off 10,20,30 thou same speed same power feed only mid one gave a mirror finish
30 thou he upped the feed rate, and it came out fine? how do you work all this out
have not got a grip on this yet
perhaps cnc s/w does all this calc for you/
Vic10/07/2021 23:08:45
3453 forum posts
23 photos
The OP was clearly about insert tooling as per the picture so I don’t know why it’s changed to HSS? thinking
Michael Gilligan11/07/2021 07:39:47
23121 forum posts
1360 photos
Posted by Vic on 10/07/2021 23:08:45:
Does it matter ?
… The thread is about Tool post height
