VFD Drives
Steve Garnett17/04/2011 23:24:21
837 forum posts
27 photos
The only thing I've discovered is that whilst there appears to be a universal agreement about how electricity is supplied to your billing company, there isn't quite such universal agreement about how they should charge for it. Some places it all comes out equal, and in other places there are tariff differences, even domestically, if you have a three-phase supply. So it might be a bit of a postcode lottery - or at least worth shopping around if you are one of the disadvantaged ones.
I would have thought though, what with all this competition and all that, that perhaps they would be competitive over this - maybe that's why the old differences have gone away?
Ramon Wilson17/04/2011 23:40:31
1655 forum posts
617 photos
Posted by Jon on 17/04/2011 15:11:50:
Ray and Ramon, what is your electric bill like now?
Of course this would have to be on a like for like basis.
Hi Jon,
I'm afraid I can't answer your question specifically and apart from 'counting the wheel' as suggested would have no idea at all. We have had no bills in yet to compare either. Last year, when I did the heads for the BR2 the mill was contantly start/stopping for near four weeks - this was with single phase 3/4 hp. This certainly did show up on the bill - as was pointed out to me!!.
What is noticeable however is that the lights in the house no longer dim as lathe or mill start up - whether there is a running cost over and above the running of the motor with VFD remains to be seen - I'm sure that it will be pointed out too.
The thing I do notice though is that the quieter, smother running of lathe, despite the slight whine, is such that I forget to turn it off something that was always done with the old set up.
Regards - Ramon
Nicholas Farr18/04/2011 00:13:49
3988 forum posts
1799 photos
Hi, Well to be honest I'm not sure how I'm chargred for my electricity, except that I get cheap rate between midnight and 7.30 AM GMT, and I pay my bills on a monthly plan by DD. In the old days you used to get a standing charge for supplying electricity, which I presume ment a charge for every meter you had, and then a usage charge for each and every meter. I assume its still much the same.
Regards Nick.
Edited By Nicholas Farr on 18/04/2011 00:15:17
John Olsen18/04/2011 07:23:25
1294 forum posts
108 photos
1 articles
You may well find that if your setup needs more than one meter that they charge more for it. I suppose such a charge would be to cover the depreciation and interest costs of the extra meter, plus I guess a healthy profit margin. Or they may just pick a number out of a hat, who knows.
As far as the actual devices go, the efficiency of an inverter is high enough that you should only be paying for the actual power used, the power dissipated in the device is negligible. If it was not, the inverter would get rather hot. It is possible that the power meter might not cope well with the harmonics that the rectifier in the inverter can produce, but modern units are designed to keep the harmonics low anyway.
With the phase converter gismos the same sort of thing should apply, the inductors and capacitors in them should be fairly low loss or they will make themselves evident pretty quickly. Where there is an idle motor, that is going to consume a certain amount of power to overcome its own friction, so that will cost something. One aspect of things is that such convertors are likely to have a poor power factor...there may be some attempt at correcting this, but it won't be right for all loads. I have heard of cases where a poor power factor affected the meter reading...it was an inductive load and it actually reduced the measured power consumption for the month. This should not happen in theory, since if the meter should be measuring true power. So adding the somewhat inductive arc welder across the normal domestic load for the month should have resulted in an increased consumption, but it actually reduced it. Not guaranteed to work with all power meters!
Anyway, typical workshop consumption is likely to be a lot less than you would use if you used electricity for heating.
regards
Jon16/05/2011 23:28:14
1001 forum posts
49 photos
Posted by Les Jones 1 on 17/04/2011 17:20:11:
How are you measuring the running cost of your inverter ? I suspect that the units being sold to monitor your power consumption may not give accurate results with the current waveform drawn by the inverter. I think the best method is to count revolutions of the wheel in your electricity meter and calculate the cost from that.
Les.
Les i used what my electric provider sent me.
Clamped after meter but before the fuse box and sends wireless to the reader.
Most things seem believable from bulbed lights to kettles.
I get no interferance at all not even on a DAB radio a few feet away.
Wired 3 core and earth but outer sheath not earthed.
The findings above were with a 5hp digital inverter, incidentally packed up last week £206 repair bill and 7 weeks for max 1 1/2hrs work from new.
Now had to fork out for the 10hp, so far so good but uses an extra 0.1amp on each phase compared with 5hp.
Counting the wheel revs totally out the question, it needs to slow at least 4 times then it would be borderline.
I do have a rotary convertor as well 5.5hp.
John Stevenson17/05/2011 00:06:23
5068 forum posts
3 photos
I get two electric bills per quarter.
House is on domestic single phase. first 210 units @ 20.05p each
Rest @ 10.05p
Workshop on industrial 3 phase, first 78 units @ 15.69p each
Rest @ 13.44p
Both these with E-On.
One thing I have noticed is that i have recently changed the plasma and Tig sets over from transformer based to inverter based and this has made a noticeable difference.
Noticeable in that I don't bother checking readings etc but since the change over the amount has dropped a fair bit
John S.
confused.eng17/05/2011 01:01:52
19 forum posts
2 photos
If your on a 3ph supply then a thing called power factor comes into effect. Electricity supplies get a bit funny as they don't like low power factors, or unbalanced usage on the supply. If you have a 3ph meter then the meter can measure the phase angle and adjust the usage reading. If you have 3 single phase meters then the supply company adjusts the readings for you. The other thing the suppliers don't like is heavy short duration loads normally referred to as peak demand and will usually bill you as though you were using this for the whole billing period.
If all your workshop sockets are on one phase then this can easily trigger a premium billing period. Put kettle on one phase, compressor on another, etc. Just watch out for wiring regs as sockets on different phases have a minimum separation distance.
If you have noise on inverters this is from my experience a very very very difficult mine field to navigate. General problem is bad earthing. Earth to drive must be very low resistance. Earth from drive to motor must be very low resistance.
The cable from the drive to the motor must be a screened cable with an earth core. An 'SY' type cable is useful for this. The earthing must be connected to the drives earth connection. The screen must also be connected to this earth connection. The earth core at the motor end should be connected the motor earth terminal and the screen must be connected at the motor end. Best thing to use for this is an EMC gland. Expensive for what they are but worth it in the end. All paint must be removed before connecting the earth or screen. Lots of people don't bother and wonder why they have problems.
Inverter control terminal, eg run, stop and speed should usually be cabled in a screened cable with the screen connected at one end only - the drive end.
Ferrite cores can help reduce interference, but you need to be careful as these can get very hot if not used correctly. They act as filters and are usually rings or cores that you pass the wire through or clip around the cable, you need to refer to the drive manual for details but with the rings you usually pass the motor phase wires through them twice immediately after the cable leaves the drive.
I have experienced situations where all the above has been done and still had noise problems and the only way to cure it was to disconnect the screen - just doesn't make sense - brick wall helps.
Another thing that can cause excessive noise is the switching frequency the drive is using. On most of the modern drives this can be changed though a parameter but sometimes makes the situation worse.
Don't fit any switches between the drive and motor as these will be destroyed quickly as the output from the drive is not a pure sin wave and most switch gear is designed to work only with a pure sin wave, especially the cheap far east import stuff.
Steve Garnett17/05/2011 01:54:53
837 forum posts
27 photos
Posted by confused.eng on 17/05/2011 01:01:52:
Actually it does make sense - and it's recommended practice! You shouldn't confuse the safety earthing arrangements with the screening requirements - they aren't the same thing at all. I have yet to find a situation where having a screen joined at both ends reduced any form of emissions at all - it can potentially increase them, and often it does.
With most inverters, you need a common grounding point, which is generally on the inverter itself. All the screened leads you run should have one end of the screen only connected, and generally it should be at that same earthing point that you do this. If you don't do this, then the screen becomes a conducting path for interference, rather than the screen that it should be, and that means that it can radiate. So your earthing connections for the motor and supply should be solid, and meeting at one point, on the inverter earth tag. The screen on the incoming supply should be connected here too, and so should the screen for the motor cable and control cable, if there is one. But the other ends of these screens should not be connected to anything - they are only screens, and shouldn't ever be used as conducting paths.
The ferrite cores you mention work effectively as a shorted-turn transformer at high frequencies, and if they get hot, then you are generating a considerable amount of interference. If you are getting radiated interference, then almost certainly this will be on the output side of your inverter, and that's where you will get most advantage from the ferrites. The other crucial thing about reducing interference is to keep the lead lengths as short as possible - this also helps to reduce the wiring impedance - it's impedance we are concerned about when there's interference involved, not resistance so much.
The other problem that is frequently encountered with inverters is that they trip earth leakage systems. There is only one really effective solution to this problem, and unfortunately it's rather expensive. That is to purchase a mains isolation transformer, and run the inverter's input from that. But to play safe with the transformer, it's going to have to be rated somewhat higher than the total load, and with even a 1HP motor, that means it has to be rated to supply at least 1kVA. The reasons for problems with earth leakage all relate back to what happens on the primary side of an inverter - basically your single (or even three-phase) mains supply is being converted to DC straight from the supply using socking great rectifiers - and with the best will in the world this is likely on some systems to unbalance the load. I should also point out that the whys and wherefores of this vary considerably between systems; what works fine on one mains supply won't necessarily behave in anything like the same way on another.
And whilst you are correct about having no switching in the output, the reason isn't quite so simple. If you look at the current output waveform from an inverter, you'll find that it generally is a good sine wave. The voltage output isn't though, because this is what's being chopped by pulse width modulation to produce the current sine wave. Where switching really runs into problems though is with the reactive feedback systems that are used to sense and control the motor - switches can screw this up completely, and even leave you with dangerous situations. All the advice I've ever seen about this is that you can use plug and socket connections if you must - but make sure they are of good quality.
Edited By Steve Garnett on 17/05/2011 01:56:15
John Olsen17/05/2011 06:55:59
1294 forum posts
108 photos
1 articles
Actually power factor is a factor in single phase systems just as much as in three phase systems, although since the three phase systems are larger the power supply people pay more attention to them. An ordinary (non electronic ballast) flourescent tube ballast will havea power factor correction capacitor in it, even though it is for use on a single phase.
OK a bit about screening. For our purposes we can treat interference as being radiated in two ways, capacitively and inductively. Eg a magnetic field and an electrostatic field. Now, the electric field is pretty easy to stop, a simple screen earthed at one end will stop it. A simple screen like that won't stop a magnetic field. (A good thickness of soft iron would.) The best way to stop a magnetic field is to keep the go and return conductors really close together. This is why wires and cables are usually made up so that the conductors are close together.
So by using a screened cable with the screen earthed at one end, preferably the end where the interference is originating, and with all the active conductors close together inside it, we minimise both the magnetic and capacitive effects. Note that if we earth the screen at both ends, interference currents can flow in the screen itself, which means that they are outside the screen, and so will happily radiate.
Students of electromagnetic theory will know that I am simplifying things a bit here, but if you know that, you probably don't need my help anyway.
regards
Les Jones 117/05/2011 09:20:41
2292 forum posts
159 photos
Hi Jon,
If the device you are using to measure the power only senses the current then it cannot give a true power reading. To measure TRUE power the device needs to know the phase relationship between voltage and current. I think the device you are using is just measuring volt amps and even that value is probably only correct if the supply voltage is at its nominal value. (Which is a reasonable assumption.)
Les.
Steve Garnett17/05/2011 10:39:27
837 forum posts
27 photos
Posted by John Olsen on 17/05/2011 06:55:59:
I should have added a bit more about the screening properties, yes - but hey, it was nearly 2am! I did mention the bit about avoiding current flow in them, though.
Jon02/06/2011 10:07:05
1001 forum posts
49 photos
I still have an ongoing problem with the electric supply to inverter.
Trying to run a 3phase 400V 3hp motor non cap start probably equivalent on startup as a 9hp motor.
32A MCB type C spur direct to inverter.
After blowing up a £650 5hp plug and play after 1 1/2hrs use, tripped in the various contactors in control panel no problem. Upon spindle start it used to trip the MCB and give a ground fault at undefined times.
After having to fork out for the 10hp model i am having a similar problem.
This time the RCCD 80A 30Mah trips at undefined times and MCB fine.
Can anyone suggest a way forward?
Thinking either change motor to a cap start 3ph 3hp.
Or is the RCCB a likely suspect Crabtree split load 380/S030 80A 30mA
KWIL02/06/2011 11:19:22
3681 forum posts
70 photos
Jon, What you have not told us is what the various Inverter parameters have been set to, soft start ramp up time, line current settings etc.
Jon02/06/2011 12:59:10
1001 forum posts
49 photos
Thanks for the reply.
No soft start its plug and play.
Upon RUN the contactors trip in control panel, so cannot use a soft start to start the motor.
I did run 3 sec soft start on the 5.5hp plug and play, this had the effect of contactors chattering up until near 400V reached.
We assumed the start up loading was more than the 5hp (run equivalent of 7.5hp for 30 secs) could handle.
Running 400V drawing 1.9A no load when running lathe.
Worked well yesterday for 4 hrs and an hour last night stopping and starting.
5 mins this morning was fine until second power up.
Lathes a Harrison M300.
KWIL02/06/2011 14:08:17
3681 forum posts
70 photos
Jon,
My Harrison M300 runs without trouble, original motor as fitted, driven by inverter from single phase mains. The original safety and interlock features are all retained, but are configured to use the inverter.
Jon02/06/2011 14:27:31
1001 forum posts
49 photos
Same here Kwil and know of a mate with a late Student and Bridgeport running same inverter plug and play.
Have you rewired then?
ie direct to motor with soft start etc Used the two forward/Reverse switches, coolant, brake etc all rewired straight to the inverter input and back out again?
confused.eng02/06/2011 19:44:15
19 forum posts
2 photos
Hi Jon,
Inverters and RCCD don't mix very well due to the noise suppression filter in the drive. If you must use an RCCD with the drive you will most likely need one that is designed to work with both AC and DC currents. These tend to be very expensive.
You will also need to check the leakage current of the drive as this is usually quite close to he tripping current of the RCCD. From experience the RCCD usually trips when the drive is delivering a high current or when slowing down.
In the past a badly earthed drive has destroyed the serial port of my laptop (back in the early days) when trying to configure it.
Does your RCCD just power the inverter or the whole workshop? If there is a lot of electronic equipment powered up at the same this can increase the problem due to the filters built into the power supplies. It is possible to test the tripping current of the RCCD if you access to the correct test equipment. If you do the test with everything running in its normal condition safely and perform the test it will give you a tripping current. This current should be 30mA give or take a mA or so. If the tripping current is low then something on the supply is causing a lot of leakage and is a case of disconnecting one item at time and repeating the test until the offending item. It could be a combination of items added together causing. The inverter will be a big source.
Damp can also be a cause of leakage current. If coolant gets where it shouldn't then this won't help things.
Jon02/06/2011 20:34:28
1001 forum posts
49 photos
A very big thank you and confirmed my suspicions. Putting two and two together i am fairly confident its a household item namely a Bosch fridge or other corrupt builders wiring or appliance.
RCCD trips when powering the spindle up. When it doesnt trip motor fires up instantly, clunk/bang. Yesterday i mostly spun the chuck whilst powering up and was ok for hours.
I dare say i could move the 32A RCB C type on to the house circuit doing away with the split load RCCD,
RCCD powers whole workshop except fluorescent lighting. Normally things are left plugged in but switch off in three pin sockets.
Good earth on inverter, lathe earth going through shielded cable to inverter.
Thanks again massive help.
KWIL03/06/2011 11:51:22
3681 forum posts
70 photos
Jon, Read MEW 154 for my complete guide as to how to set up the M300, including the circuit diagram of the minor rewiring. My mains connections are straight in on a special workshop distribution board to keep away from the house RCDs.
Ramon Wilson21/12/2011 21:23:30
1655 forum posts
617 photos
The reason i ask and to be honest cannot believe myself my findings, the power consumption of these digital inverters drawing way more than double a rotary of same size.
3HP lathe motor with the Teco MA7200 uses 61p/hr, Transwave rotary 31p/hr + vat of course, both under no load.
Hi guy's I thought you might be interested in an update to this question.
The 'Chancellor' - that's Sue not George - recently announced that we are substantially (and it is substantial) in credit with said electricty supplier over a similar period of last year.
This can only be put down to the change in power units - no more surges and dimming lights every time mill and lathe are started. It's not scientific but definitely supportive even to the extent that a suggestion was forthcoming, from the purse holder, that perhaps I should use some of the rebate to purchase a similar set up for the drilling machine - oh really dear?? how nice
To be fair the same period last year was about when those BR2 heads were tackled and there was an awful lot of stop/start on the mill for best part of a month which probably had a false effect on putting up the monthly DD but someones happy I can tell you
The other big saving has been with the compressor. The old one - 1-1/2 hp with a 20 litre tank - would cut in about every two hours for a top up when not in use (never could find the leak) and every few minutes when being used to clean the odd part etc. The new one with much larger (150litre) volume tank is only being charged once a week for the same usage. Obviously it will be different when spraying or bead blasting but that's not going to happen on a daily basis.
In short guy's it's kudos all round in this house at the moment
Have a real good Xmas break, may Santa bring you that nice new lathe - with VFD naturally and of course ....
All the very best for a productive, peaceful and very happy New Year to you all.
Regards - Ramon
