Strange angle ?
Stuart C08/03/2011 18:41:56
20 forum posts
From the research I've done(including the literature from when I was an apprentice a long long time ago) it is known as a compound slide if it can cut angles.
Ones that are not adjustable for the angle are the simpler top slide.
Terryd08/03/2011 21:40:58
1946 forum posts
179 photos
Hi Stuart,
While I agree, and I have always known the rotating top slide as the 'compound', there are those that argue that the tool can still only be moved in one direction once the angle is set. However the combination of cross slide and top slide allows compound movement in two directions. And if you add in the longitudinal movement of the saddle that gives three directions, which i have also heard described as 'the compound'.
I suppose it's a case of yer pays yer money.............
Terry
Edited By Terryd on 08/03/2011 21:43:14
David Colwill09/03/2011 09:08:47
782 forum posts
40 photos
I have a type 13 DSG and the topslide / compound slide (delete as appropriate) did cause me several hours of head scratching until I finally worked it all out.
Keith Lomman09/03/2011 09:39:42
2 forum posts
Hi
Back in the Sixties in a Railway Depot we had a Leblond Lathe from the War years .
The top slide on this lathe was made with the axis set around to I think about 27 deg Anti Clockwise from 90 to the bed.
The sides of the slide were flush with the cross slide and this was "Normal" .position
At http://www.youtube.com/watch?v=VjNsKVPM2BI a very large leblond is shown working and this has the same top slide.
Could the Boxford be built in a similar way. No changing the top slide to cut threads.
Keith
Keith Lomman09/03/2011 10:24:28
2 forum posts
Hi
A further look at the LeBlond lathes on that site, it is not the same as the one we had.
This one had a 4 Way tool post and when it was on the stop, parallel with and at right angles to the bed, the slide travel was at an angle.
This has thrown no light on the original post.
Sorry for the confusion
Keith
Terryd09/03/2011 13:51:46
1946 forum posts
179 photos
Hi Staurt C,
Just to complicate matters I have include below, in full a quote from Tony at Lathes.co.uk about this matter of top slide vs compound. As I said earlier there are conflicting views amongst quite authoritative commentators.
Terry
COMPOUND SLIDE REST consisting of the CROSS SLIDE and TOP SLIDE
Sitting on top of the "Saddle" is the "Cross Slide" - that, as its name implies, moves across the bed - and on top of that there is often a "Top Slide" or "Tool Slide" that is invariably arranged so that it can be swivelled and locked into a new position.Very early lathes had a simple T-shaped piece of metal against which the turner "rested" his tool (all turning being done by hand) but when it became possible to move this "Rest" across the bed by a screw feed it became known, appropriately enough, as a "Slide-rest". The earliest known example of a "Slide-rest" is illustrated in Mittelalterliche Hausbuch, a German publication of about 1480.
After the "Top Slide" became a more common fitting the term "Slide-rest" was not so frequently used - and the different functions of the two slides led to their specific names being more widely adopted.
When two slides are provided (or sometimes, on watchmaker's lathes, three) the complete assembly is known as the "Compound" or "Compound Slide" or even "Compound Slide-rest". Some makers have been known to label the "Top Slide" as the "Compound Rest" or even the "Compound Slide" - but as "to compound" means the 'joining of two or more' - not 'one' - this use of the term in incorrect. The top and cross slide together should be referred to as "the compound".
Eddie09/03/2011 14:16:43
56 forum posts
Hi All
Please get to the topic again.
Strange Angle , not what its called.
Eddie
Stuart C09/03/2011 14:51:50
20 forum posts
I have spoken to Boxford and as I suspected they have confirmed that it must have been changed.
I'll do the checking with a dti and mark a new index line on the top/compound slide.
By the way if anybody needs to speak to the guru, Ken Beaumont, at Boxford you'd best do it within 2 weeks as he is retiring.
With regard to it being off topic, have a heart Eddie, the other question has also proved quite informative, some useful and interesting information given which may not otherwise have been offered.
Thanks everyone.
David Clark 109/03/2011 20:31:40
3357 forum posts
112 photos
10 articles
Hi Graham
Not the end of the story.
In some parts of the county it is called Mystic.
Not sure of exact spelling.
regards david
Stuart C09/03/2011 21:32:25
20 forum posts
bit odd that Graham, telling us it's getting a bit silly then proceed to go on about Suds and Slurry
PS. Mystic or coolant for me.
Terryd09/03/2011 21:50:03
1946 forum posts
179 photos
Hi Graham,
You and me and others may well quite understand what is meant by all these confusing terms. perhaps we are experienced engineers (I have 50 + years and have come across most of these terms) but a newcomer without the benefit of an apprenticeship or years of experience will certainly not have that understanding.
I believe that it is good and adds to understanding that we have these discussions. It is not the 'end of the story' by a long way.
Hi Eddie,
I thought that the main subject of this thread was by and large answered as Stuart has shown in his posts.  Debate then usually expands to issues raised surely as part of the exercise.
Terry
Edited By Terryd on 09/03/2011 21:54:08
Stuart C09/03/2011 21:58:37
20 forum posts
" I believe that it is good and adds to understanding that we have these discussions."
I'm with you Terry, open and good natured discussion is what builds a thorough understanding of a subject as well as what helps to build communities.
Every day is a school day!
chris stephens09/03/2011 22:56:23
1049 forum posts
1 photos
Hi Guys,
Just to go back to top v compound and for a bit of light relief, if you have two independent top slides does that make them "compound", before you ask, yes, I do have two, greedy or what?
chriStephens
dcosta09/03/2011 23:51:53
496 forum posts
207 photos
Hello Terry.
I, living a little far away from the island where MEW is published and having this forum almost as the only mean to communicate with other engineers, thank You for Your effort in explaining, and point to references, in benefit of mere ignorant mortals like me on the meaning of the various (some correct some not so..) names used in Your language to refer those parts of the lathe. In this way I finally learned the difference between topslide and compound slide.
Also learned from Mr. Graham Meek that there are at least three names for the coolant liquid we use in our metal cutting machines.
Hello Stuart:
I second You fully when You say "Every day is a school day!".
Thank You both
Dias Costa
Sam Stones10/03/2011 04:43:56
922 forum posts
332 photos
David Clark 1 wrote -
That's what we called it in my part of Lancashire, ie. Bolton.
A more technical name was soluble oil, and we had two sorts. One for general lathe and milling (machine) work, the other with a nicer smell, was for grinding.
Like David, I'm not sure if it was mystic or mistic (mist-stick). In grinding, it certainly became a mist.
Sorry to be so far OT, Eddie!!!
To climb back OT a little, my Myford ML7 had a top slide which could be indexed in an angular sense for taper turning. Does that mean it was a compound slide?
Sam
David Clark 110/03/2011 07:45:39
3357 forum posts
112 photos
10 articles
Hi There
Soluble oil for machines was quite a strong mix.
The grinder soluble was much thinner but was also quite slippy.
We also had a very slippy soluble oil we used to tap 15 holes at once in aluminium castings.
This was for British Seagull outboard motor gearboxes.
In more recent times, a lot of firms use synthetic soluble and these tended to sting when you had cuts in your hand.
regards David
Nicholas Farr10/03/2011 08:28:12
3988 forum posts
1799 photos
Hi all, just another two pennies worth of thought. The toolholder on most lathes can move in three plains, two of them most of us agree are the carrage and the cross slide. That leaves the one that is holding the toolholder which is at the top of the stack. Whether it can be rotated or not, depends on the design of the lathe, but because in most cases it can, its direction of sliding movement cannot be defined, as it can be made to move in parallel to the carrage or cross slide, or at an angle anywhere in between. Hence the term top slide.
Maybe this is why in the book "Know Your Lathe" they say the top or tool slide moves along the ways of the "compound rest", which combines the cross slide and the top slide. I haven't found any reference in the book to a "compound slide", so far.
In the end it will come down to which reference you prefer, I guess.
Regards Nick.
Stuart C10/03/2011 21:03:29
20 forum posts
funny you should mention maudlsey/whitworth, I served the first year of my apprenticeship at Openshaw Tech.(The site of the Armstrong Whitworth company) which is where I was taught to call it the compound slide
