Hi all, newbie with first lathe, rare one i think.
wayne ollerenshaw18/10/2021 17:56:31
40 forum posts
4 photos
Posted by Brian Wood on 18/10/2021 16:35:10:
Google has some information from Suffolk Steam on this particular lathe, It is demonstrated in a video
The nose thread is 60 mm O/D, pitch 5.5 mm with a through bore of 40 mm and 5 MT nose taper. From the size of the bearing housing I would guess at a taper roller bearing support at the chuck end and probably a plain roller bearing at the far end of the spindle
Old Mart recommends a decent quality oil in the headstock. I agree with him and used a semi-synthetic 10W-50 oil made by Morris Lubricants in a recent restoration of a Churchill Cub lathe of 1947 vintage. It seems to like it and runs very well at all speeds.
Brian
That is mine from Suffolk Steam. Andrew there is the bloke that sold it on to me.
Brian Wood18/10/2021 18:20:13
2742 forum posts
39 photos
Well then, Andrew at Suffolk Steam is the man to ask for any other information, the rest of us are floundering about without a lot to go on
Brian
Edited By Brian Wood on 18/10/2021 18:20:34
wayne ollerenshaw18/10/2021 18:23:21
40 forum posts
4 photos
Posted by Brian Wood on 18/10/2021 18:20:13:
Brian
He told me all there is to know. Just a chap sold it to him from a workshop clearance. his dad who was high up in the Navy got to have the lathe from a WW2 German Navy boat that was is Londonderry. he used it for model making for years.
wayne ollerenshaw18/10/2021 18:28:42
40 forum posts
4 photos
Posted by not done it yet on 17/10/2021 21:52:54:
Hi W.olly, welcome over here.🙂
Get the 2HP motor. Have you checked the threads on any of the bolts and measured the lead screw pitch (travel per rev) yet?
You won’t break it if you are careful. It is built like the proverbial brick bog.
Ipswich is a bit far for me, but I expect there are some nearer, who could give you some practical on-site advice- sort out your accessories and get that indexer working.
The better VFDs can be programmed for all manner of things.
Edited to add: Check the type of bearing on the headstock. If it is a plain bearing stick to the 1000rpm limit - well not much more. If a taper roller bearing, the main spindle could go much faster but the gearbox may not like it. It would be a shame to push it too hard.
Edited By not done it yet on 17/10/2021 22:04:10
Just done 1 rev on the screw feed and got 6 threads and 1.25", does that mean anything kida ? The cross slides etc are imperial i know that much. 10 turns to an inch.
Brian Wood19/10/2021 09:55:51
2742 forum posts
39 photos
6 threads and 1.25 inches. Means nothing at all.
A more meaningful result would be to measure as best as you can the carriage travel for10 full turns of the leadscrew to reduce reading errors
I suspect it will be some metric value. The other feed screws may have been replaced with imperial versions by the previous owner, a relatively simple modification when compared to changing the leadscrew as that would also change all the results for screwcutting from the gearing tables giving the various arrangements and their results in thread pitch.
Michael Gilligan19/10/2021 10:45:09
23121 forum posts
1360 photos
A decent photo of the Gewindesschneide Tabelle would help … but [to me] it looks likely that the leadscrew is Englisch
Credit: **LINK**
http://www.lathes.co.uk/union-werk/
Edited By Michael Gilligan on 19/10/2021 10:46:47
Dave Halford19/10/2021 11:26:41
2536 forum posts
24 photos
Which would be quite handy for a metric German naval vessel crew.
Makes you wonder about the story.
DC31k19/10/2021 12:23:12
1186 forum posts
11 photos
Posted by Dave Halford on 19/10/2021 11:26:41:
Yes. It is interesting to note that the two shown on the German site linked to above are also imperial - they are both gearbox models and the screwcutting charts are shown in the two discussion threads.
In one of the German site discussions, the poster says the bearings were marked GDR, so East German. However, that may have no relevance to dating this one.
Pete Rimmer19/10/2021 12:30:01
1486 forum posts
105 photos
Posted by Michael Gilligan on 19/10/2021 10:45:09:
Credit: **LINK**
4 tpi leadscrew on that lathe Michael.
Martin Connelly19/10/2021 12:41:02
2549 forum posts
235 photos
I wonder if the 6 threads comment is 5 pitches of the lead screw with the lands either side being counted from 1 to 6, with the 4TPI Pete says it has that would give a travel of 1.25"
Martin C
Michael Gilligan19/10/2021 13:57:06
23121 forum posts
1360 photos
Before the world went mad … Sir Joseph Whitworth’s system of threads was widely accepted.
Or example: We have recently confirmed [beyond reasonable doubt] that the Leica 39mm camera mount used 26tpi Whitworth-form thread [not 1mm].
Edited By Michael Gilligan on 19/10/2021 14:11:49
Michael Gilligan19/10/2021 14:07:59
23121 forum posts
1360 photos
Posted by Martin Connelly on 19/10/2021 12:41:02:
Martin C
That was my assumption yes
It’s a classic error, which most of us have probably made at least once.
wayne ollerenshaw19/10/2021 14:09:40
40 forum posts
4 photos
I will redo the check again tonight. Will of been me and a newbie to the world of lathes making a mistake like that.
DC31k19/10/2021 14:26:54
1186 forum posts
11 photos
Posted by wayne ollerenshaw on 19/10/2021 14:09:40:
As Herr Michael Gilligan suggests above, a photo of the Gewindesschneide Tabelle will mean you do not need to measure anything - the info. on the plate will tell you. Think of it like the label in your trousers - you do not need a tape measure to size them, you just look inside and see FB.
wayne ollerenshaw19/10/2021 14:34:03
40 forum posts
4 photos
Posted by DC31k on 19/10/2021 14:26:54:
I jave a clear image here but cant download off my phone. I beleieve its good though from what I have been told. I'll do it tonight when I'm home.
larry phelan 119/10/2021 15:28:40
1346 forum posts
15 photos
She looks like a good solid machine, beautiful gearbox and a good solid bed.
May have been through the wars, but still plenty of fight left in her.
A good clean up will do wonders and she should give many happy hours turning.
At the risk of being nosey, what did she cost ?cheeky
not done it yet19/10/2021 15:48:32
7517 forum posts
20 photos
Posted by larry phelan 1 on 19/10/2021 15:28:40:
… At the risk of being nosey, what did she cost ?cheeky
A proverbial steal at less than £400 (plus shipping, of course).
You can see it running (but not at work) in this video:
VIDEO
Edited By not done it yet on 19/10/2021 15:52:40
Brian Wood19/10/2021 16:45:41
2742 forum posts
39 photos
The video shown by NDIY gives a lovely clear picture of the threading plate which, when frozen, confirms that the leadscrew is indeed of English pitch at 4TPI
No need for Wayne to post a picture, the information is all there
Brian
wayne ollerenshaw19/10/2021 17:31:11
40 forum posts
4 photos
I am thinking on doing that. Well a basic dismantle clean etc. Dont really want to paint it ????
I paid £380, i only jumped at it as its a dam good price, well i thought and nont knowing much about lathes. and i was planning on spending well over a grand for a lathe next year or so. You could call it an impulse buy.
wayne ollerenshaw19/10/2021 17:33:06
40 forum posts
4 photos
Here is the pic just incase.
