Needs a new tip...
SillyOldDuffer | 23/03/2021 08:57:37 |
10668 forum posts 2415 photos | Posted by Mike Poole on 21/03/2021 22:23:43:
... A wash bottle is handy to keep the sponge moist. Mike Love this forum for good ideas, even though they often do nothing for my inferiority complex. I've been soldering since I was 13 and never thought of keeping a wash bottle next to the iron. On the plus side, I got plenty of exercise taking sponges to the nearest tap! Why didn't I think of it? Perhaps it's too obvious. I don't recall any of my friends having a wash bottle and three of them repaired TVs for a living... Dave |
Henry Brown | 23/03/2021 09:59:54 |
![]() 618 forum posts 122 photos | Thanks again for the recent replies... Yes, the leads show one or two light battle scars to the outer sheath, as far as I can remember they were there before my ownership. The wash botte is a great idea Mike, they do dry out so quickly, I don't remember anyone using one either. |
Frances IoM | 23/03/2021 10:14:41 |
1395 forum posts 30 photos | ask the kitchen manager for the next empty squeezy bottle that contained washing up liquid - or smaller ones that contained hand gel with the pump action - these can be knocked over without spilling anything |
IanT | 23/03/2021 10:43:03 |
2147 forum posts 222 photos | My old Weller (30+ years?) is still in regular use. I've purchased new 'PT' tips from Farnell UK in the past, who also stock spares for the irons themselves. It's good to see a product like this being supported with spares for such a long time. So old tech but still my 'go-to' electronics iron - although the hot-air gun is getting used more often as SMD components become more common in my projects. Regards, IanT |
John Haine | 23/03/2021 10:56:51 |
5563 forum posts 322 photos | When I worked at the Post Office Research Department in 1972 Weller irons were "updated" with a small format Belling-Lee plug between the transformer and the iron lead (presumably to add an earth connection for soldering static sensitive devices). Someone pointed out to the safety people that if you had a crowded bench with a mass of mains and other leads one of which had a small Belling Lee mains plug on the end, and it WAS a mains lead, plugging it into the 24 V secondary of a mains transformer might be a bit unsafe. So they tried it, and it was spectacular, 2400V coming out of the mains plug (for a short while). The PO bought a LOT of those irons, I believe Weller changed the design shortly after... |
John Doe 2 | 01/10/2022 17:48:07 |
![]() 441 forum posts 29 photos | Ah, very handy that I just noticed this thread: I too used Weller TCP irons professionally for many years, and found them to be very good. So, naturally I bought a Weller TCP for myself - a W 61 model. But it has a weird fault. Sometimes it works perfectly, but other times, the heating element jams on. The first I am aware of this is a bakelite smell from the iron holder stand and on inspection I can just make out that the barrel is glowing a very dull red !! I have had the iron in pieces several times and can see that the internal magnetically operated element switch is not welded shut. The switch operates when I remove the tip from the barrel or heat the tip in situ with a blowtorch. So why does the iron sometimes not shut off? I bought the iron and Weller tips from RS, and of course it is now out of guarantee, but it must be possible to get this thing working. I note Robert's comments about the tips made of two sections, which are the type I have, (no 7 ones). I have tried a couple of tips. I wondered if the heat from the element is not getting to the tip enough to trip its magnet? is there a heat transfer cream I could use? Or any other suggestions welcomed.
Dr. MC Black | 01/10/2022 17:58:40 |
334 forum posts 1 photos | Weller are a long established reputable company as are Radiospares. I'm certain that the technical boffins in one or the other company will be happy to discuss this problem and give advice. I have reported problems with items bought from Radiospares long after the guarantee expired and found them VERY helpful. What have you got to loose?
MC
Robert Atkinson 2 | 01/10/2022 19:59:02 |
![]() 1891 forum posts 37 photos | John, Robert G8RPI. |
John Doe 2 | 01/10/2022 21:14:12 |
![]() 441 forum posts 29 photos | As I stated above , the switch is not welded shut - that is the first thing I checked - visually. It opens when I withdraw the tip from the barrel, and when I heat the tip with a blow torch. There is some other reason, that I cannot fathom, except possibly to do with (lack of ) heat transfer from the barrel to the tip. Edited By John Doe 2 on 01/10/2022 21:16:35 |
V8Eng | 01/10/2022 23:22:40 |
1826 forum posts 1 photos | I had a weller tcp1 at work for many years and from what I remember if trouble occurred it was important to clean the inside of the tube that the tip sits in. Great irons I still miss it but do very little soldering of that type now and just rely on an old antex. Edited By V8Eng on 01/10/2022 23:28:31 |
peak4 | 02/10/2022 00:21:36 |
![]() 2207 forum posts 210 photos | Posted by Robert Atkinson 2 on 01/10/2022 19:59:02:
John, Robert G8RPI. Is the switch part of the heater element, and thus voltage dependent? Mine has the opposite problem and never heats up unless you shake it for a while, and then only stays hot for a short time. It works when you first power it up, and then cools off immediately. |
Michael Gilligan | 02/10/2022 09:03:57 |
![]() 23121 forum posts 1360 photos | Bill There is a concise description of its action on the page that I linked much earlier in this thread: **LINK** http://spritesmods.com/?art=wtcpled MichaelG. . Edit: __ more detail, of course, in the patent: https://worldwide.espacenet.com/patent/search?q=pn%3DUS3662152A Edited By Michael Gilligan on 02/10/2022 09:08:29 |
peak4 | 02/10/2022 11:30:57 |
![]() 2207 forum posts 210 photos | Posted by Michael Gilligan on 02/10/2022 09:03:57:
Bill There is a concise description of its action on the page that I linked much earlier in this thread: *................... Edited By Michael Gilligan on 02/10/2022 09:08:29 Thanks, I missed that. |
John Doe 2 | 03/10/2022 10:25:34 |
![]() 441 forum posts 29 photos | Mine is a W61 - mains voltage. The switch is at the opposite end of the heating tube to the tip, and is operated magnetically. The switch housing is transparent and I can see the switch contacts open and close if I remove the tip or heat the tip with a blowtorch. The problem has to be lack of heat transfer to the tip from the heating element so the tip is not getting hot enough to magnetically trigger the switch. The barrel and tip both seem clean enough. Is there a heat transfer paste I could use? Never seen it with any of the 48V Wellers I used at work though. |
peak4 | 03/10/2022 18:22:53 |
![]() 2207 forum posts 210 photos | Well after I'm not sure how many years, I think I've sussed it with my iron. The one fitted was non-magnetic, and intended for a non-Magnastat soldering station. |
Michael Gilligan | 03/10/2022 19:24:29 |
![]() 23121 forum posts 1360 photos | All’s Weller that ends Weller, Bill
Robert Atkinson 2 | 03/10/2022 22:25:05 |
![]() 1891 forum posts 37 photos | Hi John, Sorry I missed that you had a W61. This model does not use the two part LT series tips. It needs the CT5 series of tip. I note Farnell incorrectly say on their website it will use PT or LT tips Robert G8RPI
peak4 | 04/10/2022 00:02:42 |
![]() 2207 forum posts 210 photos | Other info available from Weller's own website, about the W61 as well as the type I use, which is where I found the issue with mine. |
Sen Huybrechts | 11/07/2023 16:44:09 |
1 forum posts | Hello I was wondering what tips this soldering iron uses. I have the weller type 21 021 magnastat lotkolben TCP (I think this is the same soldering iron as displayed).
Sen |
