not done it yet | 06/03/2021 06:48:44 |
7517 forum posts 20 photos | 16DP x 100 teeth is over 7 inches outside diameter. Only 6 3/8” by my calculator.🙂 a lot of fine passes. DP16 gears would only need one cut/tooth I would have thought (at least for cast iron). |
Hopper | 06/03/2021 08:44:34 |
![]() 7881 forum posts 397 photos | Posted by not done it yet on 06/03/2021 06:48:44:
16DP x 100 teeth is over 7 inches outside diameter. Only 6 3/8” by my calculator.🙂 Oh well, a doddle then. |
Dave Halford | 06/03/2021 11:27:54 |
2536 forum posts 24 photos | Posted by not done it yet on 06/03/2021 06:48:44:
16DP x 100 teeth is over 7 inches outside diameter. Only 6 3/8” by my calculator.🙂 a lot of fine passes. DP16 gears would only need one cut/tooth I would have thought (at least for cast iron). Thats true, I've done a 16dp 90 tooth iron gear on a BS0 with the Centec, but had to use the horizontal arbor in the vertical head to get the height. Even ignoring work holding the blank and cutter already eat up a bit more than 4" of daylight between centres. You occasionally see a Jones and Shipman 1mt divider on ebay, they don't go for much and look like the Alan Timmins head except the dividing plate is direct mounted to the shaft and would need modding to take advantage of the worm wheel gearing. It should fit the rear toolpost slot. |
Bazyle | 06/03/2021 11:51:31 |
![]() 6956 forum posts 229 photos | You might want to have a rethink about whether a dividing head is what you really need. Try thinking how someone would have done this fifty years ago, even on a smaller lathe. |
Roderick Jenkins | 06/03/2021 12:50:07 |
![]() 2376 forum posts 800 photos | As we give our advice to the OP it is, perhaps, worth bearing in mind that, as I understand it, the equipment he has available is similar to this:
(image from Lathes.co.uk) The OP will have a Mentor milling head rather than a Myford/Rishton but they are similar. The obvious solution, to me, is to mount the gear cutter on an arbor in the milling head and the gear blank on a dividing head on the cross slide. I can envisage 2 problems. The first is that there may not be enough travel on the cross slide to withdraw the gear blank far enough away from the gear cutter. The second is that the gear blank will have to be mounted on an arbor and will need clearance between the cutter and the dividing head chuck. This means that the blank arbor will need tailstock support. I don't think (could be wrong!) that the Myford or GHT types have sufficient clearance to the support arm for the size of gear the OP wishes to cut. The illustration above shows a milling table attached to the cross slide. Perhaps a longer table could be arranged that will accommodate a tailstock for the dividing head. Stay well everyone, Rod |
Diy Addict | 06/03/2021 21:28:45 |
34 forum posts 5 photos | You've understood perfectly Rod. I waited around a year for a Myford/Rishton head to turn up, then this Mentor popped up so I jumped on it. So my setup is virtually identical, though somehow the photo looks much more appealing. The 100 tooth is something of an aspiration. I'm looking to cut 56 teeth at 16DP in the short term. Also, I'm not set on any particular method, so I've found this thread particularly useful - thanks to all. Once the mill is bolted to the lathe, I'll try various configurations and post sny results here. All the best, Paul
Hopper | 07/03/2021 05:05:13 |
![]() 7881 forum posts 397 photos | Ah well tha6t puts a different slant on things. It looks like the pictured type of milling head would be the way to go for cutting larger gears like DP16 at 50 to 100 teeth. You could hold the blank on an arbor in the lathe chuck and use change gears for indexing for many tooth counts. But might be a bit limited if you have the QC gearbox and limited numbers of change gears to play with. In which case, back to finding a BSO type dividing head that would fit in the daylight under the milling head while bolted to the cross slide. Or even one of those rotary tables that can be mounted sideways and fitted with index plates. That would be a much more solid set up than trying to cut large diameter gears on the Myford dividing head and vertical column perched up on a rising block. They really are pretty flimsy and best suited for cutting small model gears etc. |
Martin Kyte | 07/03/2021 08:31:05 |
![]() 3445 forum posts 62 photos | The mill spindle is a fixed distance from the lathe spindle as I read it so that rules out the headstock division for gear cutting if the cutter is to be held in the mill. regards Martin |
Michael Gilligan | 07/03/2021 08:56:06 |
![]() 23121 forum posts 1360 photos | Posted by Martin Kyte on 07/03/2021 08:31:05:
. True ... but it doesn’t rule out the possibility of using the mill as a power source for a cutter-spindle mounted on a vertical slide; which might be a tidy [and powerful] alternative to the traditional ‘overhead’. MichaelG.
Martin Kyte | 07/03/2021 10:06:26 |
![]() 3445 forum posts 62 photos | Well yes but you do then have to get a cutter spindle and a headstock dividing head rather than just a crosslide dividing head. regards Martin |
Michael Gilligan | 07/03/2021 12:46:55 |
![]() 23121 forum posts 1360 photos | There is [quite obviously] no single ‘best’ way of working ... or we wouldn’t be having this interesting discussion. I would, however, like to share this video, which demonstrates using the Schaublin 102 with a cutter spindle on the vertical slide, and the dividing done in the headstock. https://youtu.be/u0Ngmzqf2xg MichaelG. |
Diy Addict | 30/04/2021 18:43:26 |
34 forum posts 5 photos | Well here's the solution I finally came up with - a Coronet Minor Headstock! Bought on a whim from you-know-where for £26, it could have been made for this job! The only mods needed were three holes for registration pins and mounting to the cross slide; a couple of collars, and a simple sprung indexing pin. Of course, you have to already have a gear with the required tooth count. It's shown here with an 89 tooth DP 16 gear blank in Tufnol. The headstock has an external thread which a 3/4" pipe fitting bolt fits, and an internal thread, which I've yet to measure. Here's a view from above, showing the mounting holes and indexing pin: I had to swivel the vertical mill attachment so the reference gear doesn't hit the column. I haven't dared try any cutting yet. There aren't really enough threads on the external front thread to be confident of good clamping, so I'll make some sort of front clamp using the internal thread before I try it out. The indexing pin is also 'blind' - hidden behind the casting, so there's plenty of scope for a mark 2 if the concept works. Let me know if I'm about to cause a big accident. All the best, Paul |
Dave Halford | 30/04/2021 19:02:04 |
2536 forum posts 24 photos | I would include some form of marking so you can spot wether either disc slips on the shaft. Also if you have stops of some kind for each end of the cross slide travel, it's all to easy to move to the next index with the cutter still partially in the blank. |
Swarf, Mostly! | 30/04/2021 19:11:28 |
753 forum posts 80 photos | Posted by Diy Addict on 30/04/2021 18:43:26: SNIP! The headstock has an external thread which a 3/4" pipe fitting bolt fits, and an internal thread, which I've yet to measure. Here's a view from above, showing the mounting holes and indexing pin: SNIP! All the best, Paul The mandrel of my Coronet Minor (mentioned in a recent thread) had a ¾" British conduit thread, 16 tpi, Whitworth form. Best regards, Swarf, Mostly! |
