Mike Poole | 25/01/2021 10:11:56 |
![]() 3676 forum posts 82 photos | In wife world phone chargers and tumble driers will use the same amount of power, a smart meter gives them an insight to how much power each device really uses. An information sheet would probably have been cheaper than the billions spent on smart meters. They will be a never ending source of trouble as being electronic they will eventually fail and be unrepairable due to component obsolescence. The big advantage is automatic reading that gives suppliers a large saving in data collection cost. Variable rates may be the hidden sting in the tail or a benefit if it can work for you. Mike
KWIL | 25/01/2021 10:48:48 |
3681 forum posts 70 photos | Of course nothing is for free, WE are paying for the so called smart meter roll out, something around £420 EACH customer by unnecessary raised bills. How many years of being careful will that take to pay off? Only EDF pestered me to fit one, they got a swift answer which had the desired effect. |
Anthony Kendall | 25/01/2021 11:56:38 |
178 forum posts | I actually would like one - in order to find out. I think my problem is I change suppliers too often for one of them to get round to fitting one. |
Vic | 25/01/2021 12:41:05 |
3453 forum posts 23 photos | It seems some folks bills have gone up considerably after having a smart meter fitted, even with identical usage. The reason given for this by the energy companies is that the old meter was under reading. I suggest anyone that has a smart meter fitted ask if they can keep the old one just in case! |
not done it yet | 25/01/2021 13:26:40 |
7517 forum posts 20 photos | A few points. It seems some folks bills have gone up considerably after having a smart meter fitted Some think the bill will go down just by having the SM. Unfortunately not true, the customer has to use the information, to do that (the only way is to reduce usage, for most energy suppliers). Also, if your usage includes inductive loads (fridges, freezers, etc) the smart meter will record a higher electricity use for those items (more than 20%?) than presently. Not many that know or understand that! I actually would like one - in order to find out. Don’t rush to find out. It will happen soon enough. When you change supplier, they will insist on installing a SM as a condition of supply. The government will change the rules when the industry gets most onto SMs. Water companies already insist on a metered supply, whenever a new owner moves in. In wife world phone chargers and tumble driers will use the same amount of power Spot on there. My wife thinks setting a a thermostat higher increases the heat from an electric heater, not that it simply turns the item on and off. I also call her ‘turn it on, never turn it off’🙂 She also refuses to save water by using the partial flush on the loo🙁. Gas boilers alone can be 150kw ++ You'll need smelling salts for the wife when it fires up. Properties like that would install heat pumps, shirley? With a COP of around 4 for a ground source heat pump, that would likely be using only one fifth of the power quoted by John Hancock (assuming a 20% heat loss within the current heating system). Also it might enlighten them of reality - and actually educate them a bit? [via the local display unit] Once a SM is fitted, the supply companies could not care a jot if that display fails. More proof that once they have got their savings, they could not care less about the customer actually saving power! prepaid smart meters Might be good for more, but what are the rates for those on these meters? |
Anthony Kendall | 25/01/2021 13:33:25 |
178 forum posts | NotDoneItYet - I think you need a new wife. Edited By Anthony Kendall on 25/01/2021 13:52:58 |
not done it yet | 25/01/2021 13:53:13 |
7517 forum posts 20 photos | Posted by Anthony Kendall on 25/01/2021 13:33:25:
NotDoneItYet - think you need a new wife. Apart from this, my wife has very considerable other benefits/better traits/etc🙂 . I accept that no one is perfect. We all need to make compromises. |
Mark Rand | 25/01/2021 15:07:04 |
1505 forum posts 56 photos | Posted by not done it yet on 25/01/2021 13:26:40:
A few points. It seems some folks bills have gone up considerably after having a smart meter fitted Some think the bill will go down just by having the SM. Unfortunately not true, the customer has to use the information, to do that (the only way is to reduce usage, for most energy suppliers). Also, if your usage includes inductive loads (fridges, freezers, etc) the smart meter will record a higher electricity use for those items (more than 20%?) than presently. Not many that know or understand that! I'm sorry, but that comment is somewhat gonadal. Rotating kWH meters measure power. Static kWH meters measure power. The accuracy class in use for domestic meters is 2% or better .
And yes, I did spend 7 1/2 years in charge of measuriing electrical power using both types in power station performance tests. |
J Hancock | 25/01/2021 15:30:37 |
869 forum posts | NDIY Good luck with that one, ( air/ground ) heat pumps for every household ! |
not done it yet | 25/01/2021 16:34:54 |
7517 forum posts 20 photos | MR, What? Less? Power? And I would expect they should be much better than ±2%. I would expect them to be specified as +0,-2% as, given the choice, they will all tend to record more than the truth. |
Mark Rand | 25/01/2021 17:22:09 |
1505 forum posts 56 photos | VARs are not charged for in UK retail electrical contracts. End of. |
Vic | 25/01/2021 19:12:01 |
3453 forum posts 23 photos | Posted by not done it yet on 25/01/2021 13:26:40:
A few points. It seems some folks bills have gone up considerably after having a smart meter fitted. Some think the bill will go down just by having the SM. Unfortunately not true, the customer has to use the information, to do that (the only way is to reduce usage, for most energy suppliers). Also, if your usage includes inductive loads (fridges, freezers, etc) the smart meter will record a higher electricity use for those items (more than 20%?) than presently. Not many that know or understand that!
Any particular reason for the selective quote, leaving out “even with identical usage” ? Edited By Vic on 25/01/2021 19:13:18 |
Colin Heseltine | 25/01/2021 19:33:16 |
744 forum posts 375 photos | The tariff may say you must have a Smart Meter with that particular tariff, but if they cannot fit one (for whatever reason) then they will still let you on that tariff. I am on 3-phase and I am not aware of any domestic smart meters that can handle 3-phase. Colin |
Mark Rand | 25/01/2021 19:57:23 |
1505 forum posts 56 photos | They are becoming available since mid 2020 |
Vic | 27/01/2021 14:11:44 |
3453 forum posts 23 photos | Posted by Mark Rand on 25/01/2021 15:07:04:
“Electricity meters are considered “accurate” if the permitted margins of error do not exceed +2.5% to -3.5% throughout the entire load range at which the meter is designed to operate” |
Mark Rand | 27/01/2021 16:20:06 |
1505 forum posts 56 photos | Not unreasonable after 25 years of service, but if you look on the data plate, you will normally see that it states "class 2", that's what it was manufactured to, |
