Stepper power for autofeed on lathe
Michael Gilligan20/10/2019 08:50:51
23121 forum posts
1360 photos
Phil
I would be interested to see the images ... but your posts are currently displaying empty frames.
Grateful if you could try again
Phil Grant20/10/2019 09:21:07
107 forum posts
21 photos
Does it show now? I forgot to change the dropbox link to display the image, sorry
Michael Gilligan20/10/2019 09:48:52
23121 forum posts
1360 photos
Posted by Phil Grant on 20/10/2019 09:21:07:
Still not showing for me, Phil [on iPad]
... perhaps someone else could check
Thanks for trying yes
Phil Grant20/10/2019 09:58:34
107 forum posts
21 photos
Another go for the images.
Phil Grant20/10/2019 09:59:21
107 forum posts
21 photos
Do all the previous images show as I used the same dropbox link for them all!
Michael Gilligan20/10/2019 10:03:10
23121 forum posts
1360 photos
Posted by Phil Grant on 20/10/2019 09:59:21:
No ... nothing except the Youtube video
Journeyman20/10/2019 10:07:50
1257 forum posts
264 photos
Must be an iPad thing all the images show for me (Linux Mint, Firefox).
Michael Gilligan20/10/2019 11:02:10
23121 forum posts
1360 photos
Posted by Journeyman on 20/10/2019 10:07:50:
Thanks, John yes
sad
SillyOldDuffer20/10/2019 11:29:45
10668 forum posts
2415 photos
Not working directly for me on Ubuntu/Firefox. However, I can see the pictures if I right click on the image space and select 'View Image'. (This loads an application to display the image outside the browser, ie independently of the web-site and browser combination.)
Edit: The brilliant theory that follows struck out below is WRONG!  I should have been able to display one of Phil's photos in this post, and it doesn't work...   Back to the Drawing Board in sack cloth and ashes!
The only peculiarity I can see in Phil's Dropbox links is they all append a query string, query strings being a way of passing extra information to a server. I think it's telling Dropbox that the image is one of many, so that - if called by suitable software like an Image Viewer - Dropbox can download a series of images as from a slide-show magazine. As the forum/browser combo only expects a single image per link, my guess is the extra query parameters are illegal in that context. The Browser expects only one image, not the first of a list.
Assuming my theory is correct, it's not a forum problem. The forum just allows writers to insert links to remote images that are passed unchanged to the readers Browser. It's the writers job to get his external links right! Technically, the missing images are due the readers web Browser not coping with a query string copied innocently by Phil from Dropbox.
However, I think it's easy to fix. An example, with the unwanted query string in bold:
https://www.dropbox.com/s/i0ug22ojhy4ajt7/2019-10-19%2020.32.37.jpg?dl=1
Removing the ? and everything after seems to create a working link:
Once Phil's posts are locked, links can only be changed by an administrator. Phil can tweak the links when first inserted and while the timed edit window is open.
Edited By SillyOldDuffer on 20/10/2019 11:37:15
Michael Gilligan20/10/2019 11:46:04
23121 forum posts
1360 photos
Thanks for the extra info. Dave
As I’m sure you realise; it is difficult to ‘right click’ on an iPad .... and the ‘long press’ alternative doesn’t seem to work with Phil’s image frames.
If you could post his dropbox link as text, I can probably get there
... much appreciated
Tony Pratt 120/10/2019 12:21:57
2319 forum posts
13 photos
I have just completed the first stage of an electronic lead screw build based wholly on the excellent You Tube channel run by Clough42.
All works as intended, fully capable running both metric & imperial feeds/threads on my metric lathe at the touch of a button, only problem is that the Nema24 stepper rated at 4 Nm is only giving 2.3 Nm so slightly underpowered, the supplier refunded the money & let me keep the motor.
Now going to trial for a while then tidy up the mechanical bits & box up the controls.
Tony
Frances IoM20/10/2019 12:31:33
1395 forum posts
30 photos
It would be much easier both now and especially for the future to use the admittedly clunky album feature of this site - Dropbox is a tracker (hence the 'free' nature - viewers pay via privacy) + also such 'free' sites tend to drop images after a time thus often wrecking the thread (see the mess made when one such site went commercial)
Michael Gilligan20/10/2019 12:36:30
23121 forum posts
1360 photos
Posted by Tony Pratt 1 on 20/10/2019 12:21:57:
All works as intended […]
Looking good, Tony
Brian Oldford20/10/2019 19:50:18
686 forum posts
18 photos
. . . . . . the Nema24 stepper rated at 4 Nm is only giving 2.3 Nm so slightly underpowered, the supplier refunded the money & let me keep the motor.
Tony
Could you increase the torque by gearing down the motor?
Brian Oldford20/10/2019 19:52:21
686 forum posts
18 photos
Posted by Phil Grant on 20/10/2019 09:58:34:
All the images are good for me now. PCB looks good. What is the power rating of the resistors you have used?
Phil Grant20/10/2019 19:52:32
107 forum posts
21 photos
Posted by Frances IoM on 20/10/2019 12:31:33:
I will have a look at using the album feature.
Although it's the first time I've had issues with Dropbox links on forums
Phil Grant20/10/2019 19:55:46
107 forum posts
21 photos
Posted by Brian Oldford on 20/10/2019 19:52:21:Posted by Phil Grant on 20/10/2019 09:58:34:
1/8W to get them small enough.
Phil Grant21/10/2019 08:15:33
107 forum posts
21 photos
Created a new thread with pictures using the Forum Album method, hope you can now see the images.
Michael Gilligan21/10/2019 08:25:35
23121 forum posts
1360 photos
Thanks a lot for that, Phil yes
Your Album images are fine ... I am evidently unworthy to view your Dropbox
Tony Pratt 121/10/2019 09:30:47
2319 forum posts
13 photos
Posted by Brian Oldford on 20/10/2019 19:50:18:
Tony
Certainly could, but call me old fashioned if the motor is advertised at 4 Nm I would expect to get that value, I'm now going with a Nema 23 again rated at 4 Nm from 'CNC4U', hopefully it will deliver the quoted power!
Tony
