A most unusual metal
Part of an electrical connector
Michael Gilligan18/09/2017 07:46:58
23121 forum posts
1360 photos
Being rather intrigued by Ian's findings ... I searched for relevant patents, and found this:
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2672681A&KC=A&FT=D&ND=&date=19540323&DB=&locale=
... But I don't think that process would qualify as easy soldering with ordinary 60/40
Pehaps Ian's quickness of hand left the surface sufficiently free of oxides that the solder adequately wetted the surface without the use of benzoic acid.
Ian Parkin18/09/2017 08:12:42
1174 forum posts
303 photos
Could it possibly be pure tin?
easy to wet ..low melting point..silver in colour..
does it shriek?
Martin Kyte18/09/2017 09:33:38
3445 forum posts
62 photos
Backshells are usually die cast zinc overplated with nickel when they are not metalised plastic. Zinc solders easily.
regards Martin
Ian P18/09/2017 10:16:55
2747 forum posts
123 photos
Last night I filed through the plated surface (definitely plated because there is layer of copper) and exposed the base material. Later today I will see how easily it tins after being exposed for several hours.
The casting is what I would call finely detailed, its mostly about 0.30mm thick yet where the two edges of the clamshell meet there is a male/female stepped joint.
I dismissed the idea of it being Tin because of the cost, also they would not have needed to plate the surface.
All in all a bit of a mystery.
Ian P
Martin Kyte18/09/2017 10:42:20
3445 forum posts
62 photos
As I said, Zinc.
Martin
Neil Wyatt18/09/2017 13:18:36
19226 forum posts
749 photos
86 articles
I read the first page and was going to say 'surely it's just zinc'... but I won't bother now.
Martin Kyte18/09/2017 13:49:20
3445 forum posts
62 photos
"Could I just say it's zinc?".
. . . . . . "No sorry there isn't time"
(on loan from Monty Python)
Ian P18/09/2017 15:50:41
2747 forum posts
123 photos
I never thought in might be plain Zinc. Not that I know much about Zinc other than its used in galvanising but I thought it was very soft whereas this is hard and brittle (it is a cast part though).
Oddly in some previous replies Zinc is not perceived as being easily solderable.
Again odd is the fact that it is plated, as its is easily soldered and never ever going to be seen, why bother to plate it.
Ian P
Martin Kyte18/09/2017 16:19:24
3445 forum posts
62 photos
Have a look at this data sheet
It's plated to look nice and shiny. Zinc is used for sacrificial anodes on canal craft and is similar to aluminium regarding softness, gets quite malleable if heated to 200 deg C and solders easily as you discovered.
regards Martin
Ian P18/09/2017 16:28:30
2747 forum posts
123 photos
Posted by Martin Kyte on 18/09/2017 16:19:24:
regards Martin
Well I never!
I've been involved with electronics for too long and yet never been aware that straight Zinc was used for mechanical parts like these. This one is obviously Zinc so wood and trees come to mind.
IanP
Neil Wyatt18/09/2017 17:15:52
19226 forum posts
749 photos
86 articles
We used to have a zinc can opener, much bulkier than a pressed steel one.
I think it's in one of my scrap boxes... hmm I may have a use for it...
vintagengineer18/09/2017 20:56:28
469 forum posts
6 photos
This might be the same crap that SU carburettors are made of. I tried TIG welding one and got large quantities of blue smoke, a sign of zinc.
Vintage car ali castings are full of zinc due to it being cheaper than ali and you can add it to molten ali to bulk it out
Posted by Phil Whitley on 17/09/2017 13:00:43:
Probably Zamac, or some such zinc/aluminium alloy used for die casting, commonly known as "monkey metal", because of its fondness for falling to pieces after a couple of years, or when stressed beyond its very limited limits! Its great advantage is that it is ridiculously CHEAP!laugh
Michael Gilligan18/09/2017 21:37:45
23121 forum posts
1360 photos
Martin,
I bow to your wisdom, but I remain absolutely astonished that die-cast Zinc [whether pure, or an alloy] can provide sufficient structural integrity for the shell in question:
[quote] The casting is what I would call finely detailed, its mostly about 0.30mm thick yet where the two edges of the clamshell meet there is a male/female stepped joint. [/quote]
P.S. ... This is the best statement I can find on the matter of wall-thickness:
Wall Thickness
Zinc alloys have excellent casting properties, which means that thin walled cross-sections are possible. Zinc diecastings are often cast to a thickness of 1mm, with thinner sections possible depending on the flow of material to that area. Thin walled casting has a superior strength to weight ratio, thus strong and light zinc diecastings can be designed using the minimum of metal. This also improves the production rate and lowers cost.
**LINK** http://www.pmsdiecasting.co.uk/technical/for-designers/
Bazyle18/09/2017 22:44:23
6956 forum posts
229 photos
Gosh this is going on and on. When corgi and dinky and matchbox cars started being made out of plastic all the muck metal had to be used for something wink
Michael Gilligan18/09/2017 23:30:26
23121 forum posts
1360 photos
Fair comment, Bazyle
... But 0.3mm wall thickness is very impressive.
Martin Kyte19/09/2017 09:13:59
3445 forum posts
62 photos
Posted by Neil Wyatt on 18/09/2017 17:15:52:
I've got a tin can opener !
The other interesting thing about zinc is it screams when you bend it cold.
regards Martin
Russell Eberhardt19/09/2017 09:56:49
2785 forum posts
87 photos
Posted by Martin Kyte on 19/09/2017 09:13:59:
So do I laugh
Russell
