JasonB | 19/05/2017 12:22:32 |
![]() 25215 forum posts 3105 photos 1 articles | Did you not see my link above to the Rocol that is available in teh UK |
SillyOldDuffer | 19/05/2017 12:33:11 |
10668 forum posts 2415 photos | Couple more photos to look at. They're the same mild steel plate at different angles to the light. The plate was degreased and wiped with meths. From left to right they are:
When the plate is rubbed with kitchen paper, all the felt tip markings come away within 8 strokes. The Dykem is still solid after another 8, but the unbranded layout blue is beginning to show signs of wear. So for best density and wear resistance buy the real thing BUT a decent felt tip is good enough for most work. You may need to experiment before finding a good felt tip. Dave |
Hopper | 19/05/2017 12:36:53 |
![]() 7881 forum posts 397 photos | Posted by petro1head on 19/05/2017 11:24:56:
Posted by Hopper on 19/05/2017 11:04:38:
As someone mentioned, there is a spray can layout blue dye called Dykem that is widely available. Google Dykem layout fluid and you should find it locally. Really, hmm, I challenge you to find some spray available in the UK Why would I bother? It's not my problem. Best of luck with the search. (And with using the "cream" for layout work. Edited By Hopper on 19/05/2017 12:38:34 |
petro1head | 19/05/2017 13:21:54 |
![]() 984 forum posts 207 photos | Posted by JasonB on 19/05/2017 12:22:32:
Did you not see my link above to the Rocol that is available in teh UK Missed it Jason, thanks
JasonB | 19/05/2017 13:23:05 |
![]() 25215 forum posts 3105 photos 1 articles | I see the spray version DOES NOT comply with EU regs so looks like you won't find it locally in the UK or Europe. No problem getting teh Rocol one. |
petro1head | 19/05/2017 13:29:41 |
![]() 984 forum posts 207 photos | Posted by JasonB on 19/05/2017 13:23:05:
I see the spray version DOES NOT comply with EU regs so looks like you won't find it locally in the UK or Europe. No problem getting teh Rocol one. That would explin it. I have found some Rocol on ebay **LINK** which is about £6 cheaper than the link due to having to add VAT and delivery bringing it to over £40. Thanks again Jason for pointing me towards Rocol Edited By petro1head on 19/05/2017 13:30:19 |
JasonB | 19/05/2017 13:32:39 |
![]() 25215 forum posts 3105 photos 1 articles | Do you really need a spray? how big are the areas you want to cover? a bit of foam on a stick or even a folded rag will cover a large area quite easily |
petro1head | 19/05/2017 13:40:50 |
![]() 984 forum posts 207 photos | Posted by JasonB on 19/05/2017 13:32:39:
Do you really need a spray? how big are the areas you want to cover? a bit of foam on a stick or even a folded rag will cover a large area quite easily Prob not but will find it more usefull than what I currently have |
mgnbuk | 19/05/2017 14:12:37 |
1394 forum posts 103 photos | Or Cromwell Industrial Supplies if there is one near you |
Hopper | 19/05/2017 22:08:29 |
![]() 7881 forum posts 397 photos | I just use whatever spray paint I have kicking around the shed. Blue hammertone works well. If you don't prep the surface it wipes off afterwards with acetone, thinners or whatever is around and a bit of elbow grease.. |
Neil Wyatt | 19/05/2017 22:27:04 |
![]() 19226 forum posts 749 photos 86 articles | Sharpie for laying out small things, spray primer for big things - dries quicker tahn topcoats. Stuart's Micrometer blue for my rare excursions into 'scraping'. Neil |
Bob Stevenson | 20/05/2017 00:10:02 |
579 forum posts 7 photos | Earlier this evening I was glancing thru a 'Tilgear' catalogue that is about 15 years old and wedged under the top of a bench.....it showed Edding 850 blue permanent marker for metal marking. The tip is (was?) 18mm wide and they had refills of the blue ink available. |
OuBallie | 20/05/2017 10:59:24 |
![]() 1181 forum posts 669 photos |
Tip is 1/2" wide. Geoff - Works fine for my needs. Edited By OuBallie on 20/05/2017 11:00:11 |
Hopper | 20/05/2017 11:32:06 |
![]() 7881 forum posts 397 photos | Posted by Neil Wyatt on 19/05/2017 22:27:04:
... spray primer for big things - dries quicker tahn topcoats.... ...^^^^ That's why he's the editor. |
Neil Wyatt | 20/05/2017 13:08:40 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Hopper on 20/05/2017 11:32:06:
... spray primer for big things - dries quicker tahn topcoats.... ...^^^^ That's why he's the editor. If I spend my working hours editing other people's writing, I'm blowed if I will waste my leisure hours editing my own! |
Douglas Johnston | 16/07/2019 11:04:46 |
![]() 814 forum posts 36 photos | I have been trying out some scraping lately and saw on youtube that some people use a roller on the surface plate to spread the blue indicator over the surface. I was thinking about trying that but can't find any reference for the type of roller needed. There seem to be hard rubber rollers and soft rubber ones and probably ones in between. Is there a scraping mastermind out there that can recommend a suitable type of roller? Doug |
Bill Pudney | 16/07/2019 11:26:43 |
622 forum posts 24 photos | My experience of scraping goes back to my apprenticeship in the 60s. Way back then the best results were had with a VERY light application of blue, it seems to me that any sort of roller would put on far too much. But I may be wrong, it has happened before according to The Boss. cheers Bill |
Lainchy | 16/07/2019 11:32:09 |
![]() 273 forum posts 103 photos | What sort of mix of Meths and Micrometer blue? Does it actually set then? It's very oily as stock... just wondering if I can mix some before buying Dykem |
Keith Long | 16/07/2019 11:52:03 |
883 forum posts 11 photos | Seems to me that folk here are confusing two totally different products. One "engineers blue" or "layout blue", which dries to a film that them can be scribed through so that layout marks show up, and "micrometer blue" which is a greasy blue paste, doesn't dry as far as I know but remains as a greasy blue film, and which is used to determine fits between mating surfaces and in scraping. The latter would be of no use for marking out as it will rub off very easily (if messily), while the layout blue (or felt tip pen) can be used to find interference between parts as well as used for marking out. |
SillyOldDuffer | 16/07/2019 12:18:43 |
10668 forum posts 2415 photos | Posted by Lainchy on 16/07/2019 11:32:09:
What sort of mix of Meths and Micrometer blue? Does it actually set then? It's very oily as stock... just wondering if I can mix some before buying Dykem Not critical. My sample was mixed in an eggcup with a blob of Stuart's on the end of a table-knife. The dye is almost certainly Methylene Blue which dissolves readily in alcohol. Stuart's slow-drying paste is formulated stiff for scraping, but adding Meths thins it down considerably and it becomes quick drying. You can experiment for best results. Not as good as real marking blue or a decent felt tip, but worth a try. My tiny tin of Stuart's looks as if it will last me forever and I didn't feel bad about repurposing some of it. In theory it should be possible to dissolve ball-point pen ink in the same way. In practice, more trouble than it's worth! Dave Edited By SillyOldDuffer on 16/07/2019 12:19:34 |
