Where to buy cnc drills in UK
Roderick Jenkins02/01/2017 20:29:33
2376 forum posts
800 photos
I've had good service from these people: Phantom. They seem quite happy with small, irritating orders. I was after a selection of one off stub drill sizes. Placed an order on the website on a Sunday and a jolly lady rang me up on the Monday to apologise and say they were out of stock of a couple of items and would I mind waiting till Wednesday for despatch? I just went for the basic HSS but Co steel and carbide are also options.
HTH,
Rod
Michael Gilligan02/01/2017 20:36:03
23121 forum posts
1360 photos
Rod,
Those look remarkably good prices ... Have you tested them yet?
... Always good to support firms that provide decent service.
Roderick Jenkins02/01/2017 20:46:44
2376 forum posts
800 photos
Not to destruction wink
They seem fine, look nicely made and finished but only time will tell. I think they are good enough for my use - I decided to take the plunge and get a set of stub drills to match my (controversial?) tapping table. They worked fine on the bronze boiler bushes I made yesterday (as did my Carbon Steel taps surprise).
Cheers,
Rod
MW02/01/2017 21:04:00
2052 forum posts
56 photos
Posted by Roderick Jenkins on 02/01/2017 20:46:44:
Cheers,
Rod
What could possibly be controversial about a tapping table? (other than maybe a rude engraving into it)
Michael W
Edited By Michael-w on 02/01/2017 21:04:29
Michael Gilligan02/01/2017 21:40:58
23121 forum posts
1360 photos
They seem fine, look nicely made and finished but only time will tell. I think they are good enough for my use - < etc. >
That'll do for me, Rod
Hopper03/01/2017 04:08:38
7881 forum posts
397 photos
For drilling brass you might want to look for some 2mm fast helix drill bits. The lesser angle on the helix means a lesser clearance angle at the cutting edge, so it does not tend to dig into the brass so much, which is what can snap small drills in brass. Or with so many holes to drill, how about straight flute carbide drill bits?
Andrew Johnston03/01/2017 10:27:31
7061 forum posts
719 photos
Posted by Hopper on 03/01/2017 04:08:38:
That's odd, I use slow helix drills for brass.
Ian S C03/01/2017 11:27:24
7468 forum posts
230 photos
I think that's what he means Andrew. Once apon a time you could buy straight fluted drills just as easy as helical ones.
Ian S C
Andrew Johnston03/01/2017 11:49:54
7061 forum posts
719 photos
Posted by Ian S C on 03/01/2017 11:27:24:
I have a vague recollection of straight flute drills as a kid, but sadly they don't seem to be available now; pity. sad To be precise, you can buy straight flute drills, but they seem to be carbide, stub, and intended to drill hardened steels up to 65Rc.
john dakin03/01/2017 12:26:17
44 forum posts
2 photos
So what sort of speed should I be running at to drill 2mm holes into 3mm thick brass
Tony Pratt 103/01/2017 12:49:20
2319 forum posts
13 photos
Plenty of info on Google, one calculator says 10K plus [HSS drill], not many M/C's will do this straight out of the box so just run as fast as you cansmiley
Tony
Edited By Tony Pratt 1 on 03/01/2017 12:50:16
Mike Poole03/01/2017 12:51:31
3676 forum posts
82 photos
14,000rpm for HSS, 50,000rpm for carbide, flat out unless you some exotic high speed spindle.
john dakin03/01/2017 12:53:15
44 forum posts
2 photos
Thanks, my max rpm is 25,000
MW03/01/2017 12:53:37
2052 forum posts
56 photos
Posted by john dakin on 03/01/2017 12:26:17:
As fast as you can get the machine, but I have had a small mill designed for small work and that usually used 10,000rpm.
The formula I have calculated for a conservative estimate on brass at 90 metres per minute, for a 2mm drill was around 14,500rpm.
I would say this only really shows how fast you can get the drill into the workpiece, you could go very slow but you'd need less pressure on the drill. Too much pressure and you're going to be forcing a very fragile bit into the face of the work with little cutting action taking place, that's why it breaks. You could grind a steeper lead angle onto the drill, which is what sheet metal workers used to do in the past to relieve pressure on the cutting tip. The angle on most drills is around 112-115 degrees, which is only a general purpose angle, a steeper angle of say 80 degrees might be more suitable for softer materials.
PS.everyone beat me to it :P
Michael W
Edited By Michael-w on 03/01/2017 12:57:20
john dakin04/01/2017 08:12:35
44 forum posts
2 photos
80 metres per minute seems too fast, did you mean feet per minute
john dakin04/01/2017 08:13:06
44 forum posts
2 photos
I meant 90 metres per minute
John Reese05/01/2017 04:38:11
1071 forum posts
Brass has a tendency to pull the drill into the work unless the drill is modified for zero rake. Could that be contributing to your problem? To modify a drill stone the cutting edges. See video.
https://www.youtube.com/watch?v=pAngKHIZgyA
