graphite bushes/bearings ?
Danny M2Z22/02/2016 10:53:58
963 forum posts
2 photos
Posted by roy entwistle on 22/02/2016 10:40:04:
Michael W Seeing that both carbon and copper are conductors How would a moving part make any difference How would there be any chance of electric shock ?
Lol, second that.
* Danny M *
Edited By Danny M2Z on 22/02/2016 10:54:37
Circlip22/02/2016 11:12:18
1723 forum posts
And don't forget, most Nylons are hygroscopic so clearance can be affected. Don't apply to Carbon Carbon/Copper.
Regards Ian.
MW22/02/2016 11:39:03
2052 forum posts
56 photos
you can mock me if you like but i know we live in a world of possibilities, no matter how unlikely it might seem. I believe coarse humour is detrimental not only to the recipient but to the mocker themselves.
Michael W
Joe Page22/02/2016 12:33:55
37 forum posts
10 photos
I bought some graphite rod from these;
Seems to be good quality and machines nicely, I have about 6" of it left, if your in the Sheffield area you can have half of it for free.
Otherwise I used to machine carbon or graphite impregnated PTFE, should be quite easy to get hold of. Seal manufacturers may give you some, or fluorocarbon uk make it, or GAPI uk will stock it. It's not hydroscopic, very easy to get a good finish and has little thermal expansion.
As Circlip says, do not use any nylon it will expand when the moisture hits it, normally about 1-2%.
roy entwistle22/02/2016 12:43:59
1716 forum posts
Michael No one was mocking you It was a straight forward question
Russell Eberhardt22/02/2016 14:02:28
2785 forum posts
87 photos
My reason for mentioning that some motor brushes contain copper is that copper is very poor as a bearing material and may result in too much friction.
Nothing to do with electrical conductivity!
Russell;
jason udall23/02/2016 20:58:05
2032 forum posts
41 photos
I suspect the "worry" of M W. Was over electrostatic concerns
One ) graphite -carbon- and brushes for motors all conduct rather well and in electrostatic terms equally.
Two graphite vs motor brushes..
Firstly motor brushes are not fixed composition. .they are blends of graphite /binder /copper/ rarely now lead.
If one lucked out one might get a low copper brush and it might have good/excellent friction behaviour.
In low temp difference stirling engin there is on this scale little torque so along with good seal we also need lowest friction achievable. .this is part of why these low temp difference engins are largely recent due to material availability.
mgnbuk24/02/2016 10:02:23
1394 forum posts
103 photos
I raised the subject at work today and, as previously, the cost of processing such a small order is deemed to be much higher than the cost of such a small piece of graphite, so not really viable.
But I can supply a piece (the offcut to hand is approx. 14 x 20 x 85mm fine grained isostatic graphite) FOC subject to receiving pictures / a video of the completed engine which the company might use on it's website as a "general interest" application story.
If that is acceptable, PM me your address details & I'll post the piece out (the company will provide the graphite & I will stand the postage).
Nigel B.
(edit for typo)
Edited By Nigel B on 24/02/2016 10:03:16
Ian S C24/02/2016 12:09:09
7468 forum posts
230 photos
Been doing a bit of hunting, found this. JC4 grade, strong, fine grain, machinable. Another one is Poco grade carbon, this one contains copper. Then EDM grade.
G.E. Howell sell's it by the inch, 3/8"D, 5/8"D, 1"D, at $1, $1.50, $2.50, this is for pistons.
Ian S C
