Margaret Trelawny | 24/09/2023 12:15:32 |
100 forum posts 42 photos | Hello again everyone, So the continuing saga (farce!) with fitting a QCTP to my lathe continues. I sourced a stud from Little Machine Shop in the US and it fits right over my standard stud - it has a M8 tapped internal thread which works perfectly. So I fit it, and slide on the QCTP and try on the locking flange nut at the top - and guess what!?!? Yep / it doesn’t fit!!! The one supplied in the arceuro QCTP is 14mm (9/16 UNF) and the LMS stud needs a 9/16-18 flange nut - seriously- you could not make this up! Can anyone help me please with a 9/16-18 flanged nut? To buy one from the US is circa $25 plus about the same post. I cannot justify that. Any suggestions most gratefully accepted. Fed up doesn’t come close! Many thanks m |
John ATTLEE | 24/09/2023 12:32:05 |
49 forum posts | Dear Margaret, I will have 9/16th dia FULL nuts but I think that they will be BSF. I may also have a 9/16th UNF tap. I will check what I have got later this afternoon or tomorrow morning. Don't despair! John |
Margaret Trelawny | 24/09/2023 12:37:50 |
100 forum posts 42 photos | Dear John Thank you so much. I am not sure what 9/16-18 (UNF or whatnot) means but it’s what the LMS stud is threaded with.
Best wishes M |
Nigel Graham 2 | 24/09/2023 13:05:08 |
3293 forum posts 112 photos | 9/16 inch outside diameter of the thread, 18 threads per inch; UNF stands for Unified National Fine and is one of the American "UN" series industrial standards for screw-threads. UN-series threads were fitted to a lot of motor-vehicles and military equipment in the UK at one time and the fastenings are available here; though perhaps not flanged nut. You might even be able to obtain one from a garage! It does not need be flanged though - use an ordinary full nut and a thick washer. |
Michael Gilligan | 24/09/2023 13:08:25 |
23121 forum posts 1360 photos | 9/16 BSF has 16 threads per inch and a 55° thread form 9/16 UNF has 18 threads per inch and a 60° thread form I suggest you need to use the correct nut MichaelG. . Post crossed with Nigel’s Edited By Michael Gilligan on 24/09/2023 13:09:34 |
Tony Pratt 1 | 24/09/2023 13:32:59 |
2319 forum posts 13 photos | 9/16 UNF nuts are readily available in the UK. Tony |
Diogenes | 24/09/2023 13:34:31 |
61 forum posts 6 photos | What size are H-D cylinder base / head stud nuts? |
JasonB | 24/09/2023 13:34:59 |
25215 forum posts 3105 photos 1 articles | I'm not sure how important it is to have a flanged nut, you could turn up a thick washer and use that in place of the flange with a plain nut on top, not too expensive |
Michael Gilligan | 24/09/2023 13:43:10 |
23121 forum posts 1360 photos | There are loads of 9/16 UNF nuts on ebay.co.uk With or without flanges, and a few interesting ‘specials’ list them with cheapest with p&p first …and take your pick [ some are ‘stiff-nuts’ … which may, or may not, be useful ] MichaelG. |
peak4 | 24/09/2023 13:59:15 |
2207 forum posts 210 photos | Posted by Margaret Trelawny on 24/09/2023 12:15:32:
.............. The one supplied in the arceuro QCTP is 14mm (9/16 UNF) and the LMS stud needs a 9/16-18 flange nut - seriously- you could not make this up! Can anyone help me please with a 9/16-18 flanged nut? To buy one from the US is circa $25 plus about the same post. I cannot justify that. Any suggestions most gratefully accepted. Fed up doesn’t come close! Many thanks m Margaret, I think you're getting your threads a a bit mixed up. |
Clive Foster | 24/09/2023 14:02:08 |
3630 forum posts 128 photos | From what I've seen of industrial machines common practice with Dickson QCTP is to use a plain nut, a thick washer and a thick wall spacer loosely spigoted into the toolpost bore. The spacer being needed to lift the nut above the tool clamp screws. I do know of folk whose opinion I have reason to respect advocating a second, standard thickness, washer under the nut in addition to the aforementioned thick one. I have never seen a flange nut used. My instructors said that the sole use for flange nuts in a machine shop was with mill table clamping kits. I imagine the reasoning behind the use of a thick washer on top of the spacer was to spread any twisting loads as the nut was pulled down tight so the post itself doesn't try to turn. Observation of the Dickson set-up on my big Pratt & Whitney lathe seems to support this idea as both washer and spacer turn slightly with the nut on final tightening but lag. So the top washer turns less than the nut and the spacer less than the washer whilst the post says still. The turn angles are small, little more than barely enough to see and probably wouldn't be visible on smaller machine where the tightening torque is proportionally less. I don't use a locating pin or underneath ratchet on my tool posts but I do require that the post sides stay in alignment with lathe cross slide and bed. Whether the distribution of frictional forces to reduce the chance of a toolpost turning actually matters in practice I know not. I don't recall any such post twisting effects when using a simple standard washer under the nut of the tool post stud on my SouthBend lathes. Simple hand holding worked just fine. Clive |
Nicholas Farr | 24/09/2023 14:05:28 |
3988 forum posts 1799 photos | Hi, they are also available from Spalding Fasteners. If it was me choosing one, I'd go for the yellow one. A thick washer can easily be made from a piece of flat steel, cutting it out with a suitable size hole saw, and then drilling the hole for 9/16" clearance, and then just tidy it up with a file. Regards Nick. Edited By Nicholas Farr on 24/09/2023 14:07:09 |
Martin Connelly | 24/09/2023 14:09:41 |
2549 forum posts 235 photos | If you don't have thread gauges then a standard M10 stud or screw will have a 1.5mm pitch. If you have one you can check it against your unknown thread like using a thread gauge to see if it is also a 1.5mm pitch thread. An M10 thread will not match an 18 TPI imperial thread form. Martin C |
Margaret Trelawny | 24/09/2023 14:10:01 |
100 forum posts 42 photos | Hi all, thanks for your replies. I agree a non-flanged nut with a thick washer would probably be fine. can’t remember which chap said 9/16-18 are readily available in the UK - I have not been able to find any. Would you be kind enough to post a link please? many thanks m |
Margaret Trelawny | 24/09/2023 14:15:04 |
100 forum posts 42 photos | Nicholas - thanks for the link to Spalding.
are these 9/16-18? Seems to suggest so in the spec if I am reading it corrext. Apologies for the seemingly naieve reponse but I have no engineering knowledge at all.
many thanks M
Michael Gilligan | 24/09/2023 14:20:44 |
23121 forum posts 1360 photos | Posted by Margaret Trelawny on 24/09/2023 14:10:01:
Hi all, thanks for your replies. I agree a non-flanged nut with a thick washer would probably be fine. can’t remember which chap said 9/16-18 are readily available in the UK - I have not been able to find any. Would you be kind enough to post a link please? . As recently stated: There are loads of 9/16 UNF nuts on ebay.co.uk With or without flanges, and a few interesting ‘specials’ list them with cheapest with p&p first …and take your pick [ some are ‘stiff-nuts’ … which may, or may not, be useful ] . Do you need a link to an ebay search ? … I think this might do it: https://www.ebay.co.uk/sch/i.html?_from=R40&_nkw=9%2F16+unf+nut&_sacat=0&_sop=15
MichaelG. Edited By Michael Gilligan on 24/09/2023 14:23:20 |
Tony Pratt 1 | 24/09/2023 14:23:50 |
2319 forum posts 13 photos | Just Google search 9/16" UNF nuts Tony |
SillyOldDuffer | 24/09/2023 14:27:50 |
10668 forum posts 2415 photos | Posted by Margaret Trelawny on 24/09/2023 12:37:50:
Best wishes M I recommend buying a copy of Tubal Cain's "Model Engineer's Handbook" (Link is to Waterstones' - other suppliers available. Many 'what-nots' are explained! Margaret has bumped into the 'which standard system' problem, and it's worth thinking about. Briefly:
So British Model engineers setting up a workshop have choices! My view:
Pays to standardise if you can. In practice, it's hard not to work with all these systems occasionally. I do experimental work, where Metric is wonderful, and almost everything I own is standard metric. Imperial repairs aren't the end of my world, except I have to recognise what's needed and do the conversions. However, Imperial is a time-waster compared with the same job in Metric, because I often have to buy or make stuff specially. Metric jobs turning up in Imperial workshops are a similar nuisance. Whatever you do, don't get Metric vs Imperial vs US substantially the wrong way round! Dave PS Flange Nuts are ordinary nuts with a built in washer, so you don't have to worry about losing the washer. If a flange nut can't be found, a washer and ordinary nut work just as well. Also, flange nuts often come with ridged bottoms designed to grip: don't use this type on a QCTP without a washer underneath, or file the ridges smooth first! Edited By SillyOldDuffer on 24/09/2023 14:38:48 |
Margaret Trelawny | 24/09/2023 14:46:36 |
100 forum posts 42 photos | Guys, I’m getting more and more confused (doesn’t take much!) As mentioned in my opening post - the arceuro 111 QCTP is supplied with (according to their catalogue) a flanged nut specified as 14mm (9/16 UNF). The toolpost stud from LMS is specified on their website as having a 9/16-18 thread. to recap - the nut supplied with the 111 QCTP (specified as 14mm (9/16 UNF) WON’T FIT this stud. So if I buy a 9/16 UNF nut surely it’s going to be the same as the arceuro nut? Or am I missing something?
Thanks all M |
Frances IoM | 24/09/2023 14:57:05 |
1395 forum posts 30 photos | do you not have a thread gauge - cheap + resolves such problems - the combination 14mm + 9/16 should indicate something is very confused |
