machine lighting
Anna 113/02/2016 14:55:17
72 forum posts
3 photos
Hi, all, I wonder if the following is of interest.Despite having good natural and fluorescent lights in my workshop I was struggling to see well at my machines. I looked at the available ready made machine lights but couldn't find any that were bright enough. I went on line and found a range of LED "vehicle work lights"as fitted to tractors etc. The ones I settled on are 24v, 27watts about 4"square and are made as a heavy diecasting and are waterproof.The light output must be around the light output of a 200W traditional light bulb. all for about £10 each ( I bought 4) I had intended to fit them to goose necks but they are too heavy for that so fitted one each under shelves above above the lathe and grinder (have yet to do the mill) They are mounted on drawer runners so they can be positioned /swivelled how I want. Maplins do a range of 24v power supplies the ones I chose will drive 2 lights.and are about £20 each. Pictures are in my folder
Kind regards Anna
Harry Wilkes13/02/2016 15:40:47
1613 forum posts
72 photos
Hi Anna
I have a couple of these link which I find ok,
H
Johnboy2513/02/2016 15:46:30
260 forum posts
3 photos
I have a couple of these too - bought off eBay at a reasonable price. Their small enough to manipulate it to where you need the light especially when internal boring. They run on next to nothing giving a good colour temperature white light and don't get unduly hot.
Edited By Johnboy25 on 13/02/2016 15:47:59
Anna 113/02/2016 15:58:31
72 forum posts
3 photos
Hi john,
they seem to be perfect for what we are doing, especially the low voltage when cutting fluids might be flying around
kind regards Anna
Ajohnw13/02/2016 16:30:09
3631 forum posts
160 photos
I've found these from Ikea ideal. Wiring to be tidied up. It's fitted with a led light. I also have one for the miller. They can be clamped to a shelf or fixed to a wall etc.
blushThings are little tidier now but still more to do.
NJH13/02/2016 17:16:13
2314 forum posts
139 photos
Leave it as it is John - I find it quite encouraging! 😉
Norman
Terry olds13/02/2016 19:35:56
28 forum posts
14 photos
can anybody say which Maplins Transformer it is to power two of these lights
Terry
Neil Wyatt13/02/2016 19:47:45
19226 forum posts
749 photos
86 articles
Interesting. A lot of choice of styles and powers too. The ones claiming to have Cree LEDs seem a bit overpriced though!
Anna 113/02/2016 20:59:20
72 forum posts
3 photos
Hi, Terry, RE. power supplies the maplin code is N10NB £19-99 24v 65w
Purchase only online
Hope that helps
kind regards
Anna
Anna 113/02/2016 21:07:24
72 forum posts
3 photos
Hi, Terry, just had a thought
Obviously if you choose lights of even higher wattage than the ones I bought ,you need to match and buy the appropriate power supply
Anna
Anna 113/02/2016 21:10:29
72 forum posts
3 photos
Anna
Terry olds13/02/2016 21:24:19
28 forum posts
14 photos
thanks for that,,
Anna 113/02/2016 21:26:54
72 forum posts
3 photos
Hi, Terry, again, an even better choice would be code N9NB, it has a built in power lead, but you will have to put on your own plug, same price and power
Anna
Ajohnw13/02/2016 21:28:34
3631 forum posts
160 photos
I also have a couple of the Ikea lights linked to earlier. I find them pretty hopeless for situations like mine were the lighting levels are pretty high - 50w efficient 5ft strip light on a rather high ceiling (10ft) and a little behind me when I am on the lathe. The ceiling height dims these down. The ones I linked to provide a decent sized pool of light. The stalk ones at the distance needed for that hardly provide any extra light at all. I also found that they need too much fiddling about and the light rather close to the work.
I can shorten the wire to the light Norman. Using mains doesn't bother me providing the cables are safely out of the way. As to the tidy up a builder was supposed to be about to make some changes with walls post xmas so I have delayed totally sorting things out. No builder so far. At the moment I couldn't do any work if I wanted too. Increasingly I do want to do some so will have to find some hopefully short term solutions to having too much gear none of which I want to get rid of.
Johnboy2513/02/2016 21:34:26
260 forum posts
3 photos
Hi.. If you're going for LED lighting you would only need a power supply with a 1/10 of that mentioned. 65 Watts would fine for halogen lamps. Just a thought....
Anna 113/02/2016 21:48:37
72 forum posts
3 photos
Hi, John,
I tried 80 watt mains halogen above the lathe and it just wasnt enough, maybe it is just old age catching up.
If you look at the pictures which were taken in good daylight you can see the nice even beam of light from
the leds
kind regards
Anna
Nick_G13/02/2016 23:51:14
1808 forum posts
744 photos
I am not a fan of LED lights in the workshop. I find the 'quality' of the light harsh and not a nice colour temp. They are however getting better as the development and technology improves.
I have 2 spotlights with a GU10 lamp fitting over each machine spaced apart with the beams crossing to avoid shadow areas as much as possible. This is in addition to the flou fittings providing general workshop lighting. - I purchased LED GU10 lamps to fit into these spotlights. However I quickly changed them back to the original filament type lamps. They are not as economical but IMHO are a much nicer light output to work under.
Nick
Ajohnw14/02/2016 00:10:26
3631 forum posts
160 photos
These are the Ikea lights I use
They do other forms with the same shade using the same led e14 bulb. As it's a spot light I find they need to be about 50 - 60cm from the machine bed. As you can see in the photo they add considerably to the lighting levels in the room which are actually rather high.
Sounds like Anna needs her pupil size reducing to pin pricks in order to see well. I need 1 1/2 dioptre reading glasses but for perfect vision at 250mm at "normal" illumination levels I need around 3. If I wore those a lot my eyes would weaken further so they only come out when needed. I find these lights just about right wearing the reading glasses. My distance vision is fine.
Noticing harsh lighting comments I think it depends on the colour temperature of the led's. Stick to 2700 to 3000k and they are ok. The higher colour temperature ones put out an immense amount of blue light - more than normal levels as the blue they use is in a regions our eyes are not all that sensitive to. There are some eye safety concerns about higher colour temperature leds down to high levels of the blue as well. The blue also makes the light output figure look better than they really are.
Edited By Ajohnw on 14/02/2016 00:15:45
Edited By Ajohnw on 14/02/2016 00:17:10
Neil Wyatt14/02/2016 09:50:43
19226 forum posts
749 photos
86 articles
I see Lidl has some free-standing LED reading lights for £19.99 that look pretty useful for armchair engineering
Anna 114/02/2016 10:20:25
72 forum posts
3 photos
Hi, A John W
Unfortunately I have had to wear glasses since childhood being shortsighted, in the order of 3.5 diopters but in recent years I have become more longsighted. certainly the early led were not a pleasant light, but they are improving fast.and the fact that the lights are waterproof and low voltage appealed to me, Of course one can choose a lower wattage worklight as there is a big range available for vehicles etc
Kind regards
Anna
