Member postings for Terry olds
Here is a list of all the postings Terry olds has made in our forums. Click on a thread name to jump to the thread.
Thread: forward/reverse switch from a forward only switch
14/03/2022 13:58:52
hi all , thanks for your input,
1, have reverse on my myfords7,, very handy
2, be handy to have reverse on the mill for extraction of broken bolts etc
3, Any1,, did like the switch on Ebay,,, need to sort the wiring out for it now,, i'e what I do and into which hole for the wirs
13/03/2022 15:31:22
Diagrams of the connection box to help. and motor labal info
13/03/2022 12:51:00
No diagram on the inside of the lid, no letters or numbers on the grommet beside the wires, will be checking the number of wires from the motor to the terminal block
13/03/2022 12:24:54
That tells our age
13/03/2022 12:04:40
dscf0307.jpgdscf0305.jpgdscf0304.jpgdscf0303.jpgdscf0312.jpgdscf0311.jpgdscf0310.jpgdscf0309.jpgdscf0315.jpgdscf0313.jpgdoes this help
12/03/2022 19:58:15
Have an Alpine major 1982, would like to convert it from a forward only to a forward and reverse switch, can this be done
Thread: new to North Shropshire
08/08/2021 19:05:41
Sorry yes 2020
it not let me edit it now
Thread: WARCO MAJOR QUILL REMOVAL
08/08/2021 17:41:55
Not easy more by eye than anything else , but seems to be inline ,did use a big set squre I had, did it like Ewin White did it by eye, centre punch the rank, the if you take the head to the top of the column you can pull the rack out at the bottom and get a screw driver behind it to drill it 1/4 inch drill bit and not mark the column that way,, same with the top of the rack,, move the head down the column to pull the rack out at the top.
Then after counter sunk the holes, use a transfer punk to mark the column after you eyed it up,, you can lock the head if you like, but I did not , drill the column , this is a cast , so easy to drill, and then tap 1/4 as I did, or as you your case metric size, cleaned up and then put the c/s screws in, job done
Terry Olds
08/08/2021 16:20:55
hi Chris,
Have today fitted four 1/4 whit cs screws into the rack on my Alphine Major milling machine and tapped into the column 1/4 whit , it is a dm25 machine, will it say's that on the badge, did as per Edwin White video shows and it works ok,
If you google Edwin White it comes up and you see the video's available for column milling machines, they are on you tube to,, but did as per Ewin White, like I say works well for me , pleased with it,,
Terry Olds
08/08/2021 10:38:00
hi there, just aquired one of these machine,, badge as a' Chester machine tool' Alpine major' still soring it out but from the 1980'a I'd say, very little use.
Find this post very interesting indeed,    thanks
Edited By Terry olds on 08/08/2021 11:04:46
08/08/2021 10:03:51
Hi all
Not a new member but new to the North Shropshire area,
Moved here last February 2021 , then in March we got the lock down, so been an odd year, but got my workshop sorted.
Have a Myfords7 and a 'alpine major' milling machine , just aquired, so sorting that out.
Into steam engines and have done a few, but only self tight on this stuff.
Anybody in the area give a ring chat etc.
Terry Olds (Mods Edit) phone No removed to prevent spam.
Edited By Terry olds on 08/08/2021 10:22:31
Edited By JasonB on 10/08/2021 10:32:19
Thread: New Member for North Shropshire
22/07/2020 13:45:27
Hi, phil,, be great to meet up, be good to share our interests, next to the House & jockey Northwich. pm fpr phone number.
Terry
22/07/2020 06:16:16
Hi all, Just to say moved from Worcestershire and now in North Shropshire, Myford super 7 user and mainly restore steam engines back to life, be nice to meet other local members.
Terry Olds,
Northwood
Edited By Terry olds on 22/07/2020 06:17:37
Thread: Dickson type T00 toolholders
25/06/2019 09:59:22
HI, thanks for that, have found old phone number for them, but it not connecting, so yes, not about any more
Terry
25/06/2019 08:53:16
does this help
Name:
Lynam Engineering Ltd
Office Address:
Leofric House Binley Road CV3 1JN Coventry
Thread: Myfords7 bed regrind
08/06/2019 13:03:20
Hi all, bed needs regrinding and looking to see who does it, I am in Bromsgrove , so south of Birmingham
Thread: Help with Myford Saw Table?
14/11/2017 20:54:49
Have the saw table but no arbour,, can anybody help me with as myford s7 saw table arbour, or the measurements of it to make myself.
Edited By Terry olds on 14/11/2017 20:56:25
Thread: myford motor
02/04/2017 20:12:49
Thanks for all the info..working on it
31/03/2017 19:04:42
Can anybody help with who does motor repairs in or around Bromsgrove.
Thread: machine lighting
13/02/2016 21:24:19
thanks for that,,
