Member postings for Thor 🇳🇴
Here is a list of all the postings Thor 🇳🇴 has made in our forums. Click on a thread name to jump to the thread.
Thread: Steel for flywheel?
19/10/2022 17:44:14
Could you use a piece of 4" bright mild steel? If so MaccModels sell rods in lengths of 1", 2" and so on.
Thor
Edited By Thor 🇳🇴 on 19/10/2022 17:44:45
Thread: Stuart 10V rebuild
11/10/2022 12:07:50
Hi Jim,
Your 10V doesn't seem to be machined with much accuracy. I did machine the seatings for the bearings with square bottoms on mine (but I used stock material for the Soleplate, not the Stuart casting). For an engine that is not going to do heavy work brass should do as bearings material, I have used that on several of my models.
Thor
11/10/2022 11:20:23
Hi Jim,
I built a vertical steam engine based on the Stuart 10 Standard and Cylinder, see here, that you may find useful. Good luck with the rebuild.
Thor
Edited By Thor 🇳🇴 on 11/10/2022 11:29:17
Thread: Backplates
09/10/2022 11:01:55
Hi Chris,
Some chucks are directly mounted onto the lathe, placing the chuck closer to the spindle bearings. So the chuck will only fit a lathe with the correct type and size of mount. Something like this (from Ajax):
Many chucks needs an adapter plate (backplate). As long as you can find a backplate that fits your lathe you should be able to mount the chuck on your lathe. Discussed here.
Thor
Edited By Thor 🇳🇴 on 09/10/2022 11:06:03
Thread: Does anyone have a manual for a Clarkson Grinder
07/10/2022 07:34:22
Hi Michael,
You could try this link.
Thor
Thread: Boxford AUD
04/10/2022 07:32:47
Hi Perrie,
Welcome to the forum. Making a new feed-screw is one solution. Have you checked lathes.co.uk? They may have a spare. I assume you have a copy of Know Your Lathe? There is also a Boxford group.
Thor
Edited By Thor 🇳🇴 on 04/10/2022 07:37:18
Thread: New here
03/10/2022 15:23:36
Welcome to the forum. You may want to check previous threads, some links:
***Link***
***Link***
***Link***
 From the last link you can download a PDF of "Know Your Lathe" (from Boxford)
Thor
Edited By Thor 🇳🇴 on 03/10/2022 15:30:38
Thread: Fitting thin-walled Oilite bearings
29/09/2022 09:50:42
Hi Ian,
When I have installed Oilite bearings they do close up a little when pressed in, just enough to be a running fit. Are the 1" hole reamed to 1"? I assume you have read their Best Machining Practice or Engineering Assist?
Thor
Edited By Thor 🇳🇴 on 29/09/2022 10:06:17
Thread: Myford super 7
29/09/2022 06:07:52
Hi Mark,
This has been discussed before, here is one link:
***Link***
Thor
Thread: Centec 2C
28/09/2022 07:38:13
Hi Alan,
There is a Centec site on groups.io, unfortunately the files from Yahoo doesn't seem to have been transferred to the new site. You could ask them for help.
Thor
Thread: Is this any good
27/09/2022 12:53:30
Hi Haydn,
From your photos the half-nut looks worn, especially on the side where there is hardly any thread left.
Thor
Thread: New Member
25/09/2022 19:03:03
Hi John,
Welcome to the forum. The FB2 was discussed earlier on this forum, see here, there is also a link to a manual (in German) in that thread.
Thor
Thread: Silver solder wire / rod size
23/09/2022 06:14:03
Hi Steve,
I have fabricated crankshafts by silver soldering (brazing), I make the parts slightly oversize so after brazing I can clean up any distortion. I usually use 1.5mm rod since that is readily available where I live but when I find 1mm rod that is what I buy. Good luck.
Thor
Thread: Smelting Iron Ore
21/09/2022 07:13:01
Hi Andre,
During the campaign against the Sovjet Union the Germans had access to Manganese in southern Ukraine. They also got Manganese from Hungary and Romania.
Thor
Thread: Workshop Machines - How Big is Too Big?
16/09/2022 19:35:54
My 290 lathe at a bit over 200kg and I would not want to try and get something bigger or heavier across the lawn and into my basement workshop.
Thor
Thread: QCTP for WM290V
13/09/2022 13:54:01
Hi Steven,
Welcome to the forum. Warco sells several different QCTP's, have you asked them? On my 290 lathe I use this QCTP, a friend got a good price many years ago. I have made some extra toolholders.
Thor
Edited By Thor 🇳🇴 on 13/09/2022 13:56:44
Thread: Spotted in Alaska
13/09/2022 06:39:06
Looks like the ones used on Bergensbanen in Norway.
Thor
Edited By Thor 🇳🇴 on 13/09/2022 06:44:50
Thread: Lathe carbide tool issue
12/09/2022 07:41:25
Hi Karl,
Welcome to the forum. Carbide tooling needs a rigid lathe, high speed and a certain depth of cut, usually at least the nose rasius of the carbide insert. I often use carbide for the roughing cuts and finish ith a newly honed HSS tool.
Thor
Thread: Hello
12/09/2022 07:24:33
Hi Dennis,
Welcome to the forum. What models do you intend to make?
Thor
Thread: WILESCO THREADS
07/09/2022 10:19:29
Hi Noel,
As far as I know the old ones use M6 (1mm pitch), new ones may use M6 x 0.75 so you should check yours first.
Thor
Edited By Thor 🇳🇴 on 07/09/2022 10:26:27
