Here is a list of all the postings Thor 🇳🇴 has made in our forums. Click on a thread name to jump to the thread.
Thread: Quality end mill cutter that last long? |
12/01/2023 09:33:02 |
Hi Lucas, Welcome to the forum. For quality HSS cutters I buy Dormer branded cutters, Thor |
Thread: New member |
08/01/2023 08:29:43 |
Hi Raymond, Welcome to the forum, nice to have more Norwegian members. I have sent you a PM. Thor Edited By Thor 🇳🇴 on 08/01/2023 08:32:45 |
Thread: Steel used in bolts |
01/01/2023 17:44:00 |
Hi Keith, Ordinary 8.8 bolts are often made from (unalloyed) steel with 0.35 to 0.45% C, the 10.9 and 12.9 bolts are usually made from steels alloyed with Chromium or Chromium and Molybdenum. Thor |
27/12/2022 08:34:34 |
Hi Matthew, Welcome to the forum, many helpful members on here. What are your interests when it comes to Model Engineering? Thor |
Thread: Warco Lathe Oiling |
11/12/2022 16:10:16 |
Hi Justin, Welcome to the forum. My 290 lathe manual says 20W machine oil, Hydraulic H32 should work well. I use way oil on the ways and gear oil in gearbox/apron. I have to use syringe and a piece of plastic tubing when changing oil in the gearbox. Thor Edited By Thor 🇳🇴 on 11/12/2022 16:11:53 |
Thread: Up grade milling machine |
08/12/2022 10:10:06 |
Hi Bob, A friend of mine has the Sieg SX3 and likes it, he has had no troubles. I have a 10 year old milling machine similar to the Amadeal VM25 (but with a brushed mtor), no troubles and I like the long table. Thor |
Thread: Face Milling Experiment |
04/12/2022 15:10:51 |
Impressive demo Andrew. My milling machine wouldn't cope with that job either, but it only has a 1HP motor with electronic speed control and probably weighs 1/10 of your horizontal. Thor |
Thread: Hello from New Hampshire, USA! |
04/12/2022 09:51:06 |
Hi John, Welcome to the forum. I only have one Unimat SL, part of it is now used to sharpen my endmills. Thor |
Thread: This made me smile |
30/11/2022 10:39:12 |
Thread: back issues |
29/11/2022 12:04:18 |
Hi Jack, Check your messages. Thor Edited By Thor 🇳🇴 on 29/11/2022 12:04:29 |
Thread: Metric fasteners |
26/11/2022 10:49:25 |
Hi Peter, I tend to make studs and use nuts, and it isn't easy to find M 2.5 hex head bolts where I live. Thor |
Thread: Emco Compact 5 Top slide gib |
23/11/2022 08:12:38 |
Hi Manfred, I have purchased spares for my Compact 8 from Austria, yes they are not cheap. You may find what you want on eBay etc. if you are lucky. Thor |
Thread: Surface plate |
22/11/2022 18:39:15 |
Hi Wesley, Welcome to the forum. Are the porcelain tiles flat? Or do you intend to use the 3 plate method? I know some use plate glass as a cheap surface plate, usually they are made from Cast Iron or granite. Thor |
Thread: Oils for Hardening |
19/11/2022 12:05:03 |
When I harden oil-hardening steels I use a thin oil (low viscosity), I have also used rapeseed oil. Thor |
Thread: What does this micrometer measure |
17/11/2022 17:50:34 |
May be this will help? Thor |
Thread: Deckel FP1 Manuals |
10/11/2022 17:53:32 |
Hi Russel, E-mail sent to the address you PM'd me. Good luck with your Deckel. Thor |
10/11/2022 10:41:58 |
Hi Russel, I have a PDF version of an old manual, send me a PM with your e-mail. Thor |
Thread: Alba1 shaper info |
09/11/2022 18:30:27 |
Hi Tom How to post photos here. Thor |
Thread: Non-steaming models. Sacrilege?? |
26/10/2022 10:08:04 |
I run my steam engine models on compressed air, a few I have tried on low pressure steam. A model driven by compressed air or by a battery isn't a sacrilege in my book, so just do what you want. Thor |
Thread: De-gassing ally melt. |
21/10/2022 11:16:35 |
You need to use a kind of flux - salts that often contain chlorine or fluorine. Here is a Youtube video. Thor Edited By Thor 🇳🇴 on 21/10/2022 11:30:46 |
