Manfred Vormbaum | 23/11/2022 01:27:57 |
7 forum posts 2 photos | I am refurbishing an Emco Compact 5. Slowly getting it sorted out. However, I appear to be missing the plastic gib for the top slide. Any suggestions as to where I could purchase a replacement? If not any suggestions for alternatives. https://www.emcomachinetools.co.uk/ seems to be down most of the time - although that could be because I may be accessing it at the wrong time given that I am in Canada. https://www.emcoshop.at/emcoersatzzubehoerteiledrehmaschinenemcocompact5zubehoer/1718-drehmaschinenemcocompact5zubehremcooberschlitten.html appears to be a possibility although the price rather puts me off. Any help / suggestions appreciated Manfred |
Redsetter | 23/11/2022 08:10:34 |
239 forum posts 1 photos | Don't over think it - what does the gib actually need to do? Just use a piece of bright mild steel flat bar of appropriate cross section - it can't be all that critical, and there will be a stock size which is near enough. Spot through the screw holes in the top slide to drill for the screw tips. It will probably be better than plastic anyway.
Thor 🇳🇴 | 23/11/2022 08:12:38 |
![]() 1766 forum posts 46 photos | Hi Manfred, I have purchased spares for my Compact 8 from Austria, yes they are not cheap. You may find what you want on eBay etc. if you are lucky. Thor |
Emgee | 23/11/2022 10:31:53 |
2610 forum posts 312 photos | Hi Manfred The top slide gib on the Emco 5 cnc lathe is made of steel, I have never had to make adjustments in 5 years of use. Emgee |
A. Ozen | 23/11/2022 22:52:30 |
4 forum posts 13 photos | I was reading a lot of useful stuff on the forum lately, was not registered yet. Just seen your post, so I registered to tell how I solved this issue. I had the same issue with my top slide gib, I ordered a 100cm brass strip, 7mm wide and 2.5mm thick and made a gib from it. My milling attachment was not sorted yet, I made the gib at my work on a larger milling machine, and sand the sides down with 1000 grid sandpaper on a flat surface. If you have a milling attachment, you can make it yourself. The brass strip on top, the gib I made in the middle and the original gib under that: |
Jouke van der Veen | 24/11/2022 11:29:11 |
203 forum posts 19 photos | When I bought a second top slide the gib was also missing. I made a gib strip from a 2mm thick PVC tube (in length direction of course) as a “temporary” solution and I must say: it works well. The concave side of it is directed to the gib screws. Regards, Jouke
A. Ozen | 24/11/2022 16:34:06 |
4 forum posts 13 photos | Sorry Manfred, I did not check the link you posted to EmcoShop, I thought you linked the gib only, but it was the complete top slide in the link. According to the part list I have for the Compact 5 the gib has part number A5A05050 and EmcoShop sells that too, price is reasonable at €12.85, but I ordered couple times from them, and the shipment costs are really high, to the Netherlands it is almost twice as the item itself at €25 Here is the link to the gib: Emco GIB A5A 050 050 If you don't have a parts list, just search for a German manual of the lathe and at the end there is a parts list with exploded drawings of it. I figure that out after a couple of weeks when I got the lathe, and it is very helpful, the English version of the manual does not have part numbers. |
Manfred Vormbaum | 24/11/2022 22:12:39 |
7 forum posts 2 photos | Thank you all for your responses. I was reticent using mild steel for the gib as the two dovetails are apparently made from ZAMAK / MAZAK, a zink, magnesium, aluminium / copper alloy that I suspect is much softer than mild steel. Don't know what the implications of that are but not keen on finding out first hand. I will try the PVC and brass suggestions in that order. Thanks for the link at the emcoshop. Shipping to Canada is €53.83. Plus taxes and duties! For an English (perhaps American) parts list you may want to go here: https://www.searspartsdirect.com/model/1n45xgogz1-000247/craftsman-549289000-lathe-parts. The Compact 5 was sold as a Sears machine in a fetching battleship grey. |
A. Ozen | 24/11/2022 22:36:25 |
4 forum posts 13 photos | Posted by Manfred Vormbaum on 24/11/2022 22:12:39: .... Thanks for the link at the emcoshop. Shipping to Canada is €53.83. Plus taxes and duties! .... The Compact 5 was sold as a Sears machine in a fetching battleship grey. That is a lot of money for the shipment! I ordered twice from them, but I wait till I have a list of parts and accessories I want, that makes the shipment fee a little more acceptable. I got the lathe 2 months ago, it was pretty stock, and the milling attachment was bought later by the previous owner, milling attachment was worn out on some parts, so I fixed all of that, and I wanted all attachments available when the lathe was new, got those too from ebay and local "ebay" like site, so it cost me a lot at the end, but it is complete now, and I am really happy with it. I also did a VFD upgrade with a new motor, added some self-made DRO on all axes. Did a lot of upgrades on it, I uploaded some pictures of it here on the site in my album:
Jouke van der Veen | 25/11/2022 15:27:34 |
203 forum posts 19 photos | Hallo Ozen, I had a quick look at all those nice features you added to your Emco C5. Above you wrote about shipping costs from the Emcoshop (Emco Holz & Hobby) into The Netherlands. Do you live in The Netherlands? Regards, Jouke
A. Ozen | 25/11/2022 21:28:16 |
4 forum posts 13 photos | Yes Jouke, I am from the Netherlands. |
Jouke van der Veen | 26/11/2022 09:34:58 |
203 forum posts 19 photos | Good morning Ozen, I sent you a PM Regards, Jouke Edited By Jouke van der Veen on 26/11/2022 09:35:24 |
