Member postings for Roderick Jenkins
Here is a list of all the postings Roderick Jenkins has made in our forums. Click on a thread name to jump to the thread.
Thread: A SIMPLE POINT !
27/08/2021 11:25:37
Mostly a difference between US and UK terminology I think.
Rod
Thread: Sherline lathe
21/08/2021 12:40:34
I bought a high speed pulley set for my Denford/Sherline mill recently from Millhill. They were pleasant and efficient to deal with over the phone.
Rod
Thread: cutting spur gears on a mill
20/08/2021 10:42:53
Posted by Martin Connelly on 20/08/2021 08:36:56:
Anyone who has ever cut gears will know that there is great satisfaction in it because it is not a quick and easy process however it is done and there are no simple shortcuts.
I couldn't agree more with Martin and Andrew smiley
Rod
Thread: Converting fractions to decimals
17/08/2021 09:50:59
For workshop use I like to use a calculator like this **LINK**
You can select the number of decimal places displayed and round the last figure. Normally I am calculating mm to thous so I divide by 25.4 and the answer is displayed to three decimal places - the nearest thou.
Rod
Thread: Consequences of Machining Cast Iron
14/08/2021 12:21:21
Our kitchen sink is black cool
Serendipity, the previous owner of the house did a makeover. I also have a dedicated dark handwash towel.
Rod
Thread: What Did You Do Today 2021
14/08/2021 09:51:37
Emgee,
The jaws were advertised in ME back in July 1987 together with a puff article in the editorial:
As you suggest, the chuck jaw would be easy to make from a standard soft jaw. The slots in my hexagons are 1/8" and the jaws fit a 4" Burnerd. The company still appears to exist but I made no enquiries about replacement hexes.
Rod
Thread: Beam Engine - where to start?
11/08/2021 14:58:02
Thank you all for the input. The consensus seems to be to start with the bedplate and work my way up.
Andrew, I have actually started with the governor drive gears- mostly as a test of my fading intellect(?) to understand the manufacture of parallel depth bevel gears:
They will need some trimming
Tug, the castings are all bronze so the Swarfega can stay in the tub.
I do have the "build log" by Stan Bray and, frankly, whatever qualities Mr Bray has as a journalist, I am less impressed the quality of the work he showcased in ME.
Cheers guys,
Rod
11/08/2021 11:16:58
Hi Folks,
I've got the castings:
and I've got the drawings. My experience of steam engines is pretty much limited to a 10V made 30+ years ago.. The question is - where should I start? Base? Cylinder? Beam? Column? Crankshaft? Or what?
Advice please.
Rod
11/08/2021 11:03:35
My soft jaws have run out of space:
Spent the afternoon making some new tops
Ready for action
Cheers,
Rod
Thread: Painting Brass and Bronze
30/07/2021 18:52:55
The paint is already chipping off some of the brass bits on my Farm Boy. I used Halfords etch primer but this does not seem to be adequate for brass. Clear brass lacquers seem to stick ok. Would this make a good primer? Any recommendations of good technique and materials for brass would be welcome.
Cheers,
Rod
Thread: The Workshop Progress Thread 2021
29/07/2021 17:21:54
Finished my air cooled version of the Farm Boy hit and miss engine
Rod
Thread: Garmin sat nav
19/07/2021 17:09:31
Posted by Nicholas Farr on 19/07/2021 16:14:51:
Hi Hans, I guess they must transmit your position, otherwise how would it be able to tell when you reach junctions etc? and give you the next instruction and tell you when you have reached your destination
I dont think so. The GPS system knows where it is on the digital map. It then calculates where you are and distances to the next nav point. My Garmin receives traffic data as an FM signal (Traffic Message Channel) through the special cigarette lighter charging lead. A two way system would probably involve mobile telephony and a sim card, which would involve an annual charge like on most modern cards.
Rod
Thread: Gear Train Calculator
19/07/2021 16:07:22
Calum,
I applaud your effort, particular the fact that your program is completely stand alone and platform independent. I would caution against trying to make your program too universal. My own attempt written in visual basic in Excel is specifically focused on my own particular needs to calculate long leads on a Myford S7 with add on gear box, metric conversion set and loads of change gears. Too specialised, I suggest.
My advice would be to add another pair of gears like Hairy Pete has since most lathes can accommodate this. The option to select 4 or 6 gear trains would be good but clearly six gears gives a better chance of a closer result to the desired pitch so if a 4 gear train won't get close enough then a six gear train is worth a try. I suspect specifying the order of the gears is going to be too difficult since there are so many variations in banjo size and configuration. Letting the user know which are the drivers and which are driven is probably the best you can do. The user can work out which to put where on their own particular lathe. Give the user some options with a list of results since lesser accuracy may be acceptable if the better result won't mesh. I hope these thought are some use.
Rod
Thread: Template for Cutter Teeth Indexing Table : Patent
16/07/2021 15:10:01
My dad worked for the ministry and had a couple of spin off patents which would have been held his employer. However, certainly in the 60s anyway, the US insisted that patents were filed by individuals. What's more, every patent filed earned a fee of 1$. My dad got a postal order for 6s 8d through the post (3 dollars to the pound in those days).
Rod
Thread: Ml7 toolpost
14/07/2021 15:37:32
Not sure if this is relevant but on my S7 the hole in the QCTP is much larger than the stud in the topslide.
The kit included a top hat washer
This works very will, no movement of the QCTP when tightened down.
HTH,
Rod
Thread: Taps and Dies
14/07/2021 13:41:53
Posted by Mick B1 on 14/07/2021 12:00:52:
They are of 'tungsten steel', which I guess isn't quite HSS...
Actually, I suggest, nowhere near HSS. Normal O1 type gauge plate has 0.5% tungsten. Record plane blades were described as Tungsten Steel and they, like gauge plate, do not have the hot hardness of HSS. Most hardenable steels have various small quantities of elements such as vanadium, chromium and tungsten to modify the behaviour of the microstructure during the heating, quenching and tempering process. I suggest that in every day model engineering terms tungsten steel is no different to carbon steel.
Rod
Thread: Can't get the hang of HSS!
13/07/2021 16:07:41
HSS tools for brass usually have zero side and back rake. The pre-ground HSS usually have a groove ground in the top that makes them too "sharp" for brass. What type of Carbide are you using? The brazed tip type usually have little or no rake.
HTH,
Rod
Thread: Harrison M300 siting
10/07/2021 11:13:38
I'd want the option of having a long bar poking out of the rear of the headstock.
Rod
Thread: Is there an original copy of a photo from 1968?
09/07/2021 09:04:08
Gerrit,
When I wrote articles for ME back in pre digital days all original photographs were returned to me after publication.
Rod
Thread: Tool post height
08/07/2021 13:50:14
Lots of "theory" on here about the lack of rigidity of QCTPs. I have never had a problem with mine on my S7. I have a Gibraltar post and have only ever used that with a boring bar that is too big for the tool holder (and for my J&S knurling tool which has a shank which is too big).
Rod
