Member postings for fishy-steve
Here is a list of all the postings fishy-steve has made in our forums. Click on a thread name to jump to the thread.
Thread: Bolts & Setscrews Help Needed
14/10/2017 21:56:39
Dog point screw.
Thread: What are these????
05/10/2017 17:08:42
Neil would be in front of it. 😉
Thread: socket_head_cap_screw_iso_ISO_4762_M5_x_16_16S
01/10/2017 21:02:50
Looks left handed to me. 😂
Thread: GearTrain Troubles Chester Coventry Lathe
27/09/2017 23:34:54
Beat me to it Keith. laugh
27/09/2017 23:34:02
They are for cutting Module or DP worms.
Steve.
Thread: Drilling holes using drill and mills
20/09/2017 16:51:17
Wow. You lot are quick. laugh
20/09/2017 16:50:02
Have you checked if it's trammed ? Although it would have to be out by a mile to see what your getting.
Steve.
Thread: Guy Martin F1 Pit Crew
18/09/2017 10:49:55
I missed it 😂
I was at Spa and watched him do a couple of practice wheel changes from the other side of the pit wall on the Thursday evening. He looked really nervous.
I'll watch it on catch up. Thanks for the heads up.
Steve.
Thread: advice on choosing a milling machine
16/08/2017 12:54:13
Hi Giles,
I have a late metric Tom Senior M1 in very good mechanical condition. I have the knuckle head and also the horizontal capability. What really improves the machine is the S type head. I originally thought I would purchase one in the future. Unfortunately for me the prices have gone beyond my means. Only last week one that was not a very good example went for £1200 on Ebay. I only paid £950 for my machine so paying that much for the head is out of the question.
Steve.
Thread: uPVC door in closed position with broken lock
25/07/2017 10:13:48
Pay the £110 and save yourself the bother. I paid £100 for my door with exactly the same symptoms as yours. The locksmith took an hour to do it and was cursing the whole time.
Good luck.
Thread: Bruce Mclaren
10/06/2017 11:32:29
I believe the film has been released as a DVD here in the UK. I'm out and about today so I think I'll pick up a copy. Thanks for the reminder Ian.
Steve.
Thread: TORNADO 100mph Steam train TV Program
15/05/2017 18:46:33
BBC ONE YK&LI
BBC ONE YORKSHIRE
BBC ONE NE&C
Thread: BollAero 49 Glowplug Engine
02/04/2017 18:07:59
Hi Chris,
Can you confirm that the recess in the cylinder jacket (Fig7 page 85) is .040" deep as it states on the drawings.
The dotted line on the side view is drawn shallower than the .025" external shoulder length so a bit confusing.
Thanks,
Steve.
Edited By fishy-steve on 02/04/2017 18:08:26
Thread: Tap wrenches
25/02/2017 08:25:51
Hi Benny,
They look very nice.
I have a few tap wrenches to this design that I have acquired and they all have the same annoying problem. The pin that acts on the tap stems have all burred up. This isn't a problem when using smaller taps. The problem arises when you try to use it on taps that are at the maximum size for the tool. The burrs stop the pin retracting into the handle. At this point I usually throw the tool down in disgust and have to rummage around for a bigger tap wrench.
As you will own the tool from new you might not have the same problem. The guy that owned mine before I acquired them must have been an ape. 😉
You could make the 4mm pin out of silver steel and harden the tip. Just a thought.
Steve.
Thread: What Did You Do Today (2017)
08/02/2017 12:36:45
Posted by Simon Collier 1 on 08/02/2017 06:12:30:
I mounted and tested the 4 jaw chuck I had converted from Hercus to Myford (see above 2 days ago). There was a visible wobble, and TIR on the front face was at least 10 thou, so I'll have to call the project a failure. For comparison, I tested my direct mount (no backplate) 4 jaw on the Hercus: perfect, with undetectable runout on the face. I can always reclaim the chuck by chucking it in my Chinese 8" 4 jaw and bore away my Myford threaded sleeve. I suppose it was a big ask to get a precision result with such a project.
Simon,
Like you said, bore the sleeve back out.
Sell it on and buy yourself the chuck that suits your lathe. It's been stated previously Loctite is used on aircraft. It was used by Nasa, it's used in Formula One and I use it a couple time a week in my day job but there is no way I would stand in front of a chuck spinning at 1400 RPM that's been glued together.
Maybe I'm just old fashioned but I like the way chuck manufacturers design their chucks.
Steve.
06/02/2017 10:26:48
Posted by Simon Collier 1 on 06/02/2017 09:17:15:
photo 2.jpgI converted a Hercus 4 jaw with backplate into a Myford 4 jaw without backplate. I made an adaptor from cast iron, screwcutting the Myford spindle nose thread and turning the register. The outside diameter was turned to a close sliding fit in the bore of the chuck body. I will Loctite it in tomorrow. The chuck was given to me, an ex-school one. The schools are closing down metal work these days because it is, apparently, too dangerous. Our club was given a 3-phase lathe and drill for the same reason. I have an excellent directly threaded Hercus 4 jaw, but not a 4 jaw for my ML 7. I'll probably never use it, but I wanted it for completeness. The threading was extremely difficult for me as you can't test it until you remove it. In fact I ended up removing it twice, and returned it and clocked it up and continued. Good fit in the end, if a bit ugly.photo 1.jpg
Loctite is good stuff but I wouldn't trust it for that application.
Steve.
Thread: VFD article in MEW 251
01/02/2017 13:28:22
I've set my stop button to coast to a stand still on my Boxford AUD. When setting up the E-stoppel I obviously wanted the chuck to come to a stop much faster. Not a good idea to set it much less than .8 of a second.
Oh was I glad I had a 1" x 8" piece of brass in the chuck. 😉
01/02/2017 12:43:54
I haven't got access to the article but wouldn't the pendant move from machine to machine too?
The only problems I can think of would be that unless your motors were the same you would need to tweak the parameters from machine to machine
I'm sure the manual that came with my VSD states it's not recommended to fit a plug anywhere in the 3 phase supply line though.
Steve.
Thread: RDG involute gear cutters.
27/01/2017 19:55:01
Brian,
All the gears I require can be cut with a number 2 and 3 cutter. That's £35. No idea what a 18DP 14.5PA hob would cost?
Steve.
Edited By fishy-steve on 27/01/2017 19:56:08
27/01/2017 19:09:54
Update.
Used the cutter I purchased from RDG. Very pleased with it. It was indeed manufactured by HBM and I will be buying more cutters from RDG.
