GearTrain Troubles Chester Coventry Lathe
Mike Nash 227/09/2017 17:46:20
14 forum posts
I have a Chester Coventry lathe and want to be able to turn imperial threads. looking at the manual I know that I need to change over the gear sets as per below:
Bodger Brian27/09/2017 19:17:06
187 forum posts
40 photos
'...as per below:" ? There isn't anything below.
What information are you looking for? Has your post been chopped short?
Mike Nash 227/09/2017 19:32:47
14 forum posts
Thank you for replying. It was cut. I am trying to find out how to add in a copied photo. I have a metric Chester Coventry lathe. Like most lathes It has the facility to produce imperial threads by changing the gear wheels. Four in total. This is all shown in the manual. However it to cut imperial it only shows the size of the first 3 gears but not the 4th. It justs shows a line. I am trying to show a photo of the manual.
Mike Nash 227/09/2017 19:38:57
14 forum posts
Michael Gilligan27/09/2017 19:41:33
23121 forum posts
1360 photos
Mike,
Like most new members ... You would probably find it useful to read this: **LINK**
http://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1
Gray6227/09/2017 19:44:42
1058 forum posts
16 photos
Mike, to add photos to a post follow the instructions in this thread
Edited By Graeme W on 27/09/2017 19:45:20
Mike Nash 227/09/2017 19:45:16
14 forum posts
I hope the photo makes it clearer. Couldn't do it on PC but managed on an iPad!
Anyway calling Chester directly has not been very helpful so far. So I really need help on this as I have run out of ideas.
JasonB27/09/2017 20:46:53
Mike, nothing was cut, whatever you thought you had attached was not there.
Also nothing showing up that you can see on your ipad
Have a read of the instructions the others have kindly linked to.
Mike Nash 227/09/2017 21:00:43
14 forum posts
Mike Nash 227/09/2017 21:02:04
14 forum posts
Ok havre read the posts on how to upload a photo. Thank you for the help on that. Photo should now be visible.
SillyOldDuffer27/09/2017 21:54:36
10668 forum posts
2415 photos
That's a cryptic chart!
I think it means that the 4th wheel for TPI values is usually 48t but that 46t or 52t are needed to produce the TPIs in the last two columns.
So, for example, on line AC, a fourth wheel of 48t gets you 14,16, 21, 22, 24, 36 and 40 tpi, while 46t gives 23tpi and 52t does 26tpi
Hope that makes sense. If not I'm baffled!
Mike Nash 227/09/2017 23:22:06
14 forum posts
Dave thank you I think you are a very clever man indeed. Now that you have said it, it is now in plain sight! I couldn't see the wood for the trees. The line is a rather odd shaped arrow.
Once again thanks for that.
Mike Nash 227/09/2017 23:25:05
14 forum posts
It does beg the question, what are the Module and D.P. Tables for?
Edited By Mike Nash 2 on 27/09/2017 23:26:16
Keith Long27/09/2017 23:33:11
883 forum posts
11 photos
The module and DP tables are for producing worms to mesh with either module or DP gears.
fishy-steve27/09/2017 23:34:02
122 forum posts
30 photos
They are for cutting Module or DP worms.
Steve.
fishy-steve27/09/2017 23:34:54
122 forum posts
30 photos
Beat me to it Keith. laugh
Mike Nash 228/09/2017 12:04:36
14 forum posts
Thank you Gentlemen, this evening I look forward to turning some 5/8 UNF threads! Cant believe I just wrote that.
