Here is a list of all the postings Ian Parkin has made in our forums. Click on a thread name to jump to the thread.
Thread: How to stop scam phone calls for good? |
21/07/2020 14:26:56 |
Really i'd like to be able to block all calls except ones that we/she wants to get calls from the scammers are upsetting for her now i have a pair of call blocking cordless phones and loads still get through she has 4 cordless and a fixed landline phone....so how do i get call blocking? is it hardware at home or at the exchange? |
Thread: Help with contacting MyHermes |
21/07/2020 13:12:51 |
Its impossible to contact them either by phone or email |
21/07/2020 12:48:58 |
My mother is getting increased number of scammers targeting her by phone shes 85 and in early stage dementia but still living alone succesfully how can i stop the scammers getting through? I have a vague thought that you can set up a pin number on the line so anyone who rings has to enter the pin for the call to go ahead. or any other methods? been searching the bt site but seems to have to set up a blacklist and add to that as nessasary which is too complicated for her. or do we change her number and have her ex directory? |
Thread: Mystery Lathe fitting |
20/07/2020 09:52:58 |
It looks like the fitting for attaching the arm for the taper turning attachment on a Colchester lathe |
Thread: What’s this lathe insert used for? |
12/07/2020 16:28:02 |
I bought this holder for my upright threading inserts that i use and this tip was in it theres no markings on the tip what could it be used for ? 2 rounded crests and a sharp v in the middle |
Thread: Short drill or Spot / Centre drill first |
07/07/2020 11:06:43 |
I would make your pegs first and experiment with drills in your material to get your required fit make your pegs out of 3mm silver steel perhaps rather than as you said making your pegs fit the holes...make the holes fit the pegs |
Thread: Ac motor 3 wire |
06/07/2020 15:17:37 |
Are you sure that the cap has 4 terminals? not 2 terminals with 2 conections on each terminal? Edited By Ian Parkin on 06/07/2020 15:17:51 |
Thread: Butterfly Bolt or Thumb Screw |
05/07/2020 18:10:36 |
Chris if it lasts even 6 months replace the screw or the nut a bag of 10 wing nuts will last a lifetime...guaranteed |
05/07/2020 17:02:20 |
The thing about my suggestion is that you dont wear out the female thread in your equipment the bolt shaft is replaceable when it wears out as is the wing nut |
05/07/2020 16:53:38 |
Chris just run a m4 bolt into the thread after putting a wing nut on the bolt then use the wing nut to tighten it up the nut does the same job as the bolt head |
05/07/2020 16:34:56 |
Chris so you want to convert a blade locking screw that you use an allen key for to a finger lock? use a m4 bolt as the post and use a m4 wing nut on it to use as the lock...if the wing nut or bolt wears out ...replace it...? |
Thread: Parvalux motor |
04/07/2020 13:37:17 |
Well assuming its the one i linked to the other day 5 amps is plenty the motor will run fine on either of those PS That motor is a PM ( permanent magnet ) motor so wont run on ac Edited By Ian Parkin on 04/07/2020 13:42:03 |
04/07/2020 13:25:10 |
Or this style https://www.ebay.co.uk/itm/AC-DC-DC-24V-5A-Universal-Regulated-Switching-Power-Supply-Transformer-LED-PSU/164248272740?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D225113%26meid%3D5adc9fd092634b1fbd654524ac8c9b80%26pid%3D100005%26rk%3D6%26rkt%3D12%26mehot%3Dpf%26sd%3D193550898066%26itm%3D164248272740%26pmt%3D1%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic%26brand%3DUnbranded&_trksid=p2047675.c100005.m1851 |
04/07/2020 13:23:30 |
Such as https://www.ebay.co.uk/itm/Lambda-DLP120-24-1-E-Power-Supply-Module-240-110V-input-24V-5A-output/274417868096?hash=item3fe4945d40:g:IwcAAOSw5w1ekcZs |
04/07/2020 13:00:51 |
Just get a 240v in 24dc SMPS ( switch mode power supply) off eBay you should only need a 5 amp |
Thread: micro switch |
01/07/2020 20:54:51 |
Jeff they are fitted in this piece of av equipment and theres 7 of them fitted in each one made in Germany in the 70’s and 80’s by kodak its really tricky to retrofit new styles of switch but as i said they all seem to lose the spring they only carrying small currents at 24v |
01/07/2020 13:12:43 |
Hmm lots availble but at high prices Mouser came up trumps though at a reasonable price for 10 switches but only shipping option is £12 ( ouch) Many thanks to Brian Edited By Ian Parkin on 01/07/2020 13:14:31 |
01/07/2020 12:44:00 |
brilliant Brian now to find some in stock somewhere |
01/07/2020 12:31:55 |
Can anyone identify this micro switch ? i have lots of these all faulty because the spring has done a runner |
Thread: Power feed for mill head |
29/06/2020 19:21:11 |
Or this one will do https://www.ebay.co.uk/itm/NEW-PARVALUX-24V-DC-Geared-Motor-0-8A-25-RPM-3Nm-H7FL-PM45-68-0017-CONT/224057387190?hash=item342adc68b6:g:NLwAAOSwJp1e9H4L |
