Parvalux motor
larry phelan 104/07/2020 12:49:30
1346 forum posts
15 photos
Good afternoon all,
I need a 24 v dc supply to operate a Parvalux motor.
Any ideas how to go about it since I have only AC to hand 110,230 380 v
I do not have a 24v battery, nor any means of charging one.
Thanks in advance for any advice.
Frances IoM04/07/2020 12:54:30
1395 forum posts
30 photos
simplest is two 12V batteries in series - however it depends on what current is required (car batteries will supply 40+ Amps but not for long - utility batteries will tolerate deeper discharges) and for what operation you need the motor for
Ian Parkin04/07/2020 13:00:51
1174 forum posts
303 photos
Just get a 240v in 24dc SMPS ( switch mode power supply) off eBay you should only need a 5 amp
Ian Parkin04/07/2020 13:23:30
1174 forum posts
303 photos
Such as
https://www.ebay.co.uk/itm/Lambda-DLP120-24-1-E-Power-Supply-Module-240-110V-input-24V-5A-output/274417868096?hash=item3fe4945d40:g:IwcAAOSw5w1ekcZs
Ian Parkin04/07/2020 13:25:10
1174 forum posts
303 photos
Or this style
https://www.ebay.co.uk/itm/AC-DC-DC-24V-5A-Universal-Regulated-Switching-Power-Supply-Transformer-LED-PSU/164248272740?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D225113%26meid%3D5adc9fd092634b1fbd654524ac8c9b80%26pid%3D100005%26rk%3D6%26rkt%3D12%26mehot%3Dpf%26sd%3D193550898066%26itm%3D164248272740%26pmt%3D1%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic%26brand%3DUnbranded&_trksid=p2047675.c100005.m1851
Robert Atkinson 204/07/2020 13:26:01
1891 forum posts
37 photos
Most, if not all Parvalux "DC" motors are brushed "universal" motors. This means they will run fine on AC, You just need a 24 V transformer (a dual 12V will do too).
A SMPS is overkill and may not actually work depending on the size of the motor and the design of the SMPS. Many do not like the inrush current of a DC motor with a heavy load. I'm not sure how Ian determined a 5A requirement.
Robert G8RPI
Robert Atkinson 204/07/2020 13:36:26
1891 forum posts
37 photos
Posted by Ian Parkin on 04/07/2020 13:25:10:
Or this style
Personally I would not touch that with a barge pole (unless it was certified as insulating )
Clearly not compliant with regulations, it does not even have a part number. I would be concerned about it' safety.
Robert G8RPI.
Ian Parkin04/07/2020 13:37:17
1174 forum posts
303 photos
Well assuming its the one i linked to the other day 5 amps is plenty
the motor will run fine on either of those PS
That motor is a PM ( permanent magnet ) motor so wont run on ac
Edited By Ian Parkin on 04/07/2020 13:42:03
John Haine04/07/2020 13:58:49
5563 forum posts
322 photos
Posted by Robert Atkinson 2 on 04/07/2020 13:26:01:
Robert G8RPI
Rather unlikely I think. A 24V motor is most likely to be a PM type or possibly shunt wound field.
Martin Kyte04/07/2020 14:05:39
3445 forum posts
62 photos
One piece of advice is just ask the question you want to have answered. Like I need a 24 DC supply at around 5 Amps. That way you won't get everyone and his dog second guessing what your motor is.
;O)
Martin
larry phelan 104/07/2020 14:21:27
1346 forum posts
15 photos
OK Martin, that,s what I need.
ega04/07/2020 15:21:34
2805 forum posts
219 photos
If, as suggested, you used two 12V batteries you would need some way of charging these. Could this be a conventional car battery charger and is there some better way of maintaining charge in a car battery off the vehicle?
Edited By ega on 04/07/2020 15:22:07
