simple loop alarm for exhibits
bernard towers30/09/2023 11:24:40
1221 forum posts
161 photos
is there any kits or circuits available for a simple system, I just need to protect some items at an exhibition.
duncan webster30/09/2023 11:56:53
5307 forum posts
83 photos
I made one years ago for our club. I've just sent a WhatsApp round to see if it can be found, if so you're welcome to borrow it.
bernard towers30/09/2023 12:01:53
1221 forum posts
161 photos
Cheers Duncan that coud be very helpful
Dalboy30/09/2023 12:26:06
1009 forum posts
305 photos
Will THIS work
bernard towers30/09/2023 13:09:39
1221 forum posts
161 photos
Yes Dalboy this would be fine excepting my abilities in electronics and buying small quantities of components as I dont have an electronic scrap box, I had thought that a kit might be available as in the days of Maplins.
Bo'sun30/09/2023 13:37:14
754 forum posts
Maplin. Halcyon days when shops sold useful things.
John Doe 230/09/2023 14:36:01
441 forum posts
29 photos
Another idea might be not to bother building a device with electronics/electrics, but just thread through everything a few meters of thin chain, cut in a couple of places and held together with small padlocks, assuming a thin chain would fit through all the items you have.
If not, maybe some thin rigging wire (not electrical cable), but that would not be as easy to secure and have removable breaks in the loop.
Very quick and simple to build - with items bought from a DIY store. And secure enough to prevent pilfering - or at least warn of an attempt happening. The chain with a padlock every couple of meters would enable items to be released quite easily and the chain then re-secured.
Michael Gilligan30/09/2023 15:16:12
23121 forum posts
1360 photos
A quick & dirty solution would be to buy a ‘bag alarm’ as used for luggage, etc. … then attach your chain/wire/string/ whatever to the two parts of that.
ferinstance … https://www.ebay.co.uk/itm/173316446734
Edited By Michael Gilligan on 30/09/2023 15:21:08
Nicholas Farr30/09/2023 15:42:29
3988 forum posts
1799 photos
Hi, you should be able to get everything needed for the alarm that Dalboy has linked too from Cricklewood Electronics No need to dwell over the loss of Maplins, although they do have a website for online orders Maplin but I don't think they have as many components that they had in days past.
Regards Nick.
Diogenes30/09/2023 16:24:07
61 forum posts
6 photos
Would a simple 'pull-the-pin' alarm do the job ? - used to have one of these on my shed door... ..cheap and easy to rig..
WalkEasy - Minder personal Attack Alarm
Michael Gilligan30/09/2023 16:32:49
23121 forum posts
1360 photos
Posted by Diogenes on 30/09/2023 16:24:07:
Would a simple 'pull-the-pin' alarm do the job ? .
I hope so … it’s very much like I suggested angel
Speedy Builder530/09/2023 16:36:10
2878 forum posts
248 photos
Electric fence like farmers use!
duncan webster30/09/2023 18:11:46
5307 forum posts
83 photos
It's been found, as soon as I have it in my hands and can check it still works I'll be in touch, probably middle of next week
bernard towers30/09/2023 20:17:49
1221 forum posts
161 photos
Thanks Duncan will wait to hear from you, the idea from Michael is a good one too
bernard towers30/09/2023 20:17:50
1221 forum posts
161 photos
deleted
Edited By bernard towers on 30/09/2023 20:18:21
noel shelley30/09/2023 22:35:15
2308 forum posts
33 photos
Battery and a relay ! Wire alarm to NC contact and Common back to battery. Wire coil to length of wire connected to battery and other coil terminal to battery. If the wire to the goodies is parted the coil drops and the alarm sounds. Relay coil to suit battery voltage. Noel.
Bazyle30/09/2023 22:48:18
6956 forum posts
229 photos
You can make the equivalent of a pin pull out connection with a couple of drawing pins in the jaws of a wooden clothes peg and a bit of plastic to separate them.
Michael Gilligan01/10/2023 06:47:39
23121 forum posts
1360 photos
Posted by Bazyle on 30/09/2023 22:48:18:
So then there’s only the battery and the alarm to find or make
dont know MichaelG.
Speedy Builder501/10/2023 06:59:43
2878 forum posts
248 photos
And do remember, if it can be easily removed (Loco safety valve domes , miniature spades etc), a loop wire does not protect. Perhaps a notice like "Video scanning in operation" may help.
Diogenes01/10/2023 07:04:19
61 forum posts
6 photos
Posted by Michael Gilligan on 30/09/2023 16:32:49:
..indeed - acknowledged..
