David Noble | 03/10/2023 09:55:09 |
![]() 402 forum posts 37 photos | When I mentioned a while ago that I was thinking of starting to build the Strutt epicyclic clock, a few people made suggestions on cutting the internal teeth. I seem to have combined some if not all the suggestions! This is my attempt, it has yet to be tried as I have a couple of problems to iron out. Comments/thoughts are welcome as always. David |
bernard towers | 03/10/2023 10:53:58 |
1221 forum posts 161 photos | Sorry david what are we looking at? |
David Noble | 03/10/2023 11:33:38 |
![]() 402 forum posts 37 photos | Sorry Bernard. This is a rig to enable me to cut the internal teeth on a clock which has epicyclic gearing. It is clamped to the quill of my mill and has a home made cutter driven by a flexible drive from the mill. Hope this helps. At the moment, I seem to have a slight twist on it which I'm trying to resolve. David Edited By David Noble on 03/10/2023 11:34:52 |
David Noble | 03/10/2023 11:44:56 |
![]() 402 forum posts 37 photos | Hope this a little clearer? |
Jeff Dayman | 03/10/2023 12:08:41 |
2356 forum posts 47 photos | Hi David, I take it the shown bracket / drive / cutter setup will be used with a dividing head holding the gear to be cut, all mounted to the mill? Looks good! Did you buy the urethane belt made to length or did you get the belt stock as cord and cut / thermal weld it together? Cheers! PS look forward to the next epic epicyclic episode....8^) |
Michael Gilligan | 03/10/2023 12:26:57 |
![]() 23121 forum posts 1360 photos | Looks good, David You have basically re-invented a device which was available for ‘ornamental turning’ lathes MichaelG. |
David Noble | 03/10/2023 12:33:55 |
![]() 402 forum posts 37 photos | Thanks Jeff, yes, I bought a metre of the belt and hot welded it noted the length in case I need another 7 5/8" Thank you Michael, I don't know anything about ornamental turning. It sounds like a rabbit hole too far David |
Michael Gilligan | 03/10/2023 12:56:17 |
![]() 23121 forum posts 1360 photos | For your delectation and delight, David https://www.billooms.com/resourceOT.html
MichaelG. |
David Noble | 03/10/2023 13:17:35 |
![]() 402 forum posts 37 photos | Posted by Michael Gilligan on 03/10/2023 12:56:17:
MichaelG. Brilliant, thank you Michael. They are a lot neater than mine ! David |
V8Eng | 03/10/2023 13:34:23 |
1826 forum posts 1 photos | Whilst not directly related, there is an ornamental turner’s society I remember seeing the stand at ME Exhibitions. PersonallyI found it very interesting watching the process. Link here to their society website.
Edited By V8Eng on 03/10/2023 13:36:49 |
bernard towers | 03/10/2023 18:20:58 |
1221 forum posts 161 photos | They will be at lemington spa |
