Member postings for JohnF
Here is a list of all the postings JohnF has made in our forums. Click on a thread name to jump to the thread.
Thread: Help with choosing thread cutting inserts
30/08/2021 13:23:55
Dave aka SoD making an undercut at the shoulder is industry standard but doing it with a parting tool will potentially reduce the strength due to sharp corners creating stress points. Undercut tools as a general rule would be 1-1/2 x pitch wide with a radius on the corner adjacent to the shoulder and the "thread side" having an angle equal to half the thread angle or 45 deg.
Thread: A SIMPLE POINT !
27/08/2021 20:22:41
I concur 100 % with Howard Lewis above --- must have gone to the same school !
Thread: Reaming a hole
20/08/2021 14:20:00
The old "yardstick" for the drill size was reamer/hole size less 1/64" indeed the bushes available for jigs and fixtures from the main supplier for toolroom accessories for jigs, PTU [Production Unit Tool] were all to this specification.
However nothing is cast in stone you can be flexible depending on material, lubrication and not least what you have available ! Within sensible limits of course.
Thread: Dickson QCTP on a mini lathe
17/08/2021 22:17:09
Hi Martin, I have an original Dickson Engineering installation leaflet and for the SO [Myford size] tool block it shows the optimum dimension of 7/8" form the lathe centre height to the top of the top slide and suggests 3/8' tool bits.
Unfortunately its a pdf document so cannot post on here. Hope this helps, if you want a copy of the pdf PM me with your email
Thread: Clarkson Dedlock
05/08/2021 11:04:22
Hi Terry, Here is a drawing of the arbor you need, I think the arbor you have is an updated one but this one is easy to make -- more photo's in my albums; John
Thread: New Chuck wont screw on
02/08/2021 13:03:12
Something similar came up on another post relating to ER chucks, accuracy TIR and fit. I had a problem with an ER chuck purchased from and made in Europe -- I eventually found out they were using UNF form threads instead of Whitworth form so I do wonder if some of the Far East product has the same problem ?
During my conversations with the producers of the ER chuck I acquired the correct thread tolerance dimensions for Go / No Go gauges for the "Myford" thread and made a GO gauge as close to these dimensions as possible with the equipment I have -- I am confident its close enough to the limits specified for practical purposes. I used a full form tip to make the gauge measuring over wires with an indicator micrometer.
The sizes were calculated as a favour to me by a UK gauge maker so I don't feel it would be right to publicise them, however if any forum members want them please PM me with an email address and I will pass them on.
Why any commercial company manufacturing a precision product would operate without the proper gauges is beyond belief !!
Another problem I have found with much of the imported Myford spindle tooling offered by suppliers is the register diameter on both male and female units is woefully outside the tolerance it needs to be to ensure TIR accuracy
Regards John
Photo of my gauge
Spindle thread GO gauge
Thread: Strange type in the Lates Posts ?
02/08/2021 12:21:59
Thank you one and all ! I have been otherwise engaged since my original post but at least its now explained -- I'll live with it !!
Regards John
24/07/2021 23:18:52
Anyone noticed the strange type appearing in the RHS Latest Posts column ?
The actual title appear correct but see the examples pasted below of the latest post column
New Chuck won’t screw on
Centre Drill Leaves a “Pip†- Sometimes
Thread: Where to buy dowel pins in small quantities
20/07/2021 23:05:13
I bought some last year from WDS components but not that size and it seems they don't have 7/32" they do however sell single units upwards.
Have you considered using silver steel and harden it ? The problem is the tolerance may not suit you and there is a possibility of distortion after hardening however considering the short length its likely to be less of a problem ! All depends on the actual use.
Edited By JohnF on 20/07/2021 23:06:05
Thread: Autolock stuck drawbar won't screw in
16/07/2021 11:29:30
Michael, the Emco has a self ejecting mechanism for the MT2 tooling, it uses the draw bar and the small cap in photo 1. The draw bars are Allen screws and with the black cap in place you unscrew the draw bar until it comes to the black cap then continue to eject the taper.
I appreciate you say the thread is damaged so maybe you cannot use this method, however the type of Clarkson chuck you have has a stabilising collar that is threaded onto to body of the chuck, during use it should be snugged up to the spindle face. You MAY be able to use this feature to release your chuck by using a spanner [supplied with the machines] on the 2 flats on the spindle and a tommy bar in the Clarkson chuck collar it will hopefully eject the chuck --- put something under it to stop it dropping onto you mill table !!
Hope this helps John
PS PM me with you email if you want a copy of the instruction book page, look in my albums at Clarkson Autolock
Thread: The last Gravity Ropeway
16/07/2021 10:07:16
Yes Nigel it is close to Caton, next Village along at Claughton. Caton is my home town !
No the brickworks isn’t closing as far as we are aware, it was mothballed a few years ago for some time but I understand the raw material is of high value and something special! There were three brickwork’s at one time ! Two in Claughton, East works and West works plus another on the opposite side of the more Brookhouse Brick.
The chap on the video suggests the shale will run out in 15 years or so hence the possible closure however time will tell !
15/07/2021 12:41:56
Hi All, It will/would be sad if and when it is dismantled, I hope that somehow it will be saved when the day comes as suggested in 2036 -- I doubt it will be my problem !! It is very quiet and efficient and some years ago there was a plan to scrap it and run trucks to carry the shale, the route was through our village -- after a considerable "fight" with the planners it was abandoned thank goodness !
Conversion to a tourist attraction sounds great but it would need a very large cash injection to come even close to standards necessary to carry people.
Cheers John
Thread: Tool post height
14/07/2021 11:10:23
Posted by Vic on 14/07/2021 10:41:27:
Very nice John. I like the finish, one of my scribing blocks has that. What do they call it?
Hi Vic, "colour case hardening" its case hardening using bone charcoal, to achieve the finish the case is not very thick but enough to be wear resistant -- been practising and the tool was a prime candidate !
14/07/2021 10:17:14
My contribution as well -- I "borrowed" Vic's design -- one of the nicest I have seen and made this a couple of years back - have a sketch somewhere !!!!
14/07/2021 10:10:47
Hi all thought this may be if interest, its very close to me and in my opinion a cleaver feat of engineering.
Hope you enjoy
Thread: Blown Bricks : Advice please !
14/07/2021 10:06:43
Michael, one way of removing the bricks is drill a series of holes through the mortar bed as close together as possible then use on of the carbide side cutting "drills" aka Screwfix etc that fit an angle grinder - works pretty well ! I had to fit a new lintel over a window and used this method suggested by a pal in the building trade, we also used the side cutting bit to remove mortar for re-pointing the brickwork.
As far as bricks are concerned there is a company close to me who manufacture many specialist bricks for all areas of the UK - maybe they can assist ? **LINK**
Thread: re-magnetising magnetic base
09/07/2021 19:31:51
Rob, I have an Eclipse magnetic base purchased new by me and its close to 60 years old and in constant use so yes they live a long life !
Thread: Screw cutting advice ml7
05/07/2021 20:01:54
Posted by von dutch on 05/07/2021 11:06:41:
It is an imperial machine and I will be cutting an imperial thread,I will be running it slow as I don't want to scrap my part,I'll try some washers also,so in answer the the lines must exactly line up ?,you also have to "coax" the leadscrew engage lever sometimes as it won't just drop in every time(I don't want to force it) is that just normal wear I take it ?
Hi von dutch, Sorry been out all day but to answer the above -- no the lines don't have to line up exactly but its easier if they do [and simple with shim washers] - but if they don't you need to know and remember where to drop in the half nuts and of course it will alter depending on whether you are cutting right to left or vice versa.
Regarding the operating lever being maybe stiff or similar it certainly sounds as though some maintenance is required as GSCowboy suggests. I would remove the apron inspect the half nuts for damage or wear then clean and lube everything, amazing how much crud gets in there ! Also re-align the leadscrew as GSC says. The lever should move easily and smoothly.
05/07/2021 09:42:25
First two questions 1 is your machine Imperial or metric 2 are you cutting imperial threads or metric ?
Do the lines on the rotating dial line up precisely with the mark on the body when the half nuts are fully engaged? If they are not you need to adjust this with washer’s on the mounting stud. Providing they do Line up you should start engaging just before, and I do mean just before, the chosen line comes up to the fiduciary line on the body. Lastly what speed are you running at? Higher speed makes it difficult up to almost impossible to facilitate engagement.
Thread: How to repair damaged lawnmower drive
04/07/2021 23:17:50
Its unlikely any local hardening would occur on car bodywork but it is possible it may happen on the mower blade - higher carbon content ! If this should happen you can resolve it by local heating with a propane torch, best to clean the area so its bright and heat until blue, cool as slow as possible. Not a full anneal or normalise but sufficient to allow filing etc.
