Cobalt drill speed to remove broken tap
John Coates24/02/2012 17:28:00
558 forum posts
28 photos
Right the cobalt drills have arrived so I can drill the broken tap out
Original hole = 5mm
Tap size = M6 x 1.0mm
What size cobalt drill should I use and what RPM should I run it at?
Thanks folks. The sooner you answer the sooner I can get at it.
Oh and will I need coolant? (I don't have a pumped coolant supply btw)
JasonB24/02/2012 17:43:58
I would have thought you wanted solid carbide not Cobalt as thay are not much harder than the HSS the cobalt is added to.
J
IVATTLMS24/02/2012 17:50:17
22 forum posts
I agree solid carbide slotdrill no problem
John Coates24/02/2012 18:03:04
558 forum posts
28 photos
Oh arse!
John Coates24/02/2012 18:08:31
558 forum posts
28 photos
What size please for the carbide slot drill? And is ball nose OK?
Clive Foster24/02/2012 19:23:40
3630 forum posts
128 photos
A three flute carbide centre cutting endmill did the deed for me in a similar situation. Either M2 or M2.5 size and cutting dry in a Bridgeport varispeed running flat out. Somewhat below book speed, which is approximately supersonic, but it shifted 3 dead taps for me. Found the cutter on E-Bay, can't recall the brand but I think it began with N. Not a job I care to remember. Too many holes, hard spotted material, and rapidly blunting taps.
John Coates29/02/2012 14:54:05
558 forum posts
28 photos
Thanks Clive thumbs up
Bought a 3 flute 5mm bottom cutting carbide end mill from ebay. Ran it at 1800 rpm and it cut the broken tap out
So now I've got a 5mm hole I just need to see if my tap can cut a thread in it as I don't know if using the carbide end mill will have hardened the walls. If not I can cut the thread from a 6mm bolt and silver solder it in place as there will be three other bolts securing the workpiece to the trolley
David Littlewood29/02/2012 15:04:39
533 forum posts
John,
You didn't mention - here at least - the material you were tapping, which would affect the answer to your question. Both stainless steel and titanium alloys are notorious for workhardening, other metals mostly less so.
Another though - have you seen the Helicoil system for replacing drilled-out tapped holes. Never used it myself but I have seen people say very good things about it.
David
Edited By David Littlewood on 29/02/2012 15:05:02
John Coates29/02/2012 15:17:49
558 forum posts
28 photos
David
Material is a 15mm thick piece of MS plate
Yes have seen Helicoils used on motorbikes, my "models" as I don't do trains or tractions (yet) but full sized motorbikes!
Will try tapping later on. Just chuffed that the end mill got it out. I did break one of the new cobalt drills though before the end mill arrived, just seeing if it would work crying
Ian Abbott29/02/2012 15:52:40
279 forum posts
21 photos
Shouldn't think that ms will work harden.
Helicoils have worked a treat for me. A drop of Loctite helps them to stay put.
Ian
Ian S C01/03/2012 12:29:06
7468 forum posts
230 photos
John, I think I would tend to either make a bolt to fit the enlarged hole with a head to match the other bolts, or if its a stud, make a stepped stud, save you hunting around for Heli-coils, and a tap for them. Or you can do as I think you may be doing, and plug and redrill and tap. Ian S C
