Member postings for John Stevenson
Here is a list of all the postings John Stevenson has made in our forums. Click on a thread name to jump to the thread.
Thread: What Did You Do Today (2017)
29/07/2017 20:18:36
Hope you have Doune it the right. Hand 🖐️
Thread: Metal storage options
29/07/2017 18:37:32
Can find 4"square downpipe. But not 6"
Thread: Source of Silver Steel
29/07/2017 18:29:10
Learn how to chill out.
I used to run round. In 44 tonnes artics, no I make do with an estate car
Thread: Minilathe changewheels don't fit
29/07/2017 13:48:11
A few points
Possibly me deleting the fist post instead of editing
I'm in for a long time with only a mobie
Secondly for the 20,000 time Real Bull Web bankrupt about 5 years ago
The result was the better sets saw Iight under the real bull logo and the rest by the second cussing on aliexpress
28/07/2017 19:54:20
Plastic. Gears are hyfroscopic. They will easily overcome ereee these tolerances. From new, better to be
A slip filt than a prick. In a shirt sleeve
it fit thdab me a bag in. a
28/07/2017 10:06:06
I'm in the same boat planning my new shop. At one end of the bench I lille have 5 tote boxes on runners for steel, brass. Alloy, nylon etc but the other end I want to use plastic drainpipe in square section to save space. Only problem I can find is 63mm square when 80 or 100 would be much better
Thread: Jeff Thyer's Myford Gear Hobber
27/07/2017 15:08:07
Far more interesting than the discussion on new diesels in 2040 of which no one here has any control over even it it reaches fruition in 23 years entirely unchanged
Edited By John Stevenson on 27/07/2017 15:08:40
27/07/2017 11:42:00
Gear cutting is a pet subject of mine and I have studied the subject in a other of depth.
Many have also trod the path but make classic mistakes like feeding the hob in directly and not taking account of the hob helix angle
27/07/2017 10:54:21
10 out of 10 for getting a class article such as this for the magazine.
Jeff has obviously given a lot of thought to the whole process and got it right
Thread: Who was Ted Barrs?
26/07/2017 17:40:43
Lathes.co.uk give credit to Ted Barrs as the designer of the ML7 during the closing stages of WWll but the design is so innovative in looks as style and nothing like the Atlas 10"that Tony refers to that I feel that it was the most definitive design of the latter half of the 20th century.
But who was Ted Barrs?
I have odd original drawings from 1947 but his name doesn't appear to feature in any of them.
Thread: Odd Article in ME 4559 28April - A Variable Frequency Drive
25/07/2017 11:41:35
Well said Neil
Personally he was heading for the bucket list fast with that attitude from a new poster
Thread: Myford Super 7 Mk1 Motor drive belt size plz
25/07/2017 11:24:48
Perhaps the performance is linked relative to the price. No one wants to admit they have bought a pup.
Logically it's down to surface area and depth of groove hence powerful machines going on to multiple matched belts in stead odds going from C section to D section, to E etc.
This is where poly vee score, large surface area with mimimum thickness,allowing a better grip on smaller pulleys
Thread: Myford lathe id
24/07/2017 21:16:41
Why are you even asking? for $100 Canadian you could break it for ten times that.
Thread: Welding square tubing - Warping!
24/07/2017 21:09:42
Found the pics I wanted,
Back in 2012 I decided to scrap a 2 meters between centers TOS lathe for a few reasons the main ones being it was taking a lot of space up, it had some wear and it was attracting the wrong sort of work [ 1 tonne armatures etc ] when it was working which wasn't often.
Once I had started on the project it soon became obvious what the "it will come in handy one day" was.
Virtually all this had been there that long I had no idea it was there so it got skipped.
Machine dragged out and loaded up for a trip to its new home.
The scrapyard.
Which left this.
So once the cupboards had been scrapped, racks moved,  we got to the relevant part for this post.
3 metre long bench out of 40 x 40 x 3 stick welded with a crappy buzzbox as I couldn't get any of the hard wired Migs into this shop.
And I finished up with this,
Laser cutter on one end, bolt rack on the other and space for two working small CNC's with the keyboards on slide out trays on top of the toolboxes. Various metal short end drawers at one end, wall painted and all new electrics plumbed in. Unfortunately it has got to come out in the grand down size and it won't go in the new shed in one piece so I reckon a quick chop with a 1mm slitting wheel where it changes from cupboards to open space where the tool boxes fit, move in two pieces and stitch back together again and a swift repaint to credit a brand new workshop
Edited By John Stevenson on 24/07/2017 21:13:14
Thread: lathe motors
24/07/2017 09:45:59
Just that if you are using a machine with tight belts when you have a jam up the damage is greater.
2HP is well overkill for a S7
If you can afford it then think about a 1HP 3 phase with invertor
You will not regret it.
24/07/2017 05:24:28
Electrosteam,
After 5 forum posts on here it can go two ways.
The good way is you can submit a correct, factual article for Neil to publish.
The alternative way is to just carry on and loose the 0.01% of credibility you have left.
Thread: No win No fee scum warning !!!
22/07/2017 20:39:03
I change debit cards every 11 months to stop the automatic payments.
Moved house, notified the insurance thar I'd moved and wouldn't need the policy. Then later got a bill for the 3 months it had run over
Thread: SIP co2 disposable bottles
22/07/2017 13:36:46
Gas Direct at Newark
Can't quote MiG as I only use full size bottles but 1/2 hight Oxy, about 3 foot tall and 6 to 8" diameter costs 4.25 UKP per month rental, no up front charges. Refills are 7 UKP with a one off 10 UKP, per trip delivery charge.
All less Vat
MiG gas will be very similar on pricing so you have to do the sums over a period of time
22/07/2017 10:38:10
Chris, probably not what you want to hear but 50*50*2 is roughly twice as flexible as 40*40*3
Using 40*40 gives you a far more rigid frame, less liable to warp and also allows larger door and shelf areas
Thread: No respect. :(
17/07/2017 17:04:39
Just go and nick it when it's moored up
No need to unbolt it, just chop round it with a chainsaw
