Here is a list of all the postings Martyn Edwards 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Wooden shed insulation |
10/08/2023 16:44:19 |
10/08/2023 16:43:42 |
Thread: Blueing |
31/03/2023 18:57:53 |
Now retired but back in the day many moons ago when teaching metalwork we had a tank of 'Whale Oil' that was used for blueing. |
Thread: New workshop - Quart into a Pint Pot! |
03/02/2022 18:07:56 |
Posted by DutchDan on 03/02/2022 15:16:22:
That looks brilliant, seems like a nice place to work. Did you build a ramp up onto the platform to get the machines in? Funnily enough I've just made some steps up to the door today! |
Thread: Edgar Westbury could have been ahead ahead of his time! |
01/02/2022 18:55:06 |
01/02/2022 18:18:03 |
Due to a house move and losing a double garage a new 'man cave' had to be built. A 14'x8' insulated build with most of the essentials 'shoe horned' in. Still more to do. Best purchase were the 4K LED Batons, I've lost count of how many glass tubes I've inadvertently smashed in the past! Also the non slip 'coined' rubber sheet on the floor and bench tops. Very easy to keep clean and totally resistant to oils etc., .....and you can never have enough sockets! |
Thread: Milling machine, but which brand ? |
12/01/2022 17:10:31 |
Have a look at Sieg bench top Mills. Personally I believe they're a step above Warco offerings in terms of quality. Have seen both being manufactured in China in their respective factories. |
Thread: Middle of Lidl |
30/12/2021 17:33:45 |
I popped into Lidl this morning and bought a very nice double size stainless rectangular magnetic tray and also the the soldering station with magnifying glass with LED lighting. |
Thread: DRO's and mental agility |
22/12/2021 16:49:12 |
For me the biggest advantage is the ability to swap between imperial and metric measurements. I'm of an age where I experienced the change to metric late teens and thus find myself swapping between the two systems, something in the brain working on mental visualisations of key measurements in each system comes into play. Edited By Martyn Edwards 2 on 22/12/2021 16:49:46 |
Thread: Sieg SX3 and Machine-DRO 3-Axis Kit |
10/05/2021 01:22:58 |
Same kit but slightly different approach on the Y and Z Axis.
Thread: oil blackening |
30/04/2021 17:06:28 |
Back in the day it was Whale Oil.......Oh my! |
Thread: Milling machine thoughts? |
06/04/2021 19:29:09 |
EPosted by Rob Wheatley on 06/04/2021 15:58:54:
Hi All I am looking to buy a smallish milling machine as I want to start building model engines. I was looking at these with the R8 Spindle. Sieg SX2.7 750w (£1425) Fixed head no DRO Sieg SX3 1Kw (£1803) Tilting head no DRO
I like the idea of a tilting head, far easier to tilt that rather than the work piece but would have to ensure it was trammed afterwards, again factory DRO on the VM25LV would be good but could buy a kit cheaper and get it without saving about £400. Looking at the SX3, is the head handle easier to use with it at the front or is it ok on the ones on the column? Is anyone using the above mills? Ideally the VM25LV & SX3, if so what are your thoughts? Looking to spend up to £1800 on the machine plus collets etc and add to it later. Thanks Rob Hi Rob I went through the same dilemma last year and having in a past life visited the Sieg Factory in Shanghai opted for the SX3 mainly due to the build quality and low down Z Axis adjusting wheel. So far it's been faultless. I fitted a good quality 3 Axis DRO with magnetic readers from Machine DRO and have a photos and details of how it was fitted. |
Thread: Stuart Steam Plant reaching completion |
01/04/2021 18:22:40 |
Has taken Lockdown two and three to build from castings. Fortunately was able to obtain a S/H 504 boiler recently off EBay which was always going to be an issue due to current cost of new ones. Just the main steam pipe to make and lag and water level gauge to fit, although the plant also has the facility to run off compressed air from the turret.
Thread: What Did You Do Today 2021 |
25/03/2021 17:19:51 |
Started to plan out a steam plant for my two lockdown built Stuart engines. Decided to incorporate an economiser/condenser although it's probably overkill. |
Thread: Was Draw Filing ever a chargeable offence in the RAF? |
25/03/2021 17:08:56 |
Many years ago I used to teach Metalwork at a school next to Boscombe Down Airforce base in Wiltshire. Some of the students used to go on to start an apprenticeship at the base. The first 11 weeks of their apprenticeship was spent hand filing a block square to fit into a filed square hole! |
Thread: Help diagnosing escaping air on a Stuart 10V! |
24/03/2021 19:18:24 |
Thanks chaps, now sorted and running very well. It was the valve being a bit too tight on the valve nut so it didn't seat on the port face properly. Now free enough for the air pressure to push it onto the port face. |
23/03/2021 20:00:15 |
Thanks chaps, I previously suspected the valve not seating properly and checked the valve float. I'll have another look in the morning and see if there is any way it's being held off the port face. |
23/03/2021 19:22:36 |
I have a Stuart 10V which is very free running but it appears to be blowing a lot of air straight through to the exhaust pipe. When running I detect the 'pulse' of air at each end of the stroke but there seems to be air running straight through. what could be be causing this? The slide valve is centred, with a little free play and exposing the top and bottom port at each end of the stroke. The piston is a good fit in the cylinder. |
Thread: Finish for wooden base |
23/03/2021 17:22:42 |
Linseed oil based finishes are very good and can be refreshed very easily but mixing your own can be a dark art. Firstly the Wood has to be sanded and the grain filled before the thinned oil can be rubbed in, just a few drops the using the palm of your hand to rub and generate a little warmth which adds the oil penetration. Multiple applications and each time allowing it to dry will give what's known in the gun trade a 'hand rubbed finish' which is very resistant to water and oil. If you want what's called a 'London finish' the oil has to have some dryers in it and will give a gloss finish with a lot of depth but takes many applications, search for Tru Oil if you want a high depth gloss finish. Using it you can get a finish such as this |
Thread: First assembly of a Stuart Beam built during lockdown. |
22/03/2021 18:09:39 |
The Burgundy is an old British/LMS Rail colour RailMatch 1306 BR Maroon/LMS Crimson Lake |
